Question about Black & Decker BDDP100 10 IN. DRILL PRESS 1 EA 4250536
I can't, for the life of me, find out how to switch out drill bits. can someone help asap?
  • 5,603 Answers
You should have been supplied a "chuck key" which you engage and rotate the barrel of the chuck which releases the drill bits or tightens them. If you did not get the key (it looks like a bevel gear with a "T" handle) you will need to get one.
Posted on Nov 05, 2010
Testimonial: "thanks!"
    New Friend:
And it stores in the plastic U clip mounted to the right side of the drill up near the cowl
Posted on Dec 02, 2013
Cordless sds leaving grease on sds bits
There is supposed to be grease on the chuck end of SDS+ and SDS Max bits. Actually, you should put a little lightweight grease on the end of the bit every time you put one in your drill. If you, or noone who has ever used the drill, have ever done this, it is possible internal grease is leaking out of the drill and it should not. There are seals to prevent internal grease from getting out of the transmission and striker mechanisms. If you are loosing internal grease, these seals should be checked.
Feb 14, 2013 | Dewalt DW005K Rotary Hammer
I have a bolt broken off that someone tried to drill out and now i have to find something that will drill through a broken drill bit help?
You can not drill thru a broke drill bit,it is hardened
steel.
Have to try & chip it out first
If you get to a point where you have drilled some & have
a hold on it, heat the spot some & try a short left hand drill bit
to turn it out
They are avail at tool supply stores
Jan 30, 2013 | Chevrolet 3500 Cars & Trucks
Husband is out of town so how do you change the drill bit on the porter cable keyless chuck drill?
Switch drill to reverse, grab drill head tight, do not grab bit, pull trigger, chuck will open, switch to forward center new bit hold head tight pull trigger. Make sure bit stays in center, Let me know if this helps.
Aug 21, 2011 | Porter Cable Garden
I have a DEWALT DC920 drill-driver and have a bit stuck in the chuck. The chuck adjuster appears to be stripped. Need to remove the bit and replace the chuck. Any ideas on how to get the bit released?
try tapping on all sides of the chuck lightly with a hammer and wiggling the bit... you can also try to spray some oil into the chuck and see if that loosens the bit for you... You can also clamp the bit in a vise (or get someone with a pair of pliers) and pull, that will sometimes do the trick.
Apr 04, 2011 | Dewalt 18 Volt Compact Drill Kit
I have a de Walt 14.4 v XRP drill and cannot for the life of me change the drill bit! cheating Ex husband took the drill i am used to and cannot get this drill bit out! LOL help!
Assuming that the chuck has no gear teeth for a chuck key, put a leather glove on one hand, grasp the outer chuck case with drill set for reverse, and apply power which should loosen the chuck. Normally, you just grasp the outer chuck and turn it in a CW (looking at it from the handle end) direction to loosen. Hope this helps!
Oct 24, 2010 | Garden
A bit is stuck in the chuck of my Bosch drill
Hello. Wrap a towel around the chuck and use a pipe wrench or a pair of channel locks to put a little force on the chuck. J.
Jul 19, 2010 | Bosch Drills
Hi, I have 14.4v B&D drill - I for the life of me cannot unscrew the front of the drill to insert my drill bit. It is is just soo tight & not sure how this has happened! Can you help in how i can...
If this model has a keyless chuck use a plumber strap wrench to crasp the chuck. this will give you suficient leverage to open the chuck. Remember to loosen turn left,turn right to tighten. " Lefty loosey, righty tighty". You can use inexpensive rubber strap wrenchs.
Feb 14, 2010 | Black & Decker 14.4v Cordless Lithium...
The ignition switch is damaged and I need to replace it. Someone attempted to drill it out and the drill broke off in the lock, so the key can no longer be inserted.
Do not drill out there is a pin hole in the side of the switch visible after removing the covers around the swithch you may need to remove the steering wheel I never had to turn the ignition swith to on position and then put a pin or small drill bit in the pin hole push in on it and then simultaneously pull out on the chrome key tumbler wiggle it abit while pushing in on the bit to remove center tumbler assembly/contacts.
Aug 03, 2009 | 1993 Ford Bronco
Drilling a 1 3/4 x24" deep hole in rock . i wore out a dewalt rock carbide dw5830 after just two holes. what should i be using. thank you
I'm a fan of bosch bits and equipment! but try slowing your drill down a touch and even use a little water this will help the life of the bit!
Jun 06, 2009 | Black & Decker 3/4x6" Rock Carbide Sds...
Changing bits
Without a model number I am guessing but you should have to either pull back on the outer collar or push forward to release the bit in the hex driver. If this doesn't work give me the brand and model number and I will find a user manual to look at and let you know where you can get it.
Feb 09, 2009 | Black & Decker Pivot Plus Cordless...
Black & Decker BDDP100 10 IN. DRILL PRESS 1 EA 4250536 Logo
196 people viewed this question
Top Black & Decker Drills Experts
JOHN LAPIER
Marvin
Marvin
Robert Monigold
Robert Monigold
Are you a Black & Decker Drill Expert? Answer questions, earn points and help others
