Question about Briggs & Stratton 6200 Watt Electric Start Generator 30242
I require a user manual for a Scorpion PM 6500 LX Generation 2 generator, also its wiring diagram. Can you assist? This is an electric start machine. On attempting to start it with the key yesterday, it turned over a couple of times then went dead. changed the battery thinking it might be dead, and tried again but not even a click. I have looked for a broken or disconnected wire and can see nothing out of order. Machine will start and run OK with the backup pull starter Regards, Graham Luck
miket756
  • 2702 Answers
SOURCE: Stopped the auto testing a couple months ago.
sounds like the starter batter is flat try charging it up for a day or so then have another try,,,
Posted on Oct 27, 2009
  • 37 Answers
SOURCE: My Briggs and Stratton standby 7000w home
Check the battery voltage while cranking the engine if it drops below 9 VDC then you have a bad battery.
Posted on Nov 20, 2009
  • 172 Answers
SOURCE: Hello,
These units are equipped with a low/no oil shutdown. When you hold the switch over to start it, it overrides the shutdown interlock until the unit builds oil pressure in the engine. When you release the switch to the run position the interlock is engaged. Ensure there is sufficient oil in the crankcase, check the wiring from the oil pressure switch to the ignition cutout-(it may have been pulled off or damaged). If that checks out, then either jump across the 2 wires at the oil sending unit or disconnect the harness from the sending unit to test to see if the sending unit is bad. Try both unless you know the switch is normally open or normally closed. Replace the sending unit if needed.
Posted on Jan 05, 2010
  • 243 Answers
SOURCE: I have a white wire - approx. 5' with no home that I can see
please connect it to earth(chassis) and look if it is stil sparking. i think it is the wire to stop the gen. it used to be fit behind the handle to start and stop please let me know, thanks.
Posted on Feb 15, 2010
  • 130 Answers
SOURCE: Won't start: I have a tested
You can "bypass" the starter solenoid and hook your 12 volts straight to the starter but it has to be a temporary contact. You can not leave it hooked up. You do need to be careful as sparks can come from this type of connection.
If you are not getting voltage on the "outlet" side of the starter solenoid then your solenoid may be defective. It is just a switch that transfers battery voltage to the starter, once the engine starts it is no longer needed, except to start the engine again.
You may have other issues. Not knowing exactly what model engine you have, there could be some internal issues that is making the engine difficult to turn over. If this is an OHV engine, the valve settings may be off that affect the compression release. The starter motor will not turn the engine over under "full" compression.
We have also seen carburetor issues that create "flooding" conditions and the combustion chamber will fill with fuel and the engine will not complete a revolution when trying to start.
Hope this helps to get you in the right direction.
Posted on Feb 20, 2011
Want to start fridge with generater what wattage do I need to start
find the decal on the fridge( side , back inside ) that has the specifications on it
it will show wattage usage for the motor , volts required and phase/cycle requirement
now for example --if the wattage is 750 watts , then the start up wattage will be almost double for a few seconds until the motor builds up speed
so the generator size will be 2000watts continuous
that is an example
however understand this , if you get a genset that just covers the watts required , it will use a lot more fuel under full load than a gen set that has a capacity of say 4 times the requirement
next point-- gensets that just do the job will struggle on compressor start up and that can cause problems on modern fridges power boards where as a larger genset will hardly notice the load of a starting compressor
Lastly always use a surge protection board before the fridge lead as gen sets can "hunt " and produce power surges which can damage a board of the fridge
In reality if you have an outage,-- mostly at night,-- I would consider a gen set of 6500 watts capacity as that will handle fridge , freezer and house lights
I run a scorpion 6.5 kw get set connected to the house by a three way switch and a caravan plug in the meter board and that runs 2 fridges , freezer , lights and one small plate on the electric stove and 20 liter fuel tank lasts up to 6 hours running
and no it is not an inverter type so the cost of the unit is around $1200.00 aud compared to an inverter type which is more than double that price
plenty of food for thought so that you make an informed decision
Aug 21, 2016 | Refrigerators
Just received my amazon fire 5th generation. new at this and have no idea how to use. is there an ibstruction manual for it
There is indeed Ramona. You have purchased a great product and one with the very best help site on the Internet!
Here are some pages an I will put a link to instruction videos at the bottom.
  • KINDLE USER'S GUIDE 5th EDITION kindle.s3.amazonaws.com/Kindle User's Guide, 5th Edition_English.pdf · PDF file KINDLE USER'S GUIDE 5th EDITION Contents · 2 Table of Contents WELCOME 9 CHAPTER 1: Getting Started with Your Kindle 20
  • Kindle Fire HD User's Guide 5th Generation Manual: Unleash ... www.amazon.com > ... > Kindle eBooks > Education & Teaching All new Kindle Fire HD Manual for the Kindle Fire HD 5th Generation! Are you a Kindle Fire HD tablet owner looking to get the most out of your device?
  • Kindle Fire HD User's Guide 5th Generation Manual: Unleash ... https://www.amazon.ca/Kindle-Users-Guide-Generation-Manual-ebook/... Kindle Fire HD User's Guide 5th Generation Manual: Unleash the Power of Your Tablet! eBook: Shelby Johnson: Amazon.ca: Kindle Store
  • Related searches for fire 5th generation manual
  • Amazon.com Help: User's Guides for Kindle (5th Generation) www.amazon.com > ... > Kindle E-Reader and Fire Tablet User's Guides User's Guides for Kindle (5th Generation) ... User's Guides for Kindle Fire (1st Generation) User's Guide for Kindle Fire HD 7" (2nd Generation)
  • Fire 5th Generation Manual ~ June 2016 from kindle fire world kindlefireworld.net/apk/fire-5th-generation-manual Fire 5th Generation Manual, see also any related to Fire 5th Generation Manual, from kindlefireworld.net on June 2016
  • Amazon.com Help: Kindle E-Reader and Fire Tablet User's Guides www.amazon.com > Amazon Device Support User's Guides for Kindle Paperwhite (5th Generation) User's Guides for Kindle ... User's Guides for Kindle Fire 1st Generation; Was this information helpful?
  • Go to Bing homepage
    Jul 01, 2016 | Amazon Tablets & eReaders
    1997 DODGE RAM
    Engine and trans ?
    Dec 16, 2015 | Dodge Cars & Trucks
    I need to get a user manual for an Apple iPOD nano - 6th generation. How can I find one??
    Here is the users manual for your Ipod nano 6th. generation.
    http://manuals.info.apple.com/en_US/iPod_nano_6thgen_User_Guide.pdf
    Regards
    Sep 14, 2011 | Apple iPod Nano 6th Generation MP3 Player
    96 mercury cougar xr7 fuel pump
    Check your local library for repair manuals...
    Nov 08, 2009 | 1996 Mercury Cougar XR7
    Fuel pumb Wire loose, need 2000 acur 3.5 RL fuel pump Wiring Diagrams
    buy a Haynes repair manual at your local auto part store.
    haves all electrical diagrams.
    Jun 03, 2009 | 2000 Acura 3.5RL
    I need a manual
    sir,
    http://support.apple.com/manuals
    at the above mentioned site you can find your required manual.
    May 23, 2009 | Apple iPod touch 1st Generation (8 GB) MP3...
    Briggs & Stratton 6200 Watt Electric Start Generator 30242 Logo
    419 people viewed this question
    Top Briggs & Stratton Electrical Supplies Experts
    John Trevino
    Falcon52
    Level 1 Expert
    Craig Butler
    Craig Butler
    Are you a Briggs & Stratton Electrical Supply Expert? Answer questions, earn points and help others
