1995 Nissan Sentra Logo
Posted on Jun 14, 2008
Nissan Sentra Series 3 won't start
My nissan car was flooded for arround 2 hours. The next day, we tried to start it. It started, but after a few minutes, we switched on the aircon and the engine shut down. Now, it won't start anymore. What's wrong with it?
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on Oct 05, 2008
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
349
Points
I have the same problem. When I let the car sit over night it cranks right up, but if I cut it off it is off for hours and won't crank.
97 Nissan Sentra runs fine for about 2 miles then starts losing power and dies wont start back up for about an hour
Check Engine Light/Loss of Power Due to Throttle Body Unit ...
repairpal.com > Problems > Nissan > Sentra
The electronic throttle actuator (throttle body) can fail causing a loss of power ... start it studders like it is running on 2 cyl. then switches to 3 cyl. then to 4. but ... Throttle body replaced on my 2006 Nissan Sentra 1.8 engine. ... I Was going up a hill and I tried to speed up, all of a sudden my car bogs down and completely dies.
2004 Nissan Sentra SE-R Cranks but won't start!
It could be the fuel system.
It could either flooding or starving for fuel.
If injectors are fouled badly it will wet the plugs and not fire.
If plugs are pitted that makes it easier to flood. (check plug tip condition, check all plug wires and boots are good)
If it is starving -- fuel pump weak (going to fail).
Need to test fuel pump pressure.
I have a 2001 nissan sentra, and it seems to have a common 2001 nissan sentra problem. i went to start her about 2 months ago, and she fired right up. drove around, went home and she sat til the next day....
Go over it, check the air filter, fuel filter, make sure your key isn`t bent. bent keys off set the chip and the car cant read it. next time take out the key and turn it around and try it again. let me know.
2006 nissan sentra 1.8s cold start problem
run the fault codes
indicates a problem ambient temp sensor or a Baro sensor that is not report correctly to the ECM so the correct cold start air/fuel mixture is not being set
Just purchased a 2002 Nissan Sentra and 3-5 days later the car began shutting off when stopped on several occasions and starting back up. Lastly the car shut off while in park and would not start up again...
Next time it does it. try hitting the fuel tank. a couple times if necessary. if it starts back then your fuel pump is dieing. some times when the pump heats up they will stop working, only to come on latter. let me know
Start up issue
Could be a plugged catalitic converter
2helpful
My nissan sentra floods too easy why?
if its flooding its your fuel pressure regulator
2answers
Unusual starting problem, Nissan sentra '96 GXE 179K
Probably not because the tool reads if the injector is getting pulsesw, not if it is sealing correctly when off. I'd try to take a look at the spark plugs to see if any have fuel on them after you crank once in no-start. "On the floor" likely would take longer because injectors are adding fuel while you are trying to remove it.
2helpful
2answers
1999 Nissan Sentra won't start after switching drivers
Check the ignition coil, i had the same problem before and they also told me that it was a computer problem, if it's a failed computer then it will never start.
Top Nissan Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Nissan Expert? Answer questions, earn points and help others
