Question about DURATRAX Evader Electric Truck
Frontwheels will move but back wheels dont budge
Did you get a small hex tightener with yours?
if so loosen the rear wheel nuts until it turns easily but not too much so it wobbles around
Posted on Jan 07, 2011
Got hit from the left side but theright frontwheel was the one tilted towards insideof the wheel well can it be the stable lizers
it can be any part of the front suspension or brake system including drive train damage jack up right side and with wheel still on place hands at top and bottom of wheel and push and pull in and out if movement usually a ball joint but ball joints dont give off a grinding noise ===now grab tire at the 9 and 3 position front and back -push and pull if loose possible tie rod damage or steering component damaged this also doesnt give off a grinding noise unless bent into a turning part =====turn wheel and listen and look at cv axle and around brake area if noise remove wheel and now inspect brake caliper ,brakes ,hub and axle for noise these components can give you your grinding noise repair or replace damaged components the other tests performed were for possible damaged parts since wheel was bent inward
Apr 09, 2014 | 2005 Ford Taurus
98 Chrysler Town & Country Ignition, steering wheel & gear shift are all locked up. Last night we stopped to get some fast food. When we came back out to the van, it would not allow us to move...
Sometimes the mechanical system that locks your steering wheel has too much vehicle weight which can prevent the key from turning. If you can move the vehicle back and forth while someone turn the steering wheel and turn the ignition switch.
Jun 27, 2017 | 1998 Chrysler Town & Country
When i put the key in the ignition i try to start the car but it wont budge its like locked up in one spot which is all the way to the back. So when i try to move it around while moving the steering wheel...
take a flashlight and look into the lock and see if the tumblers are loose ir have worn out. try a lil bit of w-d 40 or something and see if the wheels are straight if not, try to pull the wheel in the direction of the wheels and then try it. sometimes if they get into a bind they are a pain... also, check to see if the vehicle is in park or neutral
Mar 10, 2011 | Pontiac Grand Am Cars & Trucks
I have a 2000 kia sportage and the steering wheel wont budge and the key wont turn. I called kia and they told me to yank the wheel to the right and turn the key at the same time.....nothing. the car is...
well hate to be the bearer of bad news but that is exactly what needs to be done. try turning the key and forcefully moving steering wheel from side to side. if needed get someone to help you moving the wheel but you must be turninf the key at the same time in order to unlock. this is common and happens when you turn the wheel while key is in the off posoition or out of ignition, perhaps grabbing on steering wheel while entering or exiting vehicle. good luck.
Jan 15, 2011 | 2000 Kia Sportage
Craftsman 6.0 lawnmower frontwheel drive won't engage .
Make sure the belt has not slipped off of the pulley on the engine output shaft just above the cutting blade. It is common with those type of drives for debris to make the belt hop off.
Jun 02, 2010 | Garden
Check frontwheel drive light is on. Where do I
this is most likely the switch. use a test light to check it and also check to be sure the plug is connected properly. The plugs will come loose if jard. If you find the swicth is bad, you can get them almoct any place, i have seen the even on Ebay.
Mar 13, 2010 | 2000 GMC Jimmy
Noises coming from th left frontwheel of my 2000 hyundia sonota could this be a hub and bearing noise
What kind of noises are you hearing? Most likely, you need to replace the brakes. It is very unusual for a 10 year old car to have wheel bearing problems, especially on the front wheels.
A squeal when you apply the brakes or a grinding/dragging noise while you are driving are signs that it is time to replace the brakes.
Jan 30, 2010 | 2000 Hyundai Sonata
Car makes noise from front wheel when going round corner
Frontwheel Dive CV joint is going out. Starts out as a clicking sound in turns. Will eventualy break
leaving you stranded. Requring tow fee Plus repair.
Repair usualy around $350.00 to $400.00
Sorry for your trouble.
You can also check by finding lagre parking lot turning wheel hard i backing up. Wheel one side then do the other dirctrion you will hear poping/clicking sound.
Mar 08, 2009 | 1997 Ford Escort
DURATRAX Evader Electric Truck Logo
73 people viewed this question
Top DURATRAX Toys Experts
Marvin
Marvin
Andrew Taylor
Andrew Taylor
ray gallant
Are you a DURATRAX Toy Expert? Answer questions, earn points and help others
