FixYa.com
Tags:
Kenmore Elite 45986 Front Load Washer
Kenmore Elite HE3t
posted by byrd_64 on Jun 14, 2008
My washer is flashing a F6 code and stops midway thru cycle,
i have unpluged it to no avail. I also searched for service manual or
some type of schematic in the bottom i find nothing .
Would you happen to know what F6 neans?
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Best Solution
posted on Jul 15, 2008
FixYa! (100)
rosspj
Rank:Apprentice Apprentice
Rating: 100%, 3 votes
My washer always has a "Funky" smell, how can I deoderize it
Was this solution helpful? Show your Appreciation by rating it:
Solution #2
posted on Jun 15, 2008
Not Rated (0)
reg501
Rank:Guru Guru
Rating: 90%, 210 votes
The machine control is unable to properly detect motor speed and the machine will shut down. If a failure occurs during high-speed spin the door will be unlocked after 3 minutes.
Potential Causes
• Check Wire harness connections between the Drive Motor/Tachometer and the Motor Controller, and between the Motor Controller and the Machine Control
• The Drive Motor has failed
• The Motor Controller has failed
Can you Help with these Washing Machines problems?
WILL NOT STRART ONCE SELECTION...
clean out filter in front... Answer This...
Extraction cycle sounds like a...
Ok, found the rattle after... Answer This...
kenmore elite front load
f 11 code showed up this... Answer This...
tommy walkabout digital.!
how do i disable the... Answer This...
Front Load Washer Kenmore Elite
The clothes are still soaking... Answer This...
Repair Service
Find Washing Machine Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
