Question about Magellan RoadMate 860T GPS Receiver
No Green Light or Lite Screen
I plugged the unit into my car as usual. The red light turns on but I can't get the green light to come on and the screen remains off/black.
I fixed the problem DAH the sleep switch was on and in order to turn it back on, I had to slide the little switch that is located on top of the unit.
Posted on Jun 15, 2008
My son's DS Lite stopped working last night. The unit was working fine and the battery light turned red so he put it on to charge. After about an hour the light was green so he tried to start the console...
It sounds like the battery is dead. You can order a replacement battery direct from Nintendo at http://store.nintendo.com/webapp/wcs/stores/servlet/ProductDisplay?productId=108205
Jan 27, 2014 | Nintendo DS Lite Console
Green "ice size" light is
try to reset your unit to unplug the unit then after a several minutes plug it on then observe the unit.
Mar 06, 2011 | Refrigerators
My ds lite won't turn on both fuses are good the top screen was broke so I tried another screen I had that dident work. So I put the old one back on and now the ds wont turn on .The green lite flashes then...
It's all to do with the top screen... What happens is that when you turn the DS lite on it performs a quick check on the screens to make sure they are connected properly, if one or both are not connected properly then the unit will shut down.
The flashing of the screen shows you that that particular screen is fine whereas the one that does nothing is not connected properly, either through a loose connection or faulty screen/ ribbon.
Your best bet is to buy a new top screen (I usually get mine from ebay for around £10-£12) and fit it. That should sort out your issue.
Any further problems or questions feel free to message me via my profile page.
Regards,
SOD69
Feb 22, 2010 | Nintendo DS Lite Console
Ds lite flashes on but fuses are ok
One or both your screens have blown.
Try removing the motherboard from the screens and attach the battery the green light should turn on and stay on.
Now attach the lower screen and turn on. If the screen is ok the screen and green light will flash and then turn off. (if the screen doesn't flash the bottom screen is you're problem and will have to be replaced)
If this happens the problem is then you're top screen which you will have to replace.
Jul 26, 2009 | Nintendo DS Lite Console
DS lite green light comes on, top screen flash,then switches off
Check L2 near the power switch on your DS mobo. That part usually get loosen or taken out when you drop your DS. And usually you can recover it when dismantling your DS.
Jun 16, 2009 | Nintendo DS Lite Console
Pioneer PDP435PG inadvertently reprogrammed by Casablanca remote.
Some ceiling fans have jumpers that can be moved to select a different frequency but you have to be sure both the remote and the fan receiver are set the same. Other than that, you may have to use some creative control. For example, I can turn on my TV by pointing the remote at the wall opposite the TV
Mar 29, 2017 | Pioneer PDP-4350HD 43 in. Plasma...
The Power Light is Red
yeah, should stay red when unit is turned off, indicating there's power but it's doing nothing.
Per user manual:
Solid red - power off (standby mode)
blinking red - power off (now cooling)
blinking green - power on (preparing to light lamp)
solid green - power on
Mar 08, 2009 | Panasonic PT-40LC12 40" Rear Projection...
Replaced Bottom screen bypassed fuses still problems
the backlight or fuses are dead. Do not bypass fuses or you'll kill your system.
Jan 23, 2008 | Nintendo DS Lite Console
Magellan RoadMate 860T GPS Receiver Logo
100 people viewed this question
Top Magellan GPS Experts
Will Halftowaite
Are you a Magellan GPS Expert? Answer questions, earn points and help others
