Question about Creative Labs Zen Touch MP3 Player
Mp3 problem zen mp 3 played has a broken button. It still works but not for long. How can i get it fixed. Bill
    President:
  • 4,402 Answers
Http://serviceman.site88.net/index_files/MP3Players.htm
Posted on Aug 05, 2008
I can't open my zen v plus and it always light up and there's no start up screen
Can it still play music if you press play after it lights up?
Can you still connect it to a computer?
This sounds like a dead screen, which means it is time for a new player.
Jan 03, 2010 | Creative Labs ZEN V Plus MP3 Player
I/O error in creative zen mp3
Hi! I think you should try this (i've already tried it and it works):
1- Unplug your Zen from your Computer.
2-Turn off your Zen (if you can't do it, press the "Reboot" button)
3- BEFORE turning on your Zen, press your "Play" button and hold it while you turn on.
4-When a format menu appears, select the "Format All" option (you'll loose all your Zen data).
5-When the format menu reapears, select the "Reboot" option and listo! You have your Zen as new and should not have problem. Good luck!
Feb 26, 2009 | Creative Technology ZEN Stone MP3 Player
My Zen Mozaic 8GB does not turn on.
I had the same problem, you have probably already tried this but I pressed the reset button (felt like a right plonker, but it did work) I just forgot it waas there!
Jan 11, 2009 | Creative Labs Creative Technology Zen MP3...
FM Radio was erased from the MP 3
OK this seems to easy a fix for you, but try it.
* In the main menu where it lists your options (and where FM Radio would be) press the 'Menu' button on your Microphoto (bottom right button) and there is an option to 'Configure Menu' and in there should be the option to show FM Radio again. Hope that helps you.
I have a similar, but different problem, so ill list below, maybe it will help someone out.
i also replaced the (broken) 8gb microdrive with 8gb compact flash in my Zen Microphoto, which worked flawlessly! BTW i bought the A-Data 'SPEEDY CF 8GB' from newegg.com.
My FM Radio still shows up, but only gets MONO sound on the Right channel, its very frustrating. i took it all apart again and made sure no connections were loose or broken, but everything seems perfect. i believe it to be a firmware issue, i think ill try to roll back the drivers. im using firmware 1.31.01.
its just annoying to have to roll back to Media Player 10 everytime just to install the firmware and have windows properly communicate with the zen... :[
Nov 20, 2008 | Creative Labs Zen MicroPhoto MP3 Player
My Zen is Really Broken!
http://serviceman.site88.net/index_files/MP3Players.htm
Jun 29, 2008 | Creative Labs Zen V MP3 Player
Creative zen mp3 help please
You will need to put the Zen into recovery mode and erase the firmware, then reload the firmware. Follow these steps:
To Erase the Firmware:
1. Get a paperclip and straighten it out.
2. Hold down the Play/Pause button, and put the paperclip through the reset hole. Release the paperclip while continuing to press the Play/Pause button until you see the screen change.
3. Select "Reload Firmware."
To Load the new Firmware:
Go to www.Creative.com/support --> downloads. Click through the navigation and download the latest Zen Touch firmware. Reboot your computer, then plug in your Zen via USB cable. Double-click the firmware icon and then click upgrade.
Apr 02, 2008 | Creative Labs Zen Touch MP3 Player
Blank screen
If your Zen V is dead, wont respond to anything, try this, plug it in to the computer, hold the power switch in the on position, THEN trigger the reset button, worked like a charm for mine, I had thought it a lost cause."
Q. How to reset Zen v +
http://www.youtube.com/watch?v=22T_gkkZjmM&feature=related
Feb 07, 2008 | Creative Labs Zen V MP3 Player
Creative Labs Nomand Jukebox Zen Xtra
Zen Nomad Xtra - to go to Rescue Mode do the following:
1. Insert a pin into the small hole on the left side of the player
below the volume adjustment switch.
2. Hold down the Play button on the right side of the switch
3. Rescue Mode Menu will appear
4. There are 4 Options available, but best option to fix most
problems is reformat hard drive.
5. Reformat is very fast
6. Turn off and reboot.
7. Problem solved.
Oct 31, 2007 | Creative Labs Nomad Jukebox Zen Xtra MP3...
Creative Zen Sleek Buttons dont Work
I gave it a whack on the back of the MP3 player out of frustration, and lo and behold! it works fine! i don't think this is a very orthodox method, but i'm a bit happier now! I wouldn't recommend this as an everyday method of fixing it, but it's helped me.
Oct 29, 2007 | Creative Labs ZEN SLEEK MP3 Player
Creative Labs Zen Touch MP3 Player Logo
54 people viewed this question
Top Creative Labs Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Mohamed Ismail
Mohamed Ismail
Are you a Creative Labs Audio Player and Recorder Expert? Answer questions, earn points and help others
