Question about Mitsubishi VS-50705 50" Rear Projection Television
Other parts By looking at the board, that entire corner of the board has that stuff on it, but only on the top. It did not get to bottom side. I was going to try and clean it, I have some cleaner in a spray can thats made for circuit boards, what do you think?
  • Mitsubishi Master
  • 8,617 Answers
The cleaner will work. but the liquid if its CRT coolant, and in that model I would bet that it is. Coolant is corrosive so i would at least heat the solder on those components just to evaporate any coolant that has seeped dow the components legs as it can and will eat at the pin/solder connections.
Posted on Jun 14, 2008
Water won't drain. the washer has worked fine for 7 years
Sounds like your lid switch is broken. This is located under the top of the washer and is activated by a tab that hangs off the side of the lid.
Accessing this part requires you to flip up the control panel by removing two phillips head screws in either the front bottom corners (may be behind the end-cap covers), or rear bottom corners, pull panel forward and lift to disengage the tabs at the bottom. Flip the panel upwards and it will swing back out of the way.
Next you will see one wire connector going into the top of the machine, this is actually your lid switch connector, disconnect it. Now using a flat screwdriver pry the front of the two brass clips towards the rear of the washer (put tip of screwdriver into front most part of clip and press handle of screwdriver towards rear of machine). The clips should pop off the top pretty easily.
Now you can open the lid and place a hand on the front of the opening and pull the cabinet forward. The entire front and side wrapper will come off the base platform and you can set it on the floor to gain access to the lid switch that is screwed to the underside.
Good luck to you on this!
Jul 03, 2010 | Kenmore 22422 Top Load Washer
After washing it stops and does not spin or rinse
Jul 03, 2010 | Whirlpool Ultimate Care II LSQ9549L Top...
My washer, kenmore 90 series can agitate and complete washing cycle but will not drain and spine.
Accessing this part requires you to flip up the control panel by removing two phillips head screws in either the front bottom corners (may be behind the endcap covers), or rear bottom corners, pull panel forward and lift to disengage the tabs at the bottom. Flip the panel upwards and it will swing back out of the way.
My Whirlpool Ultimate Care II will not spin drain. It agitates and washes but I have to remove the clothes and rinse the by hand, and the water remains in the machine. please help. Thanks
Sounds like your lid switch is broken. Part number 8054980. This is located under the top of the washer and is activated by a tab that hangs off the side of the lid.
Accessing this part requires you to flip up the control panel by removing two phillips head screws in either the fron bottom corners, or rear bottom corners, pull panel forward and lift to diengage the tabs at the bottom. Flip the panel upwards and it will swing back out of the way. Next you will see one wire connector going into the top of the machine, this is actually your lid switch connector, disconnect it. Now using a flat screwdriver pry the front of the two brass clips towards the rear of the washer (put tip of screwdriver into fron most part of clip and press handle of screwdriver towards rear of machine). The clips should pop off the top pretty easily.
Jun 26, 2010 | Whirlpool Ultimate Care II LSQ9549L Top...
Side by Side not cooling
There are a few reasons why the refrigerator part will not cool...here are a couple of tips that will help you to figure out why the refrigerantor is not cooling...
Refrigerator2_bing.gif not Cooling or Fridge not Cooling
http://www.fixya.com/support/r3662945-refrigerator_not_cooling_or_fridge_not
How to Defrost Refrigerator Defrost Timer Problem
http://www.fixya.com/support/r3771673-defrost_refrigerator_defrost_timer
heatman101
Jun 25, 2010 | Refrigerators
Ice dispenser door flap will not close completely. I'm sure something has sprung or broke inside the door. How do I get the face off to look at the mechanism that opens and closes the door?
Remove the top freezer hinge hover on top of the freezer door . Unplug the receptical there ( this will remove power to the door only ) .
Using a small screwdriver at the "crease" on the bottom of the dispensor control board inside the dispensor , twist slightly to disengage the 2 clips ( 1 on each side ) holding the dispensor board . Unplug the 3 connectors from the board . 4 screws ( 1 on each corner ) hold the dispensor housing shield . Remove these 4 small screws . After removing , at the top right , you will see a solenoid and plunger . These are probably rusted , holding the flap open . The part number for the solenoid and plunger is WR62X10055 . 3 screws hold this part on . When reinstalling the dispensor housing , It slides back on 2 "grooves" so make sure it is back in place , or the board will not snap back on properly at the bottom .
Sep 01, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Need to open the bottom part below the door, ideas how to get in there??
Unplug. Remove 2 screws @ lint filter. Pull forward on top one side at a time and lift up each front corner - entire top will hinge upward. Remove switch wires at front and 2 5/16 screws. Pull front up and out. Hope this helps!
Mar 09, 2009 | Whirlpool LER4634J Electric Dryer
Compaq Presario R3000 Sound card follow-up question
The sound board is connected to the mainboard by a connector and contra-connector, both soldered to their boards.. If you want to do it right, you will have to remove several screws from that bottom corner and left side, under the battery too, so that you can lift up the mainboard's corner (gently!) a bit, and put in back in place firmly. It is located just above the top left side of the battery compartment, when looking at the bottom with the front toward you. A more durable option is to take the bugger apart, and put washers max. 1mm thick under the soundboard to get a better snap-in on those connectors.
Jan 03, 2009 | Compaq Presario R3000 Notebook
Corner screw missing, causes leaking also, the washer arms on top and bottom have clogged holes, where can I get a part to open them up to clean them out?
the wash arms don't come apart you can knock the stuff out of them and clear the holes with some thing small and pointed.
as for the corner screw issue I need more info what corner what screw are you talking about?
Apr 24, 2008 | Dishwashers
Replacing battery in a Navman 570
the 2 screws and then its hookeby plastic clips be careful cause clips break easy
you need a very fine flatblade screwdriver
richard from chicago
Apr 01, 2008 | Navman PiN 570 GPS Receiver
Mitsubishi VS-50705 50" Rear Projection Television Logo
27 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
