Question about Brother Office Equipment & Supplies
My brother 2700 printer is asking for the waste toner pack to be replaced.
Works like a charm! Thank you!!!
Posted on Aug 20, 2008
  • 134 Answers
If this is a color printer, then there is a compartment where you will find the waste toner bottle. You can empty it out or vaccum it out. Then replace it.
Posted on Jun 14, 2008
Ive replaced the waste toner box in a Brother MFC-9140CDN but the replace WTB message still continues and I still can't print. Its supposed to last for 50,000 pages, its done 8,000 pages.
Check your operator''s manual for a reset procedure. If this doesn't work, pull the AC plug overnight, if the error isn't stored in a flash memory, this may help reset it.
Jun 25, 2015 | Brother Office Equipment & Supplies
Reset Waste Toner in a Brother
  1. Remove the full waste toner box per manual.
  2. Wear breathing protection as there will be toner dust in the air.
  3. Place flat in a work area and remove the 6 screws retaining the black box cover and carefully remove cover with box still flat on the work area. Be careful, the box is full of waste toner powder.
  4. Dispose of the waste toner by tipping into waste container, being careful not to inhale the powder. Use a blower or vacuum to remove final traces of waste toner from the box and clean all surfaces with a clean cloth.
  5. Place the box flat on the bench and inspect the clear sight-glass at the front. Inside will be a black flag which should be down on the bottom of the sight glass. If not, there is still waste toner in the front of the box which needs to be shaken or blown out.
  6. Replace the cover and 6 screws and replace the waste toner box in the printer.
  7. If error message still says replace waste toner box, then you need to check the sight glass again. The flag must be horizontal at the bottom of the glass or it is not completely empty.
Jan 24, 2014 | Brother WT300CL Waste Toner Box
Excess waste toner
For MFC-9840, it was simple to find and empty the box (http://www.howtofixcomputers.com/forums/printers/brother-mfc-9440cn-waste-toner-box-reuse-288524.html) and assume it is equally easy to do once you locate the box on your model.
Jul 09, 2013 | Dell 1350cnw Colour Laser Printer
Brother toner reset
It was easy to empty the one for the MFC 9840 (http://www.howtofixcomputers.com/forums/printers/brother-mfc-9440cn-waste-toner-box-reuse-288524.html). I assume it is equally easy to do once you locate the waste toner box for your model.
Jun 27, 2013 | Brother DCP7060D AllInOne Laser Printer
I have an MFC Brother printer and I cant copy or print...it says waste toner full??? How do I fix this problem?
What model MFC Brother Printer do you have? The waste toner is left over toner from each print or copy that isn't used. It collects in a different spot in each printer. Usually the waste toner container is with the regular toner cartridge. The printer is able to detect when the waste toner is full by a light sensor in or near that container. Sometimes excess toner collects on the sensor itself and causes it to think the waste toner is full when it actually isn't. Try finding the waste toner container and empty it or replace it. clean the sensor that is on or near the container. it is likely a small black plastic piece that has 2 or 3 small wires coming from it. The model of printer will help to identify where the container is.
Jan 14, 2011 | Office Equipment & Supplies
How do I reset the waste toner box in my MFC-9840 Brother printer? (without purchasing a new one)
1. 2. -> unscrew
shake to empty
http://s14.directupload.net/images/130409/awjs9m88.jpg
Jan 07, 2010 | Brother MFC-9840CDW Laser Printer
Brother 4070cdw waste toner is there a way to empty it
Messy.
Best to replace the waste toner collection unit.
This is a user replaceable, consumable part.
Dec 10, 2009 | Brother HL-4070CDW Printer
What is a waste toner box. what does it do and
like the name suggest, it collects waste toner. Any toner that is left over from the print process is waste toner. Once the waste toner bottle is full, the printer will stop working until You have replaced it with an empty waste toner bottle. So in short, if it is telling u to get a new one, get one or the other option is to empty it yourself which is very messy and if u dont clean the bottle of all toner dust, may not even work.
Oct 10, 2009 | Brother HL-4070CDW Printer
The printer asks for waste toner to be replaced
your printer has waste toner container in it, and it's full. it's needs to be replaced.
if you have a new waste toner container and it's still saying needs replacement, the sensors on each side needs to be cleaned off.
Jun 14, 2008 | Brother Office Equipment & Supplies
61 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
