Question about KitchenAid (KSRD22FKST) Side by Side Refrigerator
Kitchen Aid indoor ice maker
Hi:
I have a Kitchen Aid refrig , with a indoor ice maker . The type that you push a glass up against the lever , and ice fals into glass . I am not the best at mechanical fix-its .
What happened is a part fell into the glass when getting ice .
Its a small wheel with a 1 1/2" long plastic arm attached , the end of the arm has a hole in it .
The part does not look broken , only fell from place its supposed to be . The flapper door , that seals the hole from where the ice comes from seems loose now .
Can you help ?????
I appreciate it !
thebeeper@cox.net
Dave
  • ratava Jul 10, 2008
    The ice maker flapper fell out with a spring and pin.
    I tried to put it back in but it is too small a space.
    I need to know a safe way to remove the black plastic frame on the door to be able to access this space.
    Sergeant:
  • 409 Answers
i would recommend a technician to help you with this. this part that fell out is from the motor head off the icemaker. have the technician put it back together and make sure that there is nothing else loose.
Posted on Sep 17, 2008
My KTRC22E kitchen aid refrig. stopped making ice. I replaced the valve that ties into ties into the cold water line. The drinking water in the refrig is working properly. I'm told it may be th
sounds like you have a problem with the fill tube at the Ice Maker. remove the IM and then the back wall ( evaporator cover ) , the fill tube is probably frozen. use a hair dyer to melt ice, be careful, the hair dyer can melt the fill tube and other plastic.
Jan 07, 2012 | KitchenAid KTRS22EM Top Freezer...
Icemaker is not working in my kitchen aid superba
Hi, If your ice maker has stopped working then you need to check these things.
The lever that controls the ice maker has been pushed up which turns it off. If you have a red lever, pull it down to the wire and if you just have a wire then just pull down the wire to start your ice maker up.
Make sure the freezer temperature is below 10 degrees F If the freezer is too warm ice production will be poor because the ice maker will not cycle properly.
The ice maker fill tube may have ice formed in it, blocking it. Use a hair dryer to melt the ice. Watch out for the plastic parts, so that you do not melt the plastic. Also check the water inlet valve and the shut off valve, to make sure it is not plugged with debris. The openings in those valves are very small.
Check the gears in the ice makers to see if they are broken or stripped. Also look to see if the ice rake is broken.
All parts in the ice maker are replaceable individually, If you find broken parts replace them.
Take care
Jul 23, 2010 | KitchenAid Refrigerators
My water line in my Kitchen Aid side by side refrig is not working. No it is not a frozen line as I checked for that. I stopped getting water after someone shoved a glass real hard in the water dispenser.
Hello. Apparently that glass broke the lever which is actually controlling a valve, so the valve may be what is actually broken. The only fix would be to call your local large appliance repair person. Hope this helps you.
ps - kindly rate my answer as helpful.
Feb 23, 2010 | Refrigerators
Kitchen Aid refrig. Won't put water into the ice m
Hi Dan,the plastic hoses are removed by pushing up on the "ring"around the hose at the inet and pulling it out.
Nov 15, 2009 | Refrigerators
Kitchen aid top shelf warm
  1. check gasket
  2. check the light switch on top of the refrig. section. If then pushed the switch turns the light off, but the light is still on with the fridge door closed - door needs adjustment.
Oct 13, 2009 | KitchenAid KSS48QM 48" Built-In...
MY KITCHEN AID KSRP25FNSS ICE MAKER IS NOT WORKING
Here is a tip that I wrote about the reasons why ice makers do not work.
Ice Maker Problems and Ice Maker Troubleshooting
heatman101
689fr
Jun 09, 2009 | KitchenAid Superba Architect KSCS25INSS...
Kitchen Aid Super Ba refrig..water dripping from water spout !
To stop the dripping now, turn the water off.
The problem is there is either mineral caught in the seat of the dispenser valve, or the dispenser valve seat has a bad place in it. Removal and cleaning/replacement is required.
Jan 18, 2009 | KitchenAid Superba Architect KSCS25INSS...
Kitchen Aid KSRP25F Ice Maker
The ice maker is not working, no ice ice is coming in the tray on my Kitchen Aid KSRP25F Refridgerator, the red light keeps on
blinking
Del
Dec 05, 2008 | KitchenAid Superba Architect KSCS25INSS...
Icemaker doesn't work - no ice ejected
Krakus, there is no fuse in the dispenser assy., but there are two switches mounted on the control bracket. The posts on the brackets that hold the switches are really thin and it's possible that it broke. Therefore when you are pressing the lever you are not making the switch and sending the juice to the auger motor. Remove the dispenser cover by inserting a flat blade screw driver in the slots at the bottom. Pry out gently and the cover should pop off. Then slide it up and off. Now you will be looking at the control bracket and see the switches on the left and right side. See if the switch holder is broken. If this is the case your part number is 2183771. Not a hard job, just have to take your time. Im assuming that when you tested the auger motor you verified that the drive coupler was not broke. Catriver..post back
Dec 18, 2006 | KitchenAid KSCS25FKSS Side by Side...
KitchenAid (KSRD22FKST) Side by Side Refrigerator Logo
205 people viewed this question
Top KitchenAid Refrigerators Experts
John Tripp
John Tripp
rugby prop
Lawrence Oravetz
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
