Question about Frigidaire Refrigerators
My Frigidaire is about 5 years old and last week it started leaking water but I cannot tell where it's coming from. When I went to clean the draweres, they were filled with water. Can you tell me what the problem might be?
  • 618 Answers
Sounds like the freezer defrost drain is frozen up or plugged . It is under the evaporator behind the freezer back panel. I use boiling water to clear and you may have to clear the line at the bottom where it dumps the water in the tray.
Posted on Nov 04, 2010
Last summer we installed a Intex salt water filter it worked great for about 2 1/2 months. It stopped working, Checked the power supply nothing was coming thur it. Intex relpaced it under warranty. Started...
This could be a flow problem and you will need to check your pump baskets for junk and make sure your filter is clean. Also you can check your flow switch to be sure it is working.
Aug 13, 2011 | Intex Automatic Salt Water System for ...
My Frigidaire front load washer model no. GLTF2940E, is about 5 years old. It has always worked fine. Last week the spin cycle left some cloths wet and now when I start it, it only allow about 5 seconds...
Sounds like you have faulty water inlet valves. They may not be opening fully. You can test the power to the valves with a voltmeter to see if the power is quitting or if the valves are malfunctioning
Mar 12, 2010 | Frigidaire ATF6000ES Front Load Washer
Leak. My wife noticed water leaking out bottom of washer
Try cleaning the drain plug. I did this in about 5 minutes and was amazed at how much debris was clogging up the drain. Mine was accessible by removing two screws at the bottom of washer and removing panel. Drain plug was right there and easy to unscrew. Be sure to have a cookie sheet or other pan to catch the water that will flow out. Once that drain is clear, thumping should stop because water can flow down the drain easily.
Aug 17, 2009 | Frigidaire ATF6000ES Front Load Washer
No water coming into machine. Programme not running because the machine is still trying to fill. If I add water the machine does drain. Was cleaned with a good dishwasher cleaner only last week. Nothing to...
Turns out that the dishwasher had a leak in the bottom. No water could be seen leaking out because Bosch machines have a cut-off valve that means if a tray in the bottom of the machine fills up with water, the float valve doesn't allow anymore water into the machine. we worked this out after we tipped the machine slightly, water ran out, when we put it back down and started it the inlet valve worked until the bottom had filled with water again.
New machine for us! However, not a critism of Bosch. We use our machine at least two or three times a day and have done for the last 5 years.
Sep 09, 2008 | Dishwashers
Dead Upright Frigidaire Freezer
YOU MOST LIKELY HAVE A FREON LEAK AND RUNNING THE FREEZER WITHOUT FREON IN IT WILL KILL THE COMPRESSOR UNLESS YOU UNPLUG IT AND GET IT FIXED,THE COILS ON MOST FREEZERS ARE IN THE SIDE WALLS SO YOU DON'T HAVE TO CLEAN THEM LIKE ON YOUR FRIG.HOPE THIS HELPS-MIKE
Jun 16, 2008 | Frigidaire 14.1 cu. ft. Upright Freezer...
Where is my leak coming from?
Your machine has a bottom access panel. Remove the panel and run the unit. This will help determine where the leak is.
Jan 20, 2008 | Frigidaire GLTF2940ES Front Load Washer
Frigidaire FDB740RCS0 Upper Armnot Turning
the motor stops and runs in the opposite direction to pump water up to the top rack. you first need to listen for the motor to stop and start. if you hear that open the door and try to tell if water was coming out of the top spray arm.
Nov 01, 2007 | Frigidaire 24 in. FDB1050RE Built-in...
Machine drains and dial turns directly to S after filling with water.
moe thasn likly you have a pressure switch that is either telling the machine its too full and making it drain or its not seeing the switch and so it drains. Another possibility ids the machine is leaking. Pull the lower cover off and make sure there is no water in the bottom. These askos have a float switch down there that will run the drain if the sense water leaking into the lower tray. Last but not least, you could have a bad timer. these timers are covered for 5 years (parts only) from date of installation. The first 4 digits of the serial # will tell yuo when the machine was made the firts 2 are the year and the second 2 are the week of that year (so a serial beginning in 0145 woul;d mean built in the 45th week of 2001 and so on. Good luck!
Sep 26, 2006 | Asko W6221 Front Load Washer
5 yr old washer is leaking
Ellbee, remove the two screws at the bottom of the front panel and lift it towards you. Two clips on the top that hold it will release. You can now get a good look at the pump. Catriver..post back.
Sep 19, 2006 | Frigidaire GLWS1339C 3.0 Cu. Ft. Top...
Refrigerators Logo
51 people viewed this question
Top Frigidaire Refrigerators Experts
John Tripp
John Tripp
Steve Allison
Steve Allison
Sal De
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
