Question about Mitsubishi WS-65613 65" Rear Projection HDTV
Power problem that I had last night - nothing works, any more suggestions
Mitsubishi ws-65613 television shuts off and green light stays on - have to power off and power on for it to come on - sometimes it only stays on for a minute, sometimes longer, thought it might be a connection problem but everything is connected tight. anymore suggestions?
  • 2 more comments
  • 2nanc Jun 22, 2008
    soldered connections didn't work. TV is not actually shutting down, we just loose picture and sound because I can bring up the menu on screen from the Mitsubishi remote control (not the direct tv remote control). Can change to play DVD but still no picture until we turn the tv off then on again. When playing a DVD from video 1, same thing as when we are watching tv thru Comp2 with Direct TV, at randon we hear a pop and screen goes blue and no sound (except screen goes dark when watching from Comp2) Have to power off the tv then power on for picture to go back on. It doesn't matter if tv is playing from Comp1 (direct tv) or Video1 or Ant A - At random still loose picture and sound, Green light in front of tv stays on - Have to power tv off then power on to get picture and sound back on. When turning the tv on for the first time during the day is stays on the longest (30 maybe 45 minutes or so) then when it starts going down the duration it stays on can be for 30 seconds or 5 minutes or 1 minute (when it looses picture it is at random, but it happens every time we turn on the tv).
  • kufu Jul 06, 2008
    i have the exact same model and i have the same exact problem no blinking light or anything. for me its just a black screen but the tv knows when you have a signal going to the inputs. the reason i say that is cause when its gets real bad, a blue screen with purple lines and a high pitched whine, show up. and a error message(of a sorts) saying check power and connections. you mess with it a little, and eventually the tv works(for a short time). ive studied the tv, and the projection or screen part itself, works every time, cause you can access the menu. its like the inputs and outputs short out. you do hear a "pop", like a short would sound. if you could call it a short. And it is totally random. it does seem worse in the evening. i havent taken any steps to fix it or anything, right now im just trying to learn the random symptoms. ive never seen anything like it. i dont even want to take it in to get it fixed, its a monster. are there other options even? i know it may sound stupid but maybe trade on a new one?
  • iceryder Nov 22, 2008
    I have the same problem , has anyone figured out how to fix it? My picture will go out more often the longer the set is on.
  • wing_nut62 Mar 09, 2009
    tv will play fine for about 30 min then theres a pop and the picture goes blank and is replaced with a dark screen with purple rolling lines. when i power it off and on set plays for a bit and then cuts off again. also get the msg, check connections or power. the connections for RGBHV or YPrPb may be invalid.
    Brigadier General:
  • 6,966 Answers
Hi again,
What might look as tight might not really be. Have you re-soldered most of the major solder joints/connections?
Posted on Jun 15, 2008
Mitsubishi WS-65613 tv green power light keeps blinking tv will not turn on
Unplug the unit for 5 minutes then plug it again. Turn it on. If it does not power up, press the SYSTEM RESET button on the front panel with a pointed object such as the point of a pencil or end tip of a paper clip. The green LED light will flash quickly for about a minute then stops. You may turn on the TV then. The changes you made most recently, before using
SYSTEM RESET, may be lost. Changes you made previously, however, are not lost.
Sep 11, 2009 | Mitsubishi WS-65613 65" Rear Projection...
Mitsubishi WS-65613 power problem
kindly check the settings.. could be the sleep timer was set ON..
Let me know here again..
`jack
Jun 13, 2008 | Mitsubishi WS-65613 65" Rear Projection...
Can't turn on the TV. Green light keeps blinking.
You need to change the four capacitors C9B01,C9B02,C9B10,C9B11 all 1000 MFD 16 VOLT (on the DM board which is inside the metal shield standing upright on the left looking from the back of the set)The tops of the capacitors will look puffed out making them easy to find. This is your HD tuner digital board which is trying to reboot but can't - when the green light stops blinking after a minute,than you can power on your TV.
Aug 26, 2007 | Mitsubishi WS-65613 65" Rear Projection...
Misubishi WS-65613 Flashing green reset light
do you have the service manual? also have you checked the diodes or protection fuses for the volts out of the loptr ( low output trans) , also check the volts on the trans for no volts , low volts , or voltage drop
let me know what tests and results you have , and if you dont have a schematic yet , this one should be about the same as yours , this is part 1 with 7 zip files http://www.eserviceinfo.com/downloadsm/31768/Mitsubishi_WS-55859.html
this is part 2 with 2 zip files http://www.eserviceinfo.com/downloadsm/37351/Mitsubishi_WS-55859,%20WS-65869,%20WS-55909,%20WS-65909,%20WS-73909.html
electech
Nov 26, 2008 | Mitsubishi WS-65613 65" Rear Projection...
WS 65613 MITSUBISHI
your problem is in the power supply.check the regulator
Nov 04, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Tv won't come on. It has a flashing green light on by the power button.
the tv is not come on.it has a flashing green light on.tv model hd 1080.
Oct 19, 2008 | Mitsubishi WS-65809 65" Rear Projection...
Blinking green led light
I HAVE THE SAME PROBLEM BUT I HAVENT FOUND ANY GUIDE YET
Oct 16, 2008 | Mitsubishi WS-65613 65" Rear Projection...
You will not need SAMS on this one,Frank! I fixed four Mits. with
your symptom in the last two weeks.....parts = 1000mf/25v caps
105 degree hi-temp X 4.......Location = DM module...for pix's...
www.Chris@ChrisAndNat.com.....download copy..........
I have improved above procedure....When finished with repair of
PCB.,I place it secure in sockets , with two screws on end of
module back in place.THEN I slide cover down over module
and put the side screws in..........
Be gentle and if you need more help............T.
Nov 25, 2007 | Mitsubishi WS-48613 48" Rear Projection...
Ws 55513
The constant blinking green light means that the TV is not booting up. This is a common problem on this set.You need to remove the shield from the DM board (standing upright on the left where the DTV RF connector is)and inside you will see the four leaky capacitors (1000 MFD 16 VOLT)replace them,plug the TV in and wait 70 seconds for the blinking light to stop,then turn on the TV.The hard part will be removing the board from the TV(lots of screws and connectors,takes time)
Sep 22, 2007 | Mitsubishi WS-65613 65" Rear Projection...
Mitsubishi WS-65613 65" Rear Projection HDTV Logo
366 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
