Question about Proform 760 CrossTrainer Treadmill
Describe your proform 765 ekg sticking Problem When I am running on the treadmill, the belt sticks/stops and I about fall off. It happens just for a second, but it causes me to lose my balance. Someone said to spray the underside of the belt with vegetable spray...any other solutions?
  • 297 Answers
The problem you have is one of two things. 1 you have a loose walk belt, or 2 you have a spun front drive pully.
You need to remove the front cover to be able to observe the drive belt as it is turning on the drive pully( on the LH side of the front roller) try to stop the walk belt while traveling at speed setting 3. Hang on to the side handles, if the drive belt runs as normal, watch the front roller it will be slipping. If this happens you will need to replace the front roller.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/matt_8dbc24bf722649ac
Posted on Nov 05, 2010
    New Friend:
Just u tighten the poly belt function and applied the lubricant under the belt and tighten the running belt tenction after start and run freely
Posted on Sep 12, 2014
Belt sticks when running and briskly walking
Walking belt or drive belt loose. If you get noise while this is happening your front roller is likely bad.
Dec 25, 2013 | Proform Xp 550s Treadmill Walking Belt
My Treadmill PROFORM 760 EKG will just stop as I am walking on it.
see the video and proceed according. Lube the rollers front and rear, test the drive belt motor and replace.
God bless you
Jun 16, 2013 | Treadmill Doctor PROFORM 770 EKG TREADMILL...
My Proform 770 EKG treadmill's motor is overheating. What is the voltage that should be pulled during use? Should the walking belt be replaced if we replace the motor?
see the video and lube correctly. 2) go to my personal TIPS for motor help.3) however you must see the voltage in the plate of motor. the tolerance will be +- 10% of voltage. can be voltage continuosly or alternating voltage.God bless you6527db9f-a9f8-47a6-9208-af2b680ea3a0.jpg
Apr 01, 2013 | Treadmill Doctor PROFORM 770 EKG TREADMILL...
I have a proform 765 ekg and just replaced the motor because the treadmill kept stopping but it still stops and the breaker kicks off and the motor is real hot. any thoughts on why it still stops
LUBE the deck belt and rollers bearing this happen to due the lack of maintenance. see the video attached. Do it with silicone or wax read your manual.
If after you did lube the problem remain, TIME to replace the old board deck belt.
God bless you
Feb 16, 2013 | Proform Quick Burn Pro Treadmill with 12...
Is there a weight limit on the Pro-Form 760 EKG treadmill? While I am walking the belt skips and I feel like I am going to fall.
not sure if there is a weight limit but did you check the belt tension.
front or rear roller should have an adjustment screw on both sides to tighten the belt. this could be the solution to your problem
Aug 24, 2011 | Proform 760 CrossTrainer Treadmill
I have a Proform 770 EKG Treadmill jerks and squeaks
The drive belt was loose. I tightened up the motor just a smidge using a crow bar. That solved the problem.
Dec 29, 2009 | Exercise & Fitness
Proform 765 EKG
If I understand correct, the treadmill will not run correct unless you have the safety key in. Well yes this is correct because once the safety key is removed the treadmill will stop. If your treadmill is running extremely fast just by turning it on, you may need a new speed sensor. www.AtlantaFitnessRepair.com
Aug 10, 2009 | Proform Sport 1000 Folding Treadmill...
Treadmill Speeds Up Automatically
you might have it on a preset workout....i would read the instructions and find out how to put it on manual
May 19, 2009 | Proform 810 TR Treadmill
Treadmill LED Track does not go to start with key inserted
I pulled the safety switch out, and the elevation is stuck on 10 degrees
May 14, 2009 | Proform 775 Crosstrainer Treadmill - Free...
Proform 760 CrossTrainer Treadmill Logo
884 people viewed this question
Top Proform Exercise & Fitness Experts
Ross Metcalfe
Ross Metcalfe
Matt Olenzek
Matt Olenzek
 Atlanta Fitness
Atlanta Fitness
Level 1 Expert
Are you a Proform Exercise and Fitnes Expert? Answer questions, earn points and help others
