Question about Kenmore 75944 Gas Dryer
No Heat I have a kenmore gas dryer and it suddenly stopped heating Model # 110 70912990 . I've read that it may be something wrong with the igniting system but cannot find reliable sources for troubleshooting the problem and or schematics for parts. can you help?
  • 2 more comments
  • reggie960 Nov 03, 2008
    I am having the EXACT same problem (No Heat) with my Kenmore Gas Dryer 746323...Please send information on a solution and how-to fix it. Thanks Very Much!!!!
  • rafaelmeza4 Jan 01, 2009
    Kenmore 110.70912990 does not heat up
  • solanor2003 Feb 04, 2009
    i have a kenmore home dryer model 110 70722990. and suddenly it stopped heating. it works but only the heating doesnt. can you help me. thanks
  • djvukaraoke May 14, 2009
    looking for the pilet light. there is no heat
    Problem Solver:
  • 3 Answers
Have same problem with my dryer. Check your sensor out,
Posted on Jan 05, 2009
Im having the same problem with model 11078972890
Posted on Aug 25, 2008
Im having a problem with my gas dryer not getting hot i think its the igniting system where is it located and how do you fix it
model #118 72602100
Posted on Aug 13, 2008
You have answered this question before but does the ignitor stay on during the drying cycle? Kenmore series 80, model 110 72822101 gas, It starts correctly, ignitor glows, gas ignites,run for 5 to 6 min....
yes..
If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Aug 07, 2011 | Kenmore 72802 Gas Dryer
Ultra fabric care electric dryer model 96588210 stopped heating all of a sudden. I cleaned vent tube out. Flipped circuit breakers. still not heating. Thank you
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Aug 06, 2011 | Kenmore 62622 Electric Dryer
Kenmore Gas Dryer 11072212101 won't heat. we
heatman101.,/
Jun 30, 2011 | Kenmore 73102 Gas Dryer
I have a Kenmore dryer model # MC0329088 that is 10-11 years old that all of a sudden stopped blowing hot air
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Dec 18, 2010 | Dryers
Kenmor 80 series gas dryer model # 11076822695 dryer is heating up for about 2 min then it gose cooled for the rest of the cycle
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check out this electric no heat tip...
heatman101
Sep 20, 2010 | Kenmore 72802 Gas Dryer
My Gas Dryer has stopped heating. I've checked the breakers and reset them...if the thermal fuse is bad, will the drum still turn and dryer run but not produce heat? I thought I had read that the dryer...
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
heatman101
Sep 07, 2010 | Kenmore Elite HE3 Steam 8674 Dryer
Kenmore gas dryer model number 111.76712693 no heat coil wont light up do you think its the igniter sabrefan29@yahoo.com
heatman101
Aug 23, 2010 | Kenmore Dryers
No Heat
Hi, I worked on one of these yesterday and have found that the thermal fuse blows first. If your dryer has the lint filter on top then the thermal fuse is behind the back panel and is located on the same duct as the lint filter.It will usually have blue wires on it instead of black or red.
Oct 17, 2008 | Dryers
Kenmore Gas Dryer not heating. (74602)
i have a kenmore dryer the outside air vnet was cloged real bad , ive since cleaned it out but the only resone i found out was becoues my dryer will not heat up , is there a over heat swich ? can any one help .
Sep 24, 2007 | Kenmore 74602 Gas Dryer
Kenmore 75944 Gas Dryer Logo
738 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
