Question about Toshiba Satellite X205-S9349 Notebook
My toshiba satellite x205 makes a long beep followed by two short beeps in bios when it boots. i also get a blue screen randomly at times and most often when my computer makes it to the log in screen as soon as i log in half of my screen has a display problem and is staggered/off pixel lines... sometimes the screen will just go black and i cant do anything but force shut down and restart it... i need some expert advice!
defrankond
  • 65 Answers
SOURCE: Toshiba Satellite® X205-S9349 bios beeping
the beep codes you are getting are for video but if the system boots and you have video im sure it is something with the ram on the video card. unfortunatly this will require a service from toshiba. these cards are intergrated and will require the motherboard to be replaced.
Posted on Nov 30, 2008
Basilio00920
  • 155 Answers
SOURCE: Toshiba wont turn on, has beeping after i press power
Check the memory modules. Test one at a time to see if any of them is damaged. If you have only one, try a borrowed chip, or test yur modules in a borrowed laptop (it doesn't have to be the same brand/model, only the chips must be the same speed).
Posted on Apr 28, 2009
pearljp05
  • 35 Answers
SOURCE: i have a toshiba satellite x205-s9800 i can't burn cdserror 2131
Try lowering down the burning speed.
Posted on Dec 01, 2009
  • 811 Answers
SOURCE: I NEED REMOVE BIOS PASSWORD
Now this can be complicated of you have never done this before basically you will need to move a jumper pin to do this or the BIOS battery if it is not soldered or get a utility program that will do this for you. The easiest way to do this especially on a lap top computer because you have to open the case generally to do this.
The most common way that most of us know on how to reset or clear the BIOS password is to physically remove the power from the computer by disconnecting the power plug and then removing a battery for 30 minutes from the motherboard. Another way is to reset the clear CMOS jumper on the motherboard itself. Both of the 2 methods mentioned works because most motherboards use a battery to sustain the BIOS/CMOS settings for the motherboards PROM chip. So by cutting off the battery power, the BIOS/CMOS settings will be erased.
If you are able to figure this out then go for it be careful and delicate. Hope this assists you with this issue. John
Posted on Jan 17, 2011
msoufeer5
  • 170 Answers
SOURCE: when i turn on my
reset your laptop ram
reset bios battery
please vote me
Posted on Jan 30, 2011
Random short beep
Does it do it with the sound muted? Is it a BIOS type beep? OR, Open your Sounds, Sound Scheme, try to ID the beep by going through the Sounds Scheme, testing each one.
Jan 24, 2013 | Toshiba Satellite C655-S5125
Satellite x205-sli1 will not boot black screen error beep 1long 2 short please help. Powers up good and reseated ram nothing.
Thank you for sharing the beep code. It means that its a problem with the Video Card and Video Cards are usually buit-in to the Motherboard for laptops. The only way to fix it to replace the Motherboard in order to get the new Video Card. Hope I've helped you somehow.
AnEspera
Apr 24, 2011 | Toshiba Satellite M65-S809 Notebook
Toshiba Satellite® X205-SLi6 PC Notebook
have you solve your problem, I have the same problem!!!! i Would like to know if you have find a way to fix it?
Jan 21, 2011 | Toshiba Satellite® X205-SLi6 PC Notebook
BOot 3 beep then nothing?
Flip the unit on it's back, remove the battery, unscrew the RAM slot cover, remove the ram by pushing the two locking pieces away from the sides of the RAM. remove the RAM then re-seat it back into the slot, replace cover and replace the battery, flip unit back and attempt to boot. If you still get the beeps, note weather they are short or long, short-long-long, or short-short-long etc... it maybe a graphics problem and since most graphics cards on toshiba laptops are built onto the board you will have to replace the system board....is it under warranty? if not you maybe looking at an expensive fix.
Nov 12, 2010 | Toshiba Satellite X205 Notebook
Toshiba x200 black screen of death. One long beep, twoo short beeps. Help please.
The error codes of one long beep & 2 short beep Indicates a video error has occurred and the BIOS cannot initialize the video screen to display any additional information.
Do you have access to bios?
If you have access to Bios, I suggest you to load optimal defaults and try booting, It must fix your issue.
If you do not have access to Bios, I suggest you to remove the recently added hardware (if any) and try booting.
If there is no recently added hardware, It-seems that Video (Mono/CGA Display Circuitry) issue, I suggest you to contact near by service center.
Regards
May 24, 2010 | Toshiba Satellite X200-AA3 Notebook
Toshiba x205 Sli1 suddenly died. Got 3 beeps.
3 beeps usually means that either the chipset or the processor is dead. Nothing you can do, take it to a repair shop.
Nov 06, 2009 | Toshiba Satellite X205-SLI1 Notebook
I gt power to the pc but it does not boot and the
well on the satellite x205 it could be a couple things. there isnt any beep code? if there is no beep code then it would need atleast a main system board. i worked on 2 last week but they had beep codes (3beeps) which were video cards. in your case pull each stick of ram, then if thats not the case order a main system board.
Nov 05, 2009 | Toshiba Satellite X205-S9349 Notebook
i had a similar problem with my satellite notebook. the problem was that it was overheating. what i did was pull the processor and heat sink out, it was covered in dust and not allowing air to go through the heatsink. i just cleaned it up and it stopped overheating.
Apr 28, 2009 | Toshiba Satellite X205-SLI1 Notebook
Getting 3 beeps when starting the comp. with no screen.
some prblm is dere wid d ddr1 or ddr2 compatibility...jst check d compatibility of d ram n insert accordingly..having fit at both ends...that's it...it's not a big issue...
Apr 11, 2009 | Toshiba Satellite X205-SLI1 Notebook
Sep 07, 2008 | Toshiba Satellite X205-S9349 Notebook
Open Questions:
Toshiba Satellite X205-S9349 Notebook Logo
95 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
