Question about Motorola Talkabout T6500 (7 Channels) 2-Way Radio
We tried using a headset with it. Now, without the headset it goes back and forth between iVox and regular mode everytime you push the PTT button. Is there a way to stop it from going into Vox mode?
  • Motorola Master
  • 1,654 Answers
Here is a link to the user guide, reference page 22 for instructions on turning iVOX and VOX on or off: http://www.giantintl.com/ContentManage/manuals/Moto/T65xx.pdf (Double check you do not have the lock symbol showing while trying to change programming.)
Also, another phenomenon which can occur is when you unplug a headset or audio device while the radio is still turned on. This can leave the radio partially in VOX mode. You might try plugging in the device with the radio turned off. Then turn the radio on, use the device in VOX mode. Then shut the radio off and remove the device. See if it clears the radio's sense of having a headset plugged in.
A damaged jack can also cause the same problem.
Best regards.
Posted on Nov 05, 2010
Turn the Vox off completely and try it again. If it still happens, then it's a problkem on the board.
Posted on Nov 06, 2010
Active headset
Your headset is operating in VOX mode. This sometimes will happen if the headset is plugged into the radio when the radio is still turned on. Try unplugging the headset, turn on the radio, then talk using the PTT on the radio. Shut the radio back off. Then insert your headset plug, being certain it is seated (click) into place. Then turn the radio back on and see if it works without VOX. If you are still having problems, press the PTT on the radio one more time and see if it shuts it off.
Mar 12, 2014 | Motorola HMN9021A Dual...
Headset transmits automaticly
Puxing PX-777 PTT problem
It sounds like a PTT fault as presumably the headset has its own
ptt?
Try a reset?
Jan 25, 2014 | Radio Communications
We recently purchased the Motorola MS350 radios with headsets. We plugged the headsets in and turned the power on, but are unable to communicate back and forth in handsfree mode. We can switch to PTT and...
The three things which come to mind are:
1) Is the headset the VOX headset intended for the radio model? Sometimes the rings on the plug do not match the internal points of contact if it is not the intended headset. Not all headsets are VOX capable.
2) Is the headset plugged in all the way. (You mentioned plugging in and then turning on. This is good. You must always have the radio turned off when plugging or unplugging an audio device.)
3) Try pressing the PTT on the headset cord one time before switching the dip switch to VOX. (Assuming you have a headset with the small box in the line.)
Lastly, if you continue to have difficulties, contact Motorola at the 800# provided in the user guide. They should be able to assist you.
Best regards.
Sep 23, 2013 | Motorola Ms350r Radio Pack
We recently purchased the MS350 radios and are trying to use them handfree with the headsets. We plugged in the headsets, turned on the radios, but are unable to communicated back and forth using the VOX...
Check your VOX/ iVOX settings. You will need VOX for using an audio device.
Best regards.
Sep 23, 2013 | Motorola Hands-free Headset,for 2-Way...
How do you disable the VOX setting on a Talkabout MR350 2 way radios. I wan to use it with a headset, but do not want VOX on.
Here is a link to the user guide: http://www.giantintl.com/ContentManage/manuals/Moto/MR350-351%20User%20Guide%2012-16-08%20KEM-PK14190-90.pdf You will find the instructions for VOX and iVOX on the bottom of page one, and at the beginning of page 2.
Be certain when plugging in your audio accessory that the radio is turned off. If the radio is left on inadvertently, you would have no control over the VOX settings, it would immediately be in a confused VOX mode.
Also, with most Motorola radios, if VOX begins to occur, turn off the radio, and then re-insert the audio device plug. And in some instances, pressing the PTT on the radio when you are having a VOX occurrence will put the radio back to push-to-talk status.
Best regards.
Feb 19, 2011 | Radio Communications
How do I turn off the iVOX when I want to use it wit a Headset?
If they are Motorola's, Turn the radio off, and then plug the headset in, and then press the PTT (talk) button. This should turn it offf
Jun 26, 2010 | Radio Communications
ICOM IC-A6 Feedback type interference
The problem is caused by the microphone preamp in the headset demodulating the AM transmission. Sordin MSA headsets also have the same problem. What you require is a headset with no electronics in it and a dynamic microphone.
Mar 16, 2009 | Radio Communications
Motorola T5500 - Continuous transmitt with headset
1) Be certain the radio is shut off when plugging in the audio device.
2) On most units, press the PTT button to turn off the VOX feature.
3) If you are not planning to use VOX. Turn the VOX feature off. Follow the programming instructions which came with the radio.
Hope this helps.
Jan 15, 2009 | Motorola Talkabout T5500A (14 Channels)...
Motorola Talkabout T6500 (7 Channels) 2-Way Radio Logo
221 people viewed this question
Top Motorola Radio Communications Experts
eradiostore
eradiostore
SHARCNET-USA
SHARCNET-USA
Steve
Are you a Motorola Radio Communication Expert? Answer questions, earn points and help others
