Question about Sony Handycam DCR-TRV340E Digital Camcorder
When put on recording it shows Cleansing Cassette and runs at very slow speed showing two broad stripes on viewfinder.
  • 4,234 Answers
The unit is smart enough to detect digital dropout which is what causes the stripes. Usually a cleaning tape will resolve this. If that fails to fix the problem, a professional cleaning will be in order and testing of the actual head should be done as well. It is also possible that there is some obstruction which is preventing proper tape movement. The bottom line here is that this unit will likely require a professional. Digital units are sensitive to alignment as well. A professional will have the necessary equipment to align it as well.
Please keep us posted on your progress.
Thanks,
Dan
Posted on Nov 05, 2010
Just put in my first tape for the 2740. Even SLOW is too fast. I don't see an option for changing it. Am I missing something?
Hello this transcriber is only a 4.8 Speed transcriber and the slide speed control is on the front of the unit if the cassette that you are trying is a Normal 4.8 speed and is not responding you need to send your unit for service you can try this place Send an email to service@tvps.com or call (800) 644-9525. Please indicate model, serial and detailed description of problem
Mar 31, 2010 | Dictaphone 2740 Desktop Cassette...
Viewfinder and LCD screen only show black and record black
If camcorder shows old recorded tapes picture with correct colors in LCD but does not show live view in camera mode to record new movie then its ccd imager chip failure.
And if camcoder shows live view and old recorded tapes in its eye piece view finder but does not show any thing in LCD the its problem of broekn/ cracked flexible wire between lcd board and main board of camcorder.
Let me know your finding with bit detail to provide you solution/ helpful info.
Nov 18, 2009 | Sony Handycam DCR-HC30 Mini DV Digital...
L DVD WRITER DVD burning problem
You may try to clean you laser lens using cleansing Disk but if it wont help you. It should be echanged with LG.
Sep 28, 2009 | Computers & Internet
Recording is to fast .
If it is a re recordable cassette, you can record again. But if not you cannot actualyy do anything about it.
Regards
Kanu....
Sep 09, 2009 | Video Cameras
When recording it shows that it is recording but we can't see anything. If we play back what we think we might have recorded we can only hear the sound but not see anything.
Follow the steps below to troubleshoot this issue.
IMPORTANT: If additional model-specific instructions are needed to perform any of the steps below, refer to the operating instructions of the camcorder. The instruction manual is available in the Manuals/Specs/Warranty section of the Sony eSupport Web site.
  1. Ensure a fully-charged battery is inserted or connect the AC power adapter.
  2. Turn the camera on to the VTR or PLAYBACK mode.
  3. Insert a cassette tape with recorded video into the camcorder.
  4. Ensure the cassette tape is rewound to the beginning of the video recording.
  5. Begin playing the cassette tape.
  6. If your camcorder has an LCD screen, try adjusting the brightness or contrast.
  7. If there is still no picture on the LCD or viewfinder, reset the camcorder to factory specifications
Aug 15, 2009 | Sony Handycam DCR-TRV118 Camcorder
Recording Speed
the tascam 414 is a 4 track recording studio which uses standard cassette tapes- meaning they only play in one direction, because the tape is full. The 414 records at double speed so that recording fidelity is increased. When you have made a recording you want to mix you then dub your recording though the outputs into another standard tape recorder or whatever you have available, be it a cd recorder or your PC. So, when you listened to your recording on a standard tape player, you were not only hearing it at half speed but you were only listening to 2 of the 4 tracks. The other tracks would only be heard if you flipped the tape over, and they would be heard running backward. I would have though the 414 had a swich to allow it to also record at standard speed to but I guest it does not.
Jan 10, 2009 | Tascam Starter Pack for 4-Track Cassette...
Camera does not record
First I would suspect the record safety switch on the cassette. Look near one of the rear corners for a little red tab. If it's closed (covering the hole), then recording is disabled on that cassette.
Is there any indication in the viewfinder that recording is disabled? Usually an icon like indicator showing a cassette with a circle and slash over it.
If that's not the case, you might have a problem with you're record switch. Try using the remote to do it if you have one.
Nov 17, 2008 | Sony Handycam CCD-TRV318 Camcorder
Display shows a set of black bars
This is a common(ish) problem on the JVC models. In most cases running the cleaning cassette will work. If it does not work the first time try it a second time. Make sure you follow the instructions as provided by the manufacturer for the use of your cassette and any cleaning solutions involved. Use them in conjunction with camera's information.
Jul 17, 2007 | JVC GR-D244 DV Digital Camcorder
Partial static in playback and record even after head cleaning
Replacing the cylinder with video heads part number A7048897A will cure the problem. If you need more help please advice. Arpi
Mar 16, 2007 | Sony Handycam CCD-TR517 Camcorder
Voice playback is extremely slow.
try with some contact spray ,put it on the speed of tape button and that will solve the problem for some time.
Oct 30, 2006 | Olympus Pearlcorder T1000 Desktop Cassette...
Sony Handycam DCR-TRV340E Digital Camcorder Logo
26 people viewed this question
Top Sony Video Cameras Experts
Jerry Greenberg
Jerry Greenberg
Parshiv Luthra
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
