The red, yellow,white cables connect them to both of the dvd players.One of them the little switch on the side put one on dvd and the other one on av in. then put a dvd in one and play it. (make sure both are on)
If you are getting No Disc issues, blow on it using some compressed air. After I did that several times, my discs had no problems getting recognized and playing again.
I called Venturer's support line. They are aware of the problem (a connection between the player and the monitor). True in my case because i can connect it to a television and it plays fine. For $45 (flat rate) they will repair or replace the units with new 1 yr warranty. The $45 includes their shipping it back to you, but naturally I'll have to play postage to send it to them. (The number I called was 800-252-6123)
The shipping address is:
Venturer Electronics (make check out to this name)
203 Eggert Road
Buffalo, NY 14215
I was given a reference number to put on the outside of the box, but I'm sure it was specific to my name and address they requested.
Sounds like heat related problem. It is possible that a vital component inside (circuitry) is heating up. Chances are that it is a component level repair. If you are not comfortable working with a soldering iron and a VOM, it is probably best you seek the services of a qualified technician.
It is also worth to check if the unit has an exhaust/cooling fan that simply is not turning right.
Good luck and kind regards.
here is the link to the user manual, troubleshooting and venturer support contact details;
http://www.1800customersupport.com/products.aspx?view=93&p=43&sc=5&sn=Portable%20DVD%20Players&pn=DVD%20Players%20and%20Recorders
Hope this helps, please post again if not :)
