Question about Panasonic Televison & Video
I bought a model # PV-DC152D brand new about 6 yrs ago. It has worked flawlessly untill today. I tried to play a tape and got bold red warning on screen to "PRESS THE RESET BUTTON!" That done, no immediate change occured other that another bold red warning stating "THE CAMERA NEEDS TO BE SERVICED!" What is this all about. I tahnk you for you kind, expidiate, and helpful solution for this problem in sdvance. Sincerely, W. David Killingsworth, R.N., L.N.C.
    Master:
  • 497 Answers
Youl have to get it seviced and contact ur cutomer care right away...
Posted on Jun 14, 2008
    Guru:
  • 1,894 Answers
I think ur camera firmware has got damaged
  • dewan nafees ahmed Jun 14, 2008
    the reset button was said to press because
    "so that the unit shall recover from the problem its software was facing.
    and in and u pressed it.
    the camera in an attempt to correct the solution has damaged the software inside it.
    you can try few solutions
    ---try updating the firmware
    ---try a hard reset
    ---try flashing the memory
    if all this fails then u have only one go.
    get the software reinstalled by the service center.
    this is what i would suggest you.
    thank you
    dont forget to accept the solution if u go by it.
    have a good day.
    good luck
My vcr plays commercially-recorded tapes fine, but tapes recorded on it or another VCR play with the sound distorted. The picture seems fine.
Sounds like its mechanism need some alignment. Guide pole alignment. Contact any service technician. This is technically skilled work. http://electronicshelponline.blogspot.com/
Jul 18, 2015 | Panasonic Televison & Video
When camcorder is turned on the screen shows red or yellow screen
I have the same problem of picture distortion when recording on my PV-GS200 camcorder. It's due to a faulty CCD block, which you can read about on various websites. I can play back pre-CCD failure tapes without a problem. Panasonic recalled quite a few GS200 camcorders with specific serial numbers in the US and Canada, and replaced the faulty 3-CCD chip free of charge. I just discovered this tonight and intend to ring Panasonic tomorrow, as the camcorder - bought new - lasted only two years before the CCD fault became apparent. Obviously, the camcorder was not of merchantable quality.
Jan 27, 2009 | Panasonic Palmcorder PV-GS200 Mini DV...
Re: Model PV-4523S
You can try cleaning it with a VCR tape cleaner to see if the pinch roller have build up on there. It could be that the motor isnt feeding the tape up against the recording heads properly and may need an adjustment. If you can take the top cover off, you should be to see what the problem is by the way the tape is being inserted into the machine.
Jul 29, 2008 | Panasonic PV-V4021 S-VHS VCR
Red power light flashes twice and unit will not record. I will not play a tape, none of the tape keys work (rewind, fordward, or pause, etc). I do get a picture in both the vcr and camera mode but the tape...
That is caused by leaking capacitors. Not a lot the layman can do about it except purchase a new camcorder or send it to Panasonic for repair, if not obsolete.
Apr 23, 2017 | Panasonic Palmcorder PV-DV52 Mini DV...
Playback problems - timer stays at zero
Firewire transfer problem with PV-GS320. HAd bought the PV-GS90 and ran into significant transfer issues importing to Mac (iMovie and Fincal Cut Express HD both had problems). Upgraded to GS320 as Macworld rated it highly. Same problems: video plays back perfectly with no computer connection. once connected, video and audio stutter, go out of sync, sometimes just stop and/or crash the program.
I've used a borrowed Canon GL with this Mac before with no issues, so I suspect the camera. Have tried reset button, trashing preferences, restarts, the works. still can't get clean video to transfer from a brand new camera. Any Ideas?
Feb 09, 2008 | Panasonic PV-GS320 Camcorder
1. Take out the tape - AND TURN THE CAMERA POWER ON
2. press the menu button (near the viewfinder)
3. Use he wheel on top next to the viewfinderto scroll through the choices
4. Choose "display setup" by pushing the wheel in
5. Choose "C. Rest" by pushing the wheel in
6. Turn camera off
7. Next time you turn camera on y ou should be able to view tapes and record.
IT DID NOT WORK THE FISRT TIME SO I PUT MY FINGER IN TO TRY TO GENTLY PUSH BUTTON WHEN I TOOK THE TAPE OFF AND THEN TRIED SOLUTION ABOVE AGAIN, AND THIS TIME, IT WORKED. BUT PLEASE DONT INSERT YOUR FINGERS IN AS I DID TRY THE SOLUTION 2 OR THREE TIME IT SHOULD BE OK, HOPE THIS WORKS FOR YOU,
THANKS AND CREDIT TO LABBER
Dec 20, 2007 | Panasonic Palmcorder PV-DV53 Mini DV...
PV GS 35 wont play tapes from other cameras
perhaps it has to do with the SP and LP settings, I know certain video editing programs won't capture video recored in LP.
Aug 18, 2007 | Panasonic PV-GS35 Mini DV Digital...
Panasonic PV-DV103D
This is actually a problem with the ribbon cable. When the tape is put in and the tape door is pushed shut it jars the internal ribbon cable. Years ago I found this tip online & it fixed it!
Quote
"Ok, here goes, I had the exact same problem on my pos Panasonic pv-dv203d. After many times of taking it apart and many frustrating calls to Panasonic, I've finally figured it out, I hope it helps on your cameras.
Remove the bottom plate from the Camera (four screws, plus one near the LCD screen).
Pop off the bottom plate of the camera
Look at the ribbon cables carefully, and make sure they are all snug in the plugs. The tape transport mechanism may move them out of place."
Every now and then our will start to act up & hubby unscrews the bottom of the camcorder (Panasonic PV-DV203D), gently maks sure the ribbon cables are in place, replaces the bottom plate & it's worked for us every time. i hope this helps!
Mar 12, 2007 | Panasonic PV-DV103 Mini DV Digital...
My tape player in my video camera isn't working anymore...
repairs will cost close to replacement and - it will be older ( needs new heads , probably ); buy a new one , and get a repair quote on the old one - or ebay it , for parts ;
Nov 10, 2006 | Panasonic PV-GS19 Mini DV Digital...
Panasonic PV-DV53D
I was having the same problem. here's the solution that worked for me - should do it for you as long as your camera stays on long enough. 1. Take out the tape - mine stayed on longer (without blinking) when the tape was not in. 2. press the menu button (near the viewfinder) 3. Use he wheel on top next to the viewfinderto scroll through the choices 4. Choose "display setup" by pushing the wheel in 5. Choose "C. Rest" by pushing the wheel in 6. Turn camera off 7. Next time you turn camera on you should be able to view tapes and record. hope that helps!
Oct 16, 2006 | Panasonic Palmcorder PV-DV53 Mini DV...
Televison & Video Logo
55 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
