Question about Janome Sewing Machines
Thread seems to get all caught underneath around the bobbin. Now the thread take-up lever won't seem to move as I turn the wheel. I have had it serviced. All is fine and good from the check up. Was using earlier today with no problem. Now it seems to do the same thing again as stated above. This was the reason why I took it in to a Jonome dealer. I have a Janome New Home JD1818.
SOURCE:
snakehead
  • 1074 Answers
SOURCE: Thread getting caught underneath
you need to replace your shukle that holds the tread bobbing below.it is either slack or broken . if it is slack then you tighten the little screw that holds a cover that gives the thread tension .if its broken then replace it.once the thread is slack below it will cause your thread to bundle up.
Posted on Mar 19, 2007
RickE1
  • 202 Answers
SOURCE: Thread is bunching underneath fabric
Needle in correct? Be sure your bobbin is not in upside down and turning the wrong way. Possibly the hook that the bobbicase fits in/on has been hit by a needle and caused a burr that is catching the thread as it comes around. The burr would have to be polished off or hook replaced. The machine could be slightly out of time also.
Posted on Feb 11, 2009
jpack76645
  • 23 Answers
SOURCE: Thread getting caught in bobbin area
If you are seeing the needle thread in loops and birdnests then its the needle thread you need to check. The main reason is it is not threaded through the takeup spring(the one that moves) This action is critical as it is how the thread is pulled up tight. Also make sure the needle thread is between the discs and that it has sufficient tension that you do not see it on the bottom of the material. Try this: Use two different color threads for needle and bobbin. If you see the needle color on the bottom then the needle thread is not tight enough (or in 5% of the cases the bobbin is too tight or hung up). Let me know how it does. Jay
Posted on May 29, 2009
  • 136 Answers
SOURCE: will not pick up bobbin thread
Unusual for this machine. Check to be sure the needle is inserted with the flat side to the back of the machine. If it is, remove the needle plate, bobbin and bobbin case. Turn the hand wheel slowly toward you and see if the point of the hook is above or below the eye of the needle when the hook point is aligned behind the needle. If the eye is above the point of the hook the machine is out of time and best taken to qualified technician.
Posted on Jul 04, 2009
  • 26 Answers
SOURCE: needle wont pick up bobbin thread
timing issue, need to have serviced.
Posted on Aug 22, 2009
Hand wheel is binding - seems to be a problem with the plastic gears inside, but I don't see that there are any warn spots on them or on any belts. Any suggestions?
First, take a look at page 68 in your user's manual. If you don't have it, you can download it free at the Singer Sewing machine site. You can (and periodically should) remove the face plate over the thread path for cleaning and oiling. There are probably threads wrapped around a part there, and in addition, you can take a flashlight and look to see if there might be threads underneath the bobbin winder preventing the machine from moving.
More rarely (but possible) there may be threads wrapped around the gear underneath the bobbin basket (holds the bobbin case), so you ,may need to remove the base to access that part, but it's generally not a difficult process.
While you are there, it's probably time to use a little sewing machine oil and lubricate the parts, as per your user's manual.
Jun 27, 2015 | Singer 57815 Mechanical Sewing Machine
I have a Pfaff 4.2 Quilt Expression. I am free motion quilting and the bobbin thread keeps hanging up. Any suggestions?
1. The top loading bobbin cases have small brackets to keep them from turning or moving up or down.
2. Adjust brackets with small screwdriver. Allow enough room for thread to flow through.
3. Rotate hand wheel both directions to make sure the bobbin case doesn't move around. Also, watch the thread to see if it is flowing across the top of the bobbin case.
4. You may need to slow down movement of your "free motion". Also, make sure you are using the right pressure foot.
Mar 20, 2015 | PfaFF Sewing Machines
My machine is not catching the thread around the bobbin holder
It sounds like you have a thread jam. Depending on the machine there may be lever that will release the bobbin shuttle, and another 2 levers to release the cover plate. Pay attention to positioning so you can put it back together. Remove the shuttle, then the bobbin cover and see if there are any knots of thread getting in the way.
Oct 05, 2014 | Sewing Machines
Showing E6
You receive the error message E6 when the motor locked up because thread is tangled or the machine is seizing up.
Remove the tangled thread, it it still happens that means your machine is seizing and requires service.
Apr 30, 2014 | Brother CS-8060 Computerized Sewing...
Bunching and knotting from underneath
check there is no dirt in tension discs and that there is tension on needle thread. check that there are no marks on the hook (sharp point that travels around bobbin)
Jan 27, 2013 | Sewing Machines
I can not bring the lower thread up. The hook race does not seem to be turning and so the bobbin doesn't turn .
Sounds as though you have thread caught up inside the racer. You can try removing the boobin the turning the balance wheel back just a little to see if you can see a tail of thread caught up around the racer. Dont force the wheel or you can mess up the timing which is a major repair.
Mar 01, 2018 | Euro-Pro Easy Sewlution 385 Mechanical...
My problem is between the needle and the bobbin. The tread continues to get caught just below the needle- inside of the machine. The bobbin seems to be lifting up and thread gets caught beneath the needle
Hi. So is this a horizontal hook? Where is the thread getting caught beneath the needle? Maybe on the hook? Check your upper threading to make sure the thread passes through the thread take-up lever. If thread is not through the lever, it wont get pulled up , which can lead to multiple thread loops getting caught on the hook, not pulling off after the rotation.
Apr 15, 2011 | White Sewing 2037 Mechanical Sewing...
Thread gets caught in the screw behind the thread take-up lever
Is this your Model here
  • tension disks ( the coil/spring ) needs to be replaced
Sep 25, 2008 | Sewing Machines
Mar 10, 2007 | Euro-Pro Shark 80 - 7133
Sewing Machines Logo
35 people viewed this question
Top Janome Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Irene Tulloch
Are you a Janome Sewing Machine Expert? Answer questions, earn points and help others
