Question about GPS
Can't unlock Maps code
When i turn on my nuvi 750 i get a ''Can't Unlock Maps ''code.I press ok but i can still access my maps.what is the problem?
  • Anonymous Jul 02, 2008
    After pressing "where to" screen message says cant unlock maps press ok and press where to again and try adress or point of interest screen says No data available
  • laura_sd04 Sep 22, 2008
    I have the same problem with my StreetPilot c550- anyone know how to reset the unit?? Thanks!
The gray trim around the screen pops off. there you'll find a reset button.
Posted on Nov 08, 2008
For some reason my brand new nuvi 750 says it cant unlock the maps
Posted on Jun 27, 2008
Gps has lost its maps, screen says can't unlock maps
There several reasons you may receive the message Can't Unlock Maps on your nuvi or zumo device.
  • Can you press OK and get to the Where To/View map screen?
  • Did you load maps to the unit using the MapSource or MapInstall program?
  • Did you load maps to an SD data card?
If one of the points above applies to you, please follow the steps below to clear the Can't Unlock Maps message:
  1. Remove SD card from unit, if applicable.
  2. Plug the unit into your computer with a compatible USB cable.
  3. Open MyComputer/Computer icon. (Mac users skip this step.)
  4. Right-Click on the Garmin drive and select Open. (Mac users can locate the Garmin drive mounted on the Desktop.)
  5. Open the Garmin folder.1
  6. Locate a file named gmapsupp.img
  7. Right-Click and delete file named gmapsupp.img
  8. Safely disconnect your unit from your computer to see if the Can't Unlock Maps message is gone.
1. Nuvi 1100/1200/1300/1400/1600/3700 and Zumo 665 users will open the Map folder instead.
*If the gmapsupp.img file does not appear in the Garmin folder, please create an unlock file for device.
Nov 28, 2010 | Garmin Nuvi 265W GPS Receiver
My gps says "no
Question: What should I do if my Garmin nuvi or zumo displays the message "No Detailed Maps Found That Support Routing" or "No Map Data Available?"
--> Answer: The "No Detailed Maps Found That Support Routing" or "No Map Data Available" message may appear on your device for the following reasons:
  • The GPS device is missing it's unlock code
  • The maps on the GPS device have been disabled
To determine the cause of the message, touch the screen until the message "No Detailed Maps Found That Support Routing" disappears.
  • If you see a "Can't Unlock Maps" message following this error, remove any microSD / SD cards in the device and follow the instructions below for Retrieving your unlock codes followed by the instructions for Creating an unlock file
  • If you do not get the Can't Unlock Maps message then skip to the instructions for Enabling maps on the GPS device
Retrieving your unlock codes:
  1. Log into your myGarmin account
  2. Select Manage Maps
  3. Select Details
  4. The unlock code is located under the Installed Maps.
Nov 16, 2010 | Garmin Nuvi 360 Bilingual GPS Navigator...
My garmin nuvi 205 keeps telling my " No detailed maps found that support routing. The nuvi cannot be used without them."
The "No Detailed Maps Found That Support Routing" message may appear on your device for the following reasons:
  • If you do not get the Can't Unlock Maps message then skip to the instructions for Enabling maps on the GPS device at the bottom of this solution
To retrieve your unlock codes you must first register your satnav if you haven’t already done so.
To registe;
  • · Connect the satnav to your computer.
  • · Click on “myGarmin”
  • · Click on “Register Your Garmin Product” and follow the prompts
You’ll be asked to create a username and password. Write them down and keep them safe as you’ll need them anytime you want to update your maps.
  3. Select Details
Creating an unlock code file for PC:
  1. Plug your Garmin device into the USB port
  2. Double-Click on My Computer or Computer located on the desktop
  3. Right-Click on the Garmin or nuvi drive
  4. Click Explore
  5. Double-Click on the Garmin folder
  6. Right-Click in a blank space in this window
  7. Move your mouse over the word New
  8. Select Text Document
  9. Press Enter / Return on your keyboard
  10. Double-Click on the New Text Document. This will open the New Text Document in a window called Notepad
  11. Type the unlock code that is listed in the Manage Maps section of your myGarmin account in all upper-case letters with no spaces
  12. Select File
  13. Select Save As
  14. Change the Save As Type to All Files
  15. Type gmapprom.unl in all lower-case letters for the File name
  16. Select Save
  17. Close the Notepad window
  18. Delete the New Text Document file
  19. Disconnect the GPS device from your computer
Enabling maps on the GPS device:
  1. Touch the wrench icon on the Where to/View map screen
  2. Touch Settings
  3. Touch Map
  4. Touch Map Info
  5. Select the checkbox next to the maps to be enabled on the device
Aug 13, 2010 | Garmin nuvi 205 GPS Receiver
I have a Garmin Nuvi 250 and I am having trouble with its software. I have rebooted the device and reinstalled the original software. It keeps coming up with 'No detailed maps found that support routing....
Press tools, then press settings, then press map. The map name should be shown with a tick beside it. If it's not ticked press the map name to tick it. Then it should be ok.
The only other reason you should have this problem is if the map is locked. You can unlock it by going to www.garmin.com. Click on My Garmin, if you've already registered the sat nav. Click on maps and you'll get your unlock code there. If you haven't already registered it you'll need to do so now to get into My Garmin.
Jul 30, 2010 | Garmin nuvi 250W GPS Receiver
Garmin 750 cant unlock maps
Map unlock codes are specific to each unit. You will need to contact Garmin to obtain a code to unlock the maps.
Jul 10, 2009 | Garmin (010-00583-00) for nuvi 750/760/770
It says . cant unlock maps.
Follow this below
Go to your account at garmin that you created to manage your maps.
Click myMaps
Click Manage Maps
You should see your unit and it’s unlock codes
Copy all the unlock codes for your device
Close your internet browser
Right click on your desktop
Click new, and then click a new Text Document
Click on the newly created Text Document icon from the desktop
Type your unlock codes into the document
Click File and Save as
Change the file name to gmapprom.unl (( double check this please ))
Change the “Save as type” to "All files"
Close the document
You should see the file gmapprom.unl on your desktop
Right click on the gmapprom.unl file and then click copy
Plug your Garmin device in and then click Computer/ My Computer
Click on the nüvi drive
Right click on the Garmin folder and click paste
Safely disconnect your Garmin device from the computer
Regards
Richard.
May 18, 2009 | Garmin Nuvi 255 GPS Receiver
My Garmin nuvi says ''maps unavailable''
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} The "No Detailed Maps Found That Support Routing" message may appear for the following reasons:
  2. Select myMaps
  3. Select Manage Maps
  4. Select the device from the drop down menu
  5. The unlock code is located under the "Maps installed on this device" section
    /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Enabling maps on the GPS device:
    2. Touch Settings
    3. Touch Map
    4. Touch Map Info
Mar 21, 2009 | Garmin nuvi 260W GPS Receiver
Nuvi 770 wont can access maps?
First check please, tools, maps, map info,
in here are all your stored maps, tick the boxes, if they are there.
You may need the serial number ( on the sticker )
and unit I.D. tools,settings,system, about,
If not then follow the procedure below. to load them from your account at Garmin.
So, Go to your account at garmin that you created to manage your maps.
Click myMaps
Click Manage Maps
Close the document
Hope this helps
Regards
Richard.
Mar 09, 2009 | Garmin (010-00583-00) for nuvi 750/760/770
Can't unlock maps
What have you tried? without knowing anything else, one suggestion is to make sure you are using the correct unlock key number. There are at least three numbers located on the disk.
Aug 25, 2008 | Garmin (010-00583-00) for nuvi 750/760/770
USA MAPS
You need to buy a preloaded SD card, purchase maps from Garmin and download them to a blank SD card.
Dec 10, 2007 | Garmin nuvi 350 GPS Receiver
GPS Logo
1,276 people viewed this question
Top GPS Experts
Are you a GPS Expert? Answer questions, earn points and help others
