Question about Microsoft Windows Vista Home Basic for PC
Hi..I hav3 an issu3 with my laptop. Th3 l33t3r 3 (th3 l33t3r n3xt to F) is worn out or what3v3r. It is lik3 wh3n3v3r I push it,it's th3 low3r right part of th3 k3y is going down th3 3/4 part of th3 k3y is not & hard to push that is why I us3d th3 numb3r 3 to r3plac3 l3tt3r 3. Is th3r3 any troubl3shooting st3p I can do to g3t this fix or should I go dir3ctly to th3 outl3t to g3t this r3solv3?
  • 1,179 Answers
I recomend going directly to the outlet as they will order and install a replacement keyboard for your Laptop. Problem sorted
Yes I hav3 got to put this in h3r3. he he
Good thinking!
Your timeous rating of this solution is much appreciated. Thumbs up
Thanks
Posted on Nov 04, 2010
How to remove the radiator. I removed th3 2 bolts holding radiator, I removed condenser bolts but the cover over top of radiator is permanently attached.
year make of car helps. sometimes you just push the top of the rad towards the motor for clearance from the upper rad support and pull the rad up and out.
Sep 01, 2015 | Cars & Trucks
What colors are they
The first # is hexadecimal. ff7188 Color Hex
Th3 9-3 might be a pantone reference http://rgb.to/rgb/9,3,38
Apr 14, 2015 | Tablets & eReaders
Freezer temp displays 1 C E refig temp t 3
Hello p_shields123 - Could the actual error code display be "ICE T3"? If so, it typically indicates that the TH3 thermistor in the Fresh Food Ice Maker compartment is shorted or open. Regrettably, this is not a simple DIY job. I would strongly recommend connecting with a professional to move forward accurately and to properly assist with the repairs.
Mar 11, 2013 | Frigidaire FGHB2844L
Where are the freeze plugs located in th3 1993 Missan pickup?
Freeze plugs are on the engine block. Should find them on each side in about the center line and probably 2 or 3 on each side. There will also be some on the back of the block but it requires removal of the transmission to access them.
Jan 08, 2011 | 1993 Nissan Pickup
The dryer turns on and runs, but it is not heating up...
The problem is either the Safety Thermostat TH2, High-Limit Thermostat TH3, or the Heating Element itself. Here's what you should do find which among is the culprit.
Use a putty knife blade or similar tool to push and release the clips holding the top panel to the front panel. Insert the putty knife between the top panel and the front panel as shown at about 2 and 3/4 inches from the edges then push in until the clips are released then lift the top panel off.
Open the door then remove the two screws at the bottom of the door opening as shown.
Remove the two screws from the upper side of the front panel then pull the panel out and disconnect the Door Switch connector.
Once the front panel is removed, you'll see the Heater Box at the bottom right hand side of the cabinet. Remove the cover and you'll see three sets of the terminals on the left side of the Heater Box. The set of three terminals is the Heating Element, the middle set is the Safety Thermostat TH2, while last set is High-Limit Thermostat TH3.
Using a multimeter, set to the lowest Ohm scale (R X 1), check the continuity of the Safety Thermostat TH2 and High-Limit Thermostat TH3 then the resistance between the middle terminal of the Heating Element and the other two terminals.
The Safety Thermostat TH2 and the High-Limit Thermostat TH3 are both normally closed and any discontinuity (open circuit) found indicates that the component has failed. It is necessary to replace both the Safety Thermostat TH2 and the High-Limit Thermostat TH3 if one of them has failed. The Safety Thermostat TH2 is likely to fail as a result of the High-Limit Thermostat TH3 failure.
The normal resistance between the middle terminal (2) and the upper terminal (1) is 18 ohms to 22 ohms while between the middle terminal (2) and the lower terminal (3) is 9 ohms to 11 ohms. Replace the Heating Element if an infinite resistance (open circuit)reading is obtained in any the measurements.
You may take the Heating Element out then thoroughly check it visually for any obvious coil discontinuity if you don't have a the meter to check the continuity of Safety Thermostat TH2 and the High-Limit Thermostat TH3 and the resistance of the Heating Element. It will be obvious if the Heating Element has a broken coil.
The problem lies in either of the Safety Thermostat TH2 or the High-Limit Thermostat TH3 if the Heating Element coils is intact. Bypass both the Safety Thermostat TH2 and the High-Limit Thermostat TH3 then reconnect the Door Switch connector. Run the dryer and it should heat by now to indicate that either the Safety Thermostat TH2 or the High-Limit Thermostat TH3. Otherwise, it is a totally different story. Please let us know if that is the case.
Warning! Do not use the dryer with the Safety Thermostat TH2 and the High-Limit Thermostat TH3 bypassed due to fire hazards.
Aug 11, 2010 | LG DLE2532W Electric Dryer
I have a 1994 s420 mercedes and the main and trip odometer stopped working
hello,seems your speedometer head is defective,maybe some gear are worn or damage,ty
Apr 26, 2009 | Mercedes-Benz 420-Series Cars & Trucks
My son lost his remote
th3 remote you need is a rav311
part number wj4d93ous
Dec 12, 2008 | Yamaha HTR-6030 Receiver
S3 inverter
need more information on your air conditioner, make, model to fix problem
Dec 21, 2007 | Heating & Cooling
Microsoft Windows Vista Home Basic for PC Logo
27 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Alun Cox
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
