Question about Craftsman Garden
Craftsman hand held gas leaf blower will not start. I have put in fresh gas, changed spark plugs, cleaned the gas filter, tested for spart and it does spark, changed the air filter but all this and still will not start. What next??
  • 34 Answers
If it has a spark then try spraying some starter fluid on the air filter. If it attempts to run then the carburator is stopped up. If it doesn't then you most likely have low compression. Remove the spark plug and screw in a compression tester and pull the starter a few times. It has to have no less than 70 psi to fire and run. 90+ would be even better. If it is 50 and below try pouring a little oil in the spark plug hole and repeat the test. If it improves a little then you have a scored cylinder or piston or stuck or broken piston rings. Let me know what you learn and I'd be glad to walk you through some more.
Posted on Nov 05, 2010
I can not get my craftsman leaf blower to start. I put a new spark plug and fresh gas. Won't start.
Not to sure without seeing or hearing it being pulled over. Compression? Very likely needs some carb work/kit.
Apr 04, 2013 | Garden
My craftsman 200mph/430CFM 25cc leaf blower will start and last for about 5 mins. on half choke and then die out and not start. It cant be put on run or it will die right away.eplaced spark plug. Still...
check age of gas. Cannot be more than 30 days old.
Make sure to use fresh gas w/synthetic 2-cycle oil @ 40:1 ratio (1 gal.) Gas to 3.2 oz. Oil). Do not use old or stale oil/gas mixture. Always use the proper oil/gas mix. If you do not, your engine will suffer rapid, permanent damage.May need to clean or replace carburetor.
May 12, 2012 | Craftsman Garden
I have a Craftsman 2-cycle blower/vac and its only 3 years old and have changed out the spark plug and fresh mixed gas and still won't start. I need some help anyone know?
Check age of gas. Cannot be more than 30 days old. Make sure to use fresh gas w/synthetic 2-cycle oil @ 40:1 ratio (1 gal.) Gas to 3.2 oz. Oil). Do not use old or stale oil/gas mixture. Always use the proper oil/gas mix. If you do not, your engine will suffer rapid, permanent damage. May need to clean or replace carburetor.
Sep 18, 2011 | Craftsman Garden
Husqvarna model 125b Hand held blower (Gas) No
If you have tried a new spark plug and you still have no spark, then your Ignition Coil, (Module) has gone bad. They aren't cheap if you buy it new. Try to find a used one if you can for around $10.
Good Luck!
Jim
Aug 02, 2011 | Husqvarna Hand Held Blower 125 B Grass...
Kawasaki KRB750 B: Won't start. Have spark,
Check your off/on switch you can test it with an ohm meter to see if you are getting a open curcuit
Mar 12, 2010 | kawasaki Krb750b Backpack Leaf Blower
Won't start --has gas--has spark craftsman leaf bower
most likely the air filter is clogged, take it out blow it out or spray water through it and allow it to dry completely.
alterinavely, just pouring a small amount of gas onto the filter should make it work, i would do that even if you do clean it properly.
this method works for cars too!
Nov 07, 2009 | Craftsman 4 Cycle Blower/Vac
My Craftsman leaf blower will not start. Why not?
Inside the carb is yet another fuel filter in the form of a screen. It is located just under the inlet needle and it would be included in a carb REBUILD KIT (not simply a diaphragm kit).
Replacing the screen and rebuilding the carb take nearly the same amount of labor so buy yourself a kit. Roughly $10.00 for most Hand-Held blowers.
Hope this helps.
Oct 04, 2009 | Garden
I can't start my craftsman leaf blower 8 months. what could be wrong.
empty the gas out, put in fresh mix , clean the plug or replace it , clean the air filter. and if it still doesnt start use some starting fluid in the intake. then let me know if it starts
Mar 20, 2009 | Craftsman Garden
Craftsman 2cyl leaf blower wii not start
it sounds like vapor lock, trying giving it a couple pulls with the spark plug taken out
Nov 13, 2008 | Craftsman 4 Cycle Blower/Vac
Garden Logo
142 people viewed this question
Top Craftsman Garden Experts
Jim Parker
Jim Parker
john h
lnbn1975
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
