Question about LG WM-1832C Front Load Washer
Lg wm1832cw front load washer
Spin cycle makes alot of noise
  • 3 more comments
  • SickofLG Jun 21, 2008
    I have the same problem. The darn thing says "Quiet Operation" right on front, but it's so loud I have to close my laundry room door when I use it and it's still too loud.
  • Anonymous Nov 05, 2008
    loud noise on spin, LG won't support this without fee even though seems prevelent with this model. LG claims occur with < 2% of units. Still oushing on them but ain't holding my breath.
  • mefootin Mar 14, 2009
    I have confirmed that my problem is indeed a bearing that needs replacement. I am mechanically competent, and would like to tackle this one myself, instead of pay the repair guy $500. Can someone please point me in the direction of a REPAIR manual or detailed instructions on replacing the two bearing components and the seal?
  • Anonymous Mar 13, 2014
    LG front load washer clicks off after beginning cycle. will not spin and gives error EE.
  • Anonymous Mar 19, 2014
    drum grinding on spine
  • 489 Answers
One of 2 things may be causing the loud noise.  Either the rear bearing on the drum has failed and will need to be replaced (very expensive) or the drain pump has a bearing problem and is making a very loud noise when it is draining (not too expensive).  Either way, you will need a qualified LG technician to diagnose and repair the problem.
Posted on Jun 26, 2008
Makes noise in spin cycle and now it started smoking. Tub seems to spin more easy but i don't hear anything like a bearing.
LG WM2688H Front Load Washer Smoking power ... - Fixya
www.fixya.com > ... > LG > WM > LG WM2688H Front Load Washer
LG WM2688H Front Load Washer, smoking power related issues. ... is it worth trying to fix drum loud and rattles when on spin cycle, then smoke started pouring out of ...hi working till smoke came out the back and now no power - Unplug it. ... washer makenoise doing spin cycle smell smoke make the power cord warm to ...
LG 4280FR4048L Bearing - AppliancePartsPros.com
www.appliancepartspros.com > ... > Washer > Kenmore Washer Parts
Rating: 5 - ‎189 reviews - ‎$32.19
Burnt rubber smell at end of cycle from 11 yr old lg wm2277hw front load washer i hand spun inner drum it was ... Appliance: LG Washer WM2277HW ... Our LG "Tromm"washer (a.k.a. "Trommy Baby") started making a horrible ... The bearings were worn and made very loud noise in the spin cycle John A. • Punta Gorda, FL.
LG WM2455HW washing machine problem - YouTube
? 10:29
https://www.youtube.com/watch?v=__abhTwmi1I
Sep 15, 2010 - Uploaded by djmcarter
I also have an LG refrigerator, which makes a loud sound (it's the.... I am watching your video while mopping up water underneath the exact same machine right now. ... How to Fix an LG Front load washer machine that wont spin - Duration: 5:32. ...
Jan 19, 2016 | LG WM2277H Front Load Washer
LG WM1832CW, what is the key code combination to cause it to spin only?
The machine has a "Rinse & Spin" button in the "Options" side of the control panel. Press this button to accomplish the spin "cycle" that you require.
Oct 12, 2014 | LG WM-1832C Front Load Washer
Lg wm1832cw de error occurs when starting the washing. after multiple tries, it might start
It is a door lock error caused by bad door lock switch or if your door is very hard to swing closed because the hinge is corroded, then the hinge could be causing the door lock to error.
Jan 04, 2014 | LG WM-2277HW Front Load Washer
I have an LG WM-0532HW Front Load Washer. upon trying to fix a diffierent problem, something popped. I couldn't find anything broken. However, the inside metallic tub is not longer stable. During the...
When my washer did that, I found that the shocks that hold the tub were bad...
Check out this tip I wrote about the noise and vibration that front loadwashers can make..
Washer Problems Washer noise when spinning
heatman101
Jun 26, 2011 | LG WM-0532HW Front Load Washer
Lg-wm1832cw front loader washer won't spin and drain
did anyone solve this problem? Mine is doing the same thing... uggh!
Apr 12, 2010 | LG WM-1832C Front Load Washer
Need code/s for LG WM1832CW to have washer do a spin/drain only
1. press POWER button to turn om.
2. press SPIN SPEED button only.
3. press START/PAUSE button/
May 02, 2009 | LG WM-1832C Front Load Washer
Noisy on spin cycle LG WM1832CW
this is joyce
Go to lg.com and download your manuel put in your model #
thanks
joyce
Feb 07, 2009 | LG WM-1832C Front Load Washer
Lg WM1812cw makes alot of noise when in spin cycles.
There are always bearings. This model uses a direct drive brushless DC motor so there are no belts and such. Without actually hearing the noise with no load, it's hard to say what may actually be wrong. Any time a motor makes an abnormal noise, you can expect it won't last too much longer. I have the same model so now I'm worried.
Jan 13, 2008 | LG WM1812C Front Load Washer
LG WM1832CW Front Load Washer
FE means water is overflowing. Check pump filter. Check water level switch and hose. Also check that drain hose isn't too low causing it to refill itself continuously. In any case the drain pump should run for 4 minutes to try and eliminate the extra fill
Dec 28, 2007 | LG WM-2277HW Front Load Washer
LG WM-1832C Front Load Washer Logo
1,510 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
