Question about QMark MUH-35 Heater
How do i wire the q-mark MUH35 to a plug - QMark MUH-35 Heater
My plug wires got mixed up. Which wires go where on 92 olds cutlass ciera
Put engine on piston #1 TDC compression stroke and see where rotor points. Mark outside of distributor, reinstall cap and plug wire at the mark goes to cylinder #1. Going clockwise to next wire, follow firing order for each next plug. Shop manual gives firing order.
Jun 22, 2015 | Cars & Trucks
How do i hookup the what i think is the power cord to the computer its a round plug in
If it's a power cord, it doesn't plug into the computer; one end goes in the wall, the other into the speakers.
For most speaker pairs, there are 3 wires:
1) The wire that connects the speakers to each other. That's often fused into the back of the left speaker, and gets plugged into the right speaker (it's usually pretty well marked where to plug it in).
2) The wire that connects the right speaker to the computer. Usually it's pretty well marked where to plug this into the speaker. On the computer, that wire will fit into 2 ports. Usually those ports are marked with microphone and headphone icons. You want the headphone jack. If they aren't marked, try them both or check your manual.
3) The power cord. One end of that will plug into an electric outlet on the wall (or into an extension cord or power strip). The other end will plug into the right speaker; it should only fit into one hole (which will probably be marked with "12V" or "0.5A" or something like that).
It would help if you told us what kind of speakers you have, and what kind of wires you're seeing.
Mar 02, 2015 | Audio Players & Recorders
Wiring
if you mean the plug wires do the following. remove number one spark plug,turn engine over till you feel compression coming out of cylinder, find tdc mark on timing cover, turn motor over till mark on crankshaft pully lines up with timing cover mark, remove distributor cap, rotor now points to number one plug wire, check rotor rotation, firing order 4 cylinder motor 1324 6 cyl 153624.
Aug 16, 2014 | Cars & Trucks
Vintage singer 3 pole plug wireing
WIRE WITH COLOUR GREEN OR WITH SOMETIMES GREEN WITH YELLOW STRIPE IS THE EARTH WHICH HAS TO THE TOP ONE USUALLY MARKED WITH AN ANTENNA SIGN UPSIDE DOWN. BROWN COLOUR WIRE IS USUALLY LIVE WHICH IS MARKED IN PLUG AS (L) AND BLUE COLOUR WIRE IS NEUTRAL USUALLY MARKED IN PLUG AS (N).
IN CASE THE COLOUR DIFFERS OR ELSE THE PLEASE INFORM SO THAT WE CAN REGUIDE YOU.
Aug 31, 2012 | Sewing Machines
Hi im putting in a JVC cd/radio in a 1997 ford escort TD,Ive removed factory fitted Ford radio cassette,leaving 5 wires connected to a yellow plug,I have 3 wires coming out of JVC marked yellow memory back...
hi...well i know this might not be of any help, but you can buy a connector that plugs straight into the ford plug, and then you plug the jvc plug/s into that, not cutting wires no messing up the original connector just incase you want to sell the car with original system in it... http://productfinder.autoleads.co.uk/productinfo.aspx?&m=FORD&f=ESCORT&id=463&pID=6889
thats the link for it...if you tell me what colours are on the ford plug i could tell you what goes where...thanks
Feb 04, 2011 | 1995 Ford Escort
Disconected spark plug wires and cant rember where the wires atach to distrubted cap on my 2000 s10 blazer v6
The cap is marked. look at the top of the cap where the wires are attached. they are numbered.
Oct 13, 2010 | 2000 Chevrolet Blazer
There is a misfire in my engine, changed plugs & wires. now it reads that the fuel leveling sensor is bad, will this help?
If there is a misfire, the cylinder that it is misfiring in will be recorded as a code in the computer.
Have the car scanned to determine which cylinder is bad. Then, replace the coil pack going to that cylinder.
Ignition Coil Pack Removal & Installation 2V Engine To Remove:
  1. Twist the spark plug wires off of the ignition coil towers. Mark the spark plug wire positions so they can be installed in their original positions.
  2. Disconnect the electrical connector from the ignition coil. CAUTION
    When removing the spark plug wires, a slight twisting motion will break the seal and ease removal.
  3. Remove the mounting screws and remove the ignition coil.
To Install:
  1. Position the ignition coil pack on engine.
  3. Connect ignition coil pack electrical connector.
  4. Match previously marked spark plug wires to ignition coil and install.
4V Engine To Remove:
  2. Remove the screws and the water shield
  3. Mark spark plug wire positions
  4. Disconnect the spark plug wires from the ignition coil CAUTION
    When removing the spark plug wires a slight twisting motion will break the seal and ease removal.
  6. Remove the mounting screws and remove the ignition coil
To Install:
  1. Position ignition coil pack. Install mounting screws and torque to 56 in-lbs. (6Nm)
  2. Connect ignition coil pack electrical connector
  3. Match previously marked spark plug wires to ignition coil and install
  4. Position water shield and install screws
  5. Install RH cowl panel
Aug 11, 2010 | 2002 Ford Taurus
Need help with the wiring on the reddy heater 110 btu
CIRCUIT CARD-
-Photocell blue wired go to two terminals marked BLUE PHOTOCELL (any order)
-Motor red wire plugs onto terminal marked MTR MAIN, motor white wire plugs into terminal marked WHITE MOTOR.
-potentiometer (thing with knob) two white wires plug into terminals marked TEMP SEL
-Black wire from switch to terminal marked L1 BLACK
-White wire from power cord goes to terminal marked N White
-Ignitor (used to be yellow wires) goto terminals marked IGNITOR and IGNITOR RET (any order)
OTHER-
-White wire from power cord goes to switch terminal marked 3A , other pigtail of the white wire goes to board as described above.
-Black wire from power cord goes to swtich terminal marked 4B
Nov 14, 2009 | Reddy Heater-170,000 BTU Kerosene Deluxe
Which plug goes where in dist. cap
I think your firing order is 1-3-4-2.
Your plug-wires must connect in that order!
The longest plug-wire goes to #1 point
already marked on cap. The other longer wire
is for #3 point-marked on cap......
The #1 cylinder (longest plug-wire) is nearest the timing belt-sprocket.
Oct 29, 2009 | 2001 Nissan Altima
I have a Mustang GT convertible with the Shaker 1000 system. I'm installing a Kenwood DNX8120. There are 3 plugs in the back of the factory radio. I only have 2 plugs that will match the factory plugs. one...
a savvy installer can make a circuit using your garage remote (installed in the dash) or some wireless lights (with remote) and with the push of a button, your (insert item here) will function.
Depending on the voltage required, one is really just a ground, and the other is a positive trigger.
It requires a SPDT relay, and if the remote is not 12V, a resistor of the right value to lower the voltage.
Jan 14, 2009 | Kenwood Car Audio & Video
QMark MUH-35 Heater Logo
59 people viewed this question
Top QMark Heating & Cooling Experts
Paul Carew
john h
Bill Boyd
Are you a QMark Heating and Cooling Expert? Answer questions, earn points and help others
