Question about Samsung C417 Cellular Phone
Camera set up problem
I click on the Set Up menu under Camera Settings, But it will only let me change the "Default Name" and none of the other settings (Brightness Sound, Zoom) because I can't scroll up.
    Brigadier General:
  • 7,752 Answers
Take the phone and have the keyboard replaced
Posted on Jul 02, 2008
My olympus sp800-uz is protected with or without the sd card
I cannot find a menu setting to protect everything.
You could try making sure this is set under "Menus for Other Camera Settings"
Selecting a storage device
[INTERNAL/SD] is set to AUTO.
The only other option I would suggest is RESET under the same menu.
This resets the camera settings to default.
You would lose the things you have set yourself and would have to change them back to how you like them.
Oct 12, 2014 | Cameras
Touch screen frozen
the best solution to fix this problem is to get it repaired or replace if it is still under warranty.
I'll let you know if there is any other solution to fix this.
Apr 12, 2008 | Sony Cyber-shot DSC-N2 Digital Camera
How do i reset my canon rebel t3i back to default settings
Go into the Menu, Go to the ninth Submenu folder, Sec one from the end, Then Go to clear settings, Third one down, Hit set, Then Clear all Camera Settings. TC Camera Repair.
Jul 08, 2014 | Canon EOS 600D Rebel T3i Digital Camera
I am having a sony cybershot s750, i have checked almost each and every setting but unable to click clear picture. On proper light condition clicked picture were having linings viewed as picture taken of...
You may have changed the light condition settings,white balance etc which will will create bad images when not used under the prescribed conditions.Since you are not aware which all settings you have changed, you can restore the settings of the camera to factory default values.This will allow you to use the camera under normal conditions.Please refer the instructions shown below to set the camera to default values.
Please don't forget to rate me if satisfied with my solution.Thanks for choosing Fixya.
TinuAlbinAlex.
Jun 17, 2011 | Sony Cyber-shot DSC-S750 Digital Camera
I have sony DSC-W190,i want correct menu setting ,bcos if i take a picture its not clear,i think may be menu setting changed,idnt any idea about menu setting pls help.....
If the Menu settings in the camera is changed, then I suggest you to reset the Camera back to factory default. Initializing the Camera back to factory default will set all the settings in the Camera back to factory default.
To initialize the Camera back to factory default, select the INITIALIZE Option from the Main Settings 1 Menu of the Camera to OK.This will set the user defined settings back to factory default. The images and videos will not get deleted.
You can also try a manual reset;
Turn off the camera.
Remove the battery pack.
Press and hold the power button for 30 seconds.
Allow the camera to remain without power for 60 seconds.
Reinsert the battery pack.
Turn on the camera.
The blurry image capturing can also adjusted by changing the ISO Settings or the Scene Selection modes.
Thanks for using FixYa!
Apr 07, 2011 | Sony Cyber-shot DSC-W190 Digital Camera
How do I change the language from japanese to english of my sony DSC-w190 digital camera?
Click Sony Support and download English User Manual copy, press Menu, settings, main settings in same sequnece and select Initialize camera, this will set camera to default settings and camera will ask time, date and language settings, select English.
Hope this info will help you.
Thanks.
Nov 14, 2009 | Sony Cyber-shot DSC-W190 Digital Camera
My sony cyber-shot DSC-W190 digital camera has a japanese language. I want to change its language to english. Any solution you can teach me? Please..
How to connect to remote camera
To create new Camera Window
  • Click New Camera from the File menu.
  • Camera Setting dialog box appears.
Camera Setting dialog box helps you control selected video source. To open the Camera Settings dialog box, select Camera Settings from the File menu.
Set a preview rate in the Preview Frame Rate box. It indicates the number of frames per second in the camera window. The default value is 10 frames per second. This value doesn't interfere with broadcast or record frame rate.
Remote Cameras
Remote camera is another Active WebCam program with enabled Remote Access launched on remote computer. Both programs use UDP protocol to communicate each other. If connection with Remote camera goes through firewall, make sure that the IP address of your computer, local and remote ports are opened on the firewall, and the UDP protocol is enabled.
To connect to Remote Camera
In the Device tab click to select Remote Camera.
Specify the computer address in the IP address box. Don't place the protocol prefix (like http://) in the address, just four digits of IP address delimited by dots, like: 192.168.1.101. You can find out the remote computer IP address by clicking Get Computer IP Address from the Tools menu on the remote computer.
Type port, which is opened on remote computer for remote access in the Remote Port box. This value is specified in the Port box in the Broadcasting | Remote Access properties on the remote computer.
Specify port, which will be used to receive data from remote camera, in the Local Port box. If your network uses firewall, make sure that Local Port and computer's IP address are opened in the firewall. Use the Check the Port Availability button to make sure that this port is not used by another program.
If the remote computer requires authorization, enter user name and password in the appropriate boxes. The authorization could be set in the Broadcasting tab in the Camera Settings window in the Remote Access Additional Settings window on the remote computer.
If the Remember Password check box is checked, the user name and password will be saved among the session parameters.
Cycle through cameras
If you have multiple cameras you can set up a cycler to have the program to change cameras automatically.
To configure the Camera Cycler:
  • Click Camera Settings from the File menu.
  • Select Cycle through cameras to activate cycler.
  • Type cycler interval in seconds.
Select cameras to cycle.
Jul 13, 2009 | HP USB Web Camera
Microphone Not Working
Each one of those applications has their own settings for audio. However to make it easier, you can set your webcam as the "default" input device for audio.
To do this, click on the "Start" button then goto "Control Panel"
Once in "Control Panel" click on "Sounds and Audio Devices" Then click the "Audio" tab at the top of the new box.
Under "Sound Recording/Default Device" click the drop down menu and choose your webcam from the list.
These steps may differ slightly depending on the version of Windows you are using. But this will set your webcam as the default microphone for all applications.
Jei
Dec 10, 2008 | Logitech QuickCam Communicate STX Personal...
New camera that doesn't respond...
I am assuming you are talking about a Polaroid 8MP I830 camera.
http://www.polaroid.com/service/userguides/digital/cameras/i830_ug_en.pdf
Link for manual
Factory reset
Resetting to Default Settings
You can easily change all the settings you made back to the camera default setting by the following steps.
Please refer to "Camera Default Settings" on page 103 for more details.
1. Access the setup menu.
2. Press or to select (RESET ALL).
3. Press the or button.
4. Press or to select "YES".
5. Press the button.
Setup Menu 3/3SelectExitBattery Type AlkalineReset All NoSetup Menu 3/3SelectOKBattery TypeReset AllYesNo
NOTE:
The following settings do not change with this procedure:
• Date & Time setting
• Language setting
• TV out setting
Contact Information
Phone: 1-877-388-3779
Email: Click Here
Customer Support Hours:
(Mon - Fri:) 10:00am - 7:00pm EST
(Sat:) 10:00am - 4:00pm EST
Warranty on Cameras 1year parts and labor
There is no response from the camera while pressing any buttons.
The LCD screen is frozen or the camera is hanged.
Remove and re-install the battery or batteries to reset the camera. Your valuable data stored in the camera will not be lost.
I hope some of this helps, if not above is the contact number for Polaroid tech support. You camera seems to be still covered under warranty.
Good Luck
Mar 28, 2008 | Cameras
Samsung C417 Cellular Phone Logo
18 people viewed this question
Top Samsung Cell Phones Experts
Computer Repairing
Computer Repairing
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
