Question about GE (PSS26MSRSS) Side by Side Refrigerator
My GE side by side fridge door swings all the way open and hits my counter next to it. It progressively has gotten worse over time. Is there a "stop" that is bad or just a hinge issue?
  • GE Master
  • 2,699 Answers
There are door stops that snap off on the bottom of the door,the part number is WR02X10782 and they're like 8 bucks,two screws hold it in place
Posted on Nov 05, 2010
Home Depot lists a depth dimension for a GE refrigerator. Is the handle included in the depth dimension?
no. depth is measured from the back of the box to the front of the box but does not include the handles. The depth of the cabinet is used to determine if the doors will open sufficiently to clear countertops and half walls or appliances. Also helps determine if enough space will be available to open doors in small kitchens such as "c" shape, "L" shape or narrow galley kitchens. for small kitchens, the best frig is a side by side. The doors are smaller and less swing space is needed. A 25 cubic foot side by side uses less swing space then a 15 cubic foot single door. If you are worried about depth, you can also get a counter depth frig which will stick out past your countertops by about 2 inches rather then 8-10 inches with a standard frig. standard depth is about 28-36 inches from the back wall when plugged in. Handles get in the way most often in width measurements because they prevent the doors from swinging past 90 degrees if located next to a wall.
Dec 18, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
Hello! My side by side Fridge door won't stay
sir i have a problem my flash player run very slow
Apr 19, 2010 | GE Refrigerators
GE Side by Side Frig Door Flies Open to Far
Look under the front of the fridge, should be some adjustments to raise and lower the wheels or feet for leveling. Level it with a level on the top, should help keep the doors from swinging.
Sep 13, 2009 | KitchenAid KSCS25FKSS Side by Side...
Fridge door hits counter
as long as its not over 20 lbs on the door you will be ok
Aug 12, 2009 | U-Line Origins 1175R Refrigerator
The refrigerator door swings open without resistance and hits the counter behind the door
Hi, Check the hinge cam and closer kit on the bottom hinge. See if there are any cracks or even part of the cam mising. They have a tendency to wear sown through the years. If this loks like the problem, please let me know and I can get you part #'s for you.
Vid
May 23, 2009 | Refrigerators
Doors don't swing shut automatically
The GE side by side refrigerator has 2 cams on the bottom hinge that helps shut the door. If the cam wears out then the door will not close properly. One of the cams is riveted to the hinge assembly and an extra cam is shipped with it. The cam assemblies can easily be replaced by using the information on the Partselect.com website that refers to the GE TFX22R refrigerator.
Apr 25, 2009 | GE GSH25JSTSS Stainless Steel Side by Side...
My GE frontload washer "jumps around" the room.
Plug off the mains. Open up the machine to look for defective shock-absorbers, broken springs, etc. You shd have done this much earlier, surely you're not walking around the house with a helmet.
For spares:
RepairClinic.com (which is good)
espares.co.uk
AppliancePartsPros.com
Mar 01, 2009 | GE WSXH208A Front Load Washer
GE Side by Side Fridge Door Adjustment
Most refrigerators do not have anything to prevent the door from opening all the way. To minimize this , adjust the front leveling legs up enough so the door won't stay open by itself. The refrigerator doesn't have to be level, it just should not rock. Most are adjusted this way to let the door shut itself. This should help. If this doesn't work. make a strap with small chain or seat belt type material. Attach from the bottom of the door. Make it just long enough to not let the door open past 90 degrees.
Jul 02, 2008 | GE Refrigerators
Counter depth refrigerator
Do you have room to pull the fridge out from the wall, maybe just a couple inches? Pulling it out from the wall should give you more door swing without hitting the counter.
Let me know if this works for you.
Thanks,
Bill
May 16, 2008 | Refrigerators
GE (PSS26MSRSS) Side by Side Refrigerator Logo
241 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Randy Justice
