Question about Canon PIXMA MP530 All-In-One InkJet Printer
A vertical line prints on the back of every print job.
  • 1,179 Answers
You will need to clean the rubber wheel of ink, that corresponds with the vertical line left on the page, use tissue paper.
Your timeous rating of this solution is much appreciated. Thumbs up
Thanks
Posted on Nov 04, 2010
Hello, I have a problem with Zebra Z4M Plus
Hi, if is the vertical line, its the print head that need to be replaced,
try to clean the print head and try this to confirm:
turn printer off, press PAUSE button and at the same time, power on, don't release the button, please wait until printer LCD screen come on, then release button. It will print the PAUSE test and after few 3-4 prints, u can turn off and on again otherwise printer not ready to print your labels until u restart it. (pause test stops after 10-15 labels). this pause print just show how the print head is and if come with vertical lines, u will need to replace. other idea is (if u can) turn the bar code different position or on vertical way at label format. Thanks.
Aug 04, 2013 | Zebra Office Equipment & Supplies
KM7450 Vertical Lines in Magenta
I would replace the Magenta drum unit & developer unit
Jan 13, 2010 | Konica Minolta magicolor 7450 Magenta...
Line down the left side of the photocopies
If this only occurs with copies (not with printed jobs), then your problem is most likely dust/dirt on the scanner (not necessarily the glass), or on the optics that feed the image to the scanner. If it's on print jobs also, it could be a simple image drum problem (they wear out over time, and frequently manifest their impending failure with vertical lines appearing down printed/copied pages.
Aug 13, 2009 | Brother MFC-7440N Laser Printer
MY PROBLEM IS MY 230 PRINTER VERTICAL PRINT IS NOT
I have problem while printing colour photos and I would like to know how to print back to back i.e. even and odd pages
Jun 09, 2009 | Epson STYLUS R230 InkJet Photo Printer
Samsung ml-2010 printer prints vertical lines on the page
it may due to scearch on roller. check the roller for any scearch mark.
Dec 23, 2008 | Samsung ML 2010 Laser Printer
Vertical print residue left about half inch past the longest line printed
inside the front cover, under where the head parks, you will find a vertical wiper. Clean it.
Power off. open front door. push down cutter (blue) and slide head to the left. To the right of the cleaning pad is the wiper. clean with rubbing alcohol on both sides.
Run a normal cleaning.
All set
NOTE: you do not need to put the head back in place. when you power on it will automaticly park itself
Nov 06, 2008 | Epson Stylus Pro 9800 InkJet Printer
Scanner leaves three vertical lines on scanned page
A dirty glass base can cause ‘spots’ or blemishes to appear on your final printout. Additionally, if you had some sort of opaque liquid that may have transferred on to the glass base from a previous operation. But the majority of the unwanted vertical lines are generally caused by either a dirty or damaged print roller or faulty LEDs in the Scanner Module.
To separate one from the other you have to check the following:
Do you only see the lines with a Scan operation?
Do your print jobs print fine without any unwanted lines?
If you only see the unwanted lines during a Scan operation, then most likely you have a fault/dirty/obstructed LED module.
If you see the unwanted lines with all print operations (Scan, Print and Copy), then you most likely have a worn out, damaged or dirty Print Roller.
Hope this helps…
RojoSho
Sep 29, 2008 | Brother MFC-7820N Laser Printer
Prints yellow vertical lines on all color print jobs
Try to do a nozzle check/ Turn printer off/ put in a plain paper
Press and hold the middle button on the printer while turning it on. When it turns on you can realease the buttons. Should [print the nozzles/ check if there would be gaps of missing colors/ if yes do head cleaning by going to printers and faxes under contorl panel>right click on c66 and go to printing preferences>maintenance tab>print head cleaning>do it 3 times and then try to print
Jan 21, 2008 | Epson Stylus C66 Inkjet Printer
Canon PIXMA  MP530 All-In-One InkJet Printer Logo
Clive
Clive
old marine
old marine
