posted by Kodiola on Jun 14, 2008
For a while now I've had this problem with booting my computer... When I turn it on it (a) turns off and on by itself, never loading windows (no matter how long you wait) (b) loads but the screen is all messed up and blurry, or (c) loads normally. Usually I have to turn it off and back on several times to get it to the last one, and I know that's not good for it.
I don't know if this has anything to do with, but the computer is also fairly new (just past the warranty!) and its running a bit slow... and if I close my computer after putting it in sleep mode or hybernate it and I open it back up I can't get the screen to come back on. I've checked with all sorts of virus scans and can't find one of those... any ideas on how to fix this?
Comment by Kodiola, posted on Jun 14, 2008
I'm sorry! I forgot to tell you what type of computer I had. Its HP Pavillion dv6000.... not a desktop... so sorry I didn't mean to make it sound like it was a desktop.
Best Solution
hi Kodiola,
There may be a simple problem is your Ram . it may be not connected well in the memory slot. Do you know how to connect it. I will tell you the trick for removing and restore it.
In the back panel of the cpu there are two screw first remove it. Remove the side panel. here you can see the mother board and all the components. There you see the ram with two or four slot. In the corner of the slot two knobs. just slightly press the upward to down on the both side of the slot . then it will remove the ram from the slot.then clean with the cloth not wet cloth. then put the ram on the slot. now switch on the system and see .
if the prob comes again please inform to fixya.com
bye kodiola.
bye kodiola.
Rating Locked! (?) Kodiola has rated this solution as Thanks for Trying
Suggest a new solution for this problem
Post a New problem for IBM ThinkPad T40 2373 PC Notebook
Email this problem
Email this problem
Can you Help with these PC Laptops problems?
Repair Service
Find PC Laptop Repairman Near You:
