Question about Rinnai RHFE-556WTA Direct Vent Heater NG Air Conditioner
RCE-429A filter light keeps blinking when the filter is clean.
I have a Rinnai RCE-329H gas heater that keeps turning off.
Check..for gas pressure creep.....2 lb sys....big problem...change to green hat....pig tail line.....rinnai gas valve problem being fixed....
May 31, 2012 | Heating & Cooling
The filter light keeps blinking. the filter isn't dirty. the filter is in the front and slides out either side. we keep it clean. so.. how do i get it to quit blinking? is there some regular...
Pam, be sure tat the filter is properly installed. Whenever you remove the filter for cleaning, be sure to turn the unit OFF, before removing it. And back ON after it is cleaned and reinstalled.
For the blinking problem. Turn the Master ON/OFF Switch to OFF and unplug the unit for 15 minutes. Once the time has elapsed, plug the unit back in and turn the Master ON/OFF Switch to ON. Hopefully, during that 15 minute timeout, the unit's electronics reset themselves and reverted back to the original factory settings. If so, the filter light should have stopped blinking, if the filter is installed properly.
I hope this helped you to troubleshoot and solve the problem. Please let me know. Thanks.
Jun 29, 2011 | Whirlpool ACQ122XK Air Conditioner
Hi I have an old Rinnai RCE 417H natual gas unit
needs a service a clean and check of the ignition secquence. should only have green light for power and red light for Lighting. large screen can be bought from Rinnai part supplies
Jun 14, 2011 | Heating & Cooling
I'm using whirlpool mastermind chrome split ac.. clean filter light started blinking so i cleaned and replaced the filters but still CLEAN FILTER light is blinking. please give a solution
If you didn't turn the Master ON/OFF Switch to OFF, before removing the filter. That is the problem. To clear the error message. Turn the Master ON/OFF Switch to OFF, unplug the unit, remove the filter and reinstall it. Wait 10 minutes, plug the unit back in, turn the Master ON/OFF Switch to ON. The controls should have reset themselves and the clean filter light should not appear.
Hope this helped you solve the problem. Please let me know. Thanks.
Jun 12, 2011 | Whirlpool ACC108PS Air Conditioner
Dryer check filter light keeps blinking and dryer will not start cleaned lint filter and nothing happened display on control board blinks when dryer is turned on and that's about it can you assist dyer...
There is a reminder light to "Check Lint Filter" near the lower right of the cycle knob. It will come on every time the power button is pushed. After cleaning the lint filter, if the "check lint screen" light does not go off, it is likely that the touch pad control will need replacement.
Jan 09, 2011 | LG DLE0442 Electric Dryer
I have four blinking lights and it reads clean filter cartridges or call for service. First three lights blink jet one jet two and light and also heat light. All four blink and tub will not heat up. Keeps...
Is your pump actually moving water?
I think you should replace your cartridge filter or at the very least, do a thorough cleaning in accord with the manufacturer instruction.
There is a possibility you have pump impeller damage or there is other problem with the pump.
May 13, 2010 | Qca Spas Majestic Series Aruba Xl Hot Tub
Rinnai propane heater RCE-429A is in lock down position -
If lock button is lit.
Hold it down for a few seconds till it goes out.
Jun 10, 2009 | Rinnai RHFE-556WTA Direct Vent Heater NG...
Rinnai convector 404
You have a dirty pilot assembly and maybe even a bad ECO switch (safety switch). I would suggest replacing the ECO and removing the pilot assembly and clean it out.
Jun 03, 2008 | Rinnai Vent Free Gas Heater/: 6,000 BTU...
Rinnai RHFE-556WTA Direct Vent Heater NG Air Conditioner Logo
Top Rinnai Heating & Cooling Experts
Paul Carew
vance jones
Tim Whalen
Are you a Rinnai Heating and Cooling Expert? Answer questions, earn points and help others
