Question about Poulan 25CC Gas BlowerVac
How check the ohms, on pick-up coil Poulan-Pro Leaf Blower?
boscia
  • 163 Answers
SOURCE: Poulan leaf blower wont start
try changing the spark plug. if that doesnt work let me know and i'll help you trouble shoot it.
Posted on Nov 30, 2008
  • 15 Answers
SOURCE: Poulan Pro 200 Leaf Blower won't start. I have
Ok. Good job on doing what you could, right off! The simplest things are the most overlooked, and the most unforgiving.
So, you know your plug is wet, so you got some fuel flow.
Now let's figure out the plug no-fire problem. (This is under the assumption you haven't beat on this blower with a sledge-hammer at one point. The whole "key-way" is fried thing.)
1. Grab ahold of that plug THEN crank away. One time will tell you yes or no on spark. No, I am not joking, and yes, it is better than staring at the end of a plug and wondering if your eyes are bad.
In fact, better than a cup of coffee......in a bad way.
2. Check your kill switch. It is either: Grounding, or Open (open like it should be, UNTIL you push it, click it, or slide it, whatever you got). One CHEAP and fast way: Unhook the kill switch.
Then crank away. No spark? Not the kill switch then!
3. Check your spark plug GROUND. Let's say you got some shocking results from grabbing onto that bad boy. NOW check where the plug meets the cylinder head when she is screwed down in there. Believe it or not.....if it is funky, she won't ground right!
Hence, no worky.
4. You got no spark at all.....STILL. Let's look over your Spark Plug WIRE. Is she wore through? Is SHE grounding out? Has she heat failed? Then do #5.
5. STILL no spark. Let's check the last 2 things......
Rotor Magnets, and Magneto (ignition coil).
IF you have a volt/multi-meter, hook her up to the plug wire. No juice = Bad Magneto, or Bad Plug Wire. SOME juice = Good Magneto, but Bad Plug Wire (in some mowers/weedeaters, etc., remember that the Magneto is where the kill switch hooks too.
See if it is somehow grounding you out, by being loose but still touching the cylinder, etc.)
6. Failing Magneto. This can happen, and it does. You get SOME juice, just not ENOUGH juice. 2-Strokes make a lot of heat, even Magneto's give up the ghost after a while, sometimes. In this case, find a replacement!
Posted on May 30, 2009
bulldogchief
  • 388 Answers
SOURCE: what type spark plug for the Poulan Pro PBV 200 LE
RCJ6Y is the plug number, you can get them at any home improvement store for about $3
Posted on Sep 11, 2009
jdlipscomb41
  • 157 Answers
SOURCE: Hi, I have a Poulan Pro SM400 leaf blower, I have
poulan is a cheap blower no offense so it could be a number of things take it to a dealer for repair
Posted on Sep 18, 2009
  • 256 Answers
SOURCE: Leaf blower does not respond when increasing throttle and engines
Unit is either having trouble picking up enough fuel or muffler is plugged. First disassemble the muffler and check that the flame arrestor screen is not clogged. Clean as needed. Cost, $0. Check fuel pickup line from fuel tank to carbureator for cracks. Replace if brittle or cracked. Next would be to check the diaphram in the carbureator. Even a small hole or crack can cause this problem.
Posted on Mar 31, 2010
I have a 2004 Poulan Pro PBV200 leaf blower, and have purchased a new ignition coil. My question is, how do I install it?
you have to pull the whole unit apart
air gap is important so note the gap on the coil before undoing the old one
exploded views
Poulan PBV200 Pro Leaf Blower Parts
you tube link
Poulan pro leaf blower no spark
POULAN PRO PBV200 INSTRUCTION MANUAL Pdf Download.www.manualslib.com > Brands > Poulan Pro Manuals > Blower > PBV200
Oct 13, 2016 | Poulan Garden
I need a repair manual for Poulan Pro PPBP30 leaf blower
The best you will get is a User Manual as repairs are usually left to the manufacturer or a dealer. The head office is 5 minutes from where I live!
http://lawnandgarden.manualsonline.com/manuals/mfg/poulan/ppbp30.html
Oct 29, 2015 | Poulan Pro PPBP30 30cc Gas Variable Speed...
Can I get a trouble shooting guide for a Poulan Pro leaf blower bvm200vs
the owners manual, available online has some trouble shooting tips...
Oct 18, 2014 | Poulan Bvm200vs 200mph 25cc Gas Pro Leaf...
What is the air gap for Poulan pro BVM 200 blower. I am not getting any spark with a new coil. Thank you
.010 make sure its not on backwards some have an arrow molded on them to show wich way flywheel turns and make sure grounw wire is not pinched against metal that will shot the coil hope this helps
Aug 17, 2010 | Poulan Pro Reconditioned BlowerVacuum 25cc...
Poulan pro weedeater will start fine run untill you pick it up then dies
poulan has a bad habit of the fuel breaking inside the tank if it breaks before the fuel filter that makes the fuel line shorter
Nov 05, 2009 | Poulan/Weed Eater #Wt200 711724 24cc Gas...
Poulan Pro leaf blower will not start. I need to
Buffalo Creek Small Engine
1054 Teels Branch Rd
Hunington, WV 25708
304-429-4301
This is a repair place Poulan shows for your area.
Good Day.
Oct 26, 2009 | Garden
What is the gap setting on coil for poulan pro pbv 200 le
It should be 0.010.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Oct 05, 2009 | Poulan/Weed Eater No. Bvm200le 711482 24cc...
Poulan 25CC Gas BlowerVac Logo
479 people viewed this question
Top Poulan Garden Experts
Jim Parker
Jim Parker
roeb
Jay Finke
Jay Finke
Are you a Poulan Garden Expert? Answer questions, earn points and help others
