Question about LG Heating & Cooling
Compresser Shuts Off
Recharged A/C unit with 18oz. of R-22 Compresser will run for about 2 min. then shuts off for about 5 min. then restarts agan.
  • Westrick Jun 17, 2008
    Coil had a leak in it which was repaid. Do you know what the hi & low psi. should be ?
  • 525 Answers
It may be overcharged now. Let some of it out until it stays running.
Why did you add freon? if it needed freon then you must also have a leak or a bad compressor
What was the issue with the a/c to lead you to putting in freon?
Dave E. (Illeagle)
Posted on Jun 14, 2008
  • David Emmel
    David Emmel Jun 15, 2008
    Just checking back to see if you need anymore assistance. If you got it fixed and my advice was a positive factor, please rate my help by rating my answer.
    Thank you,
    Dave E (Illeagle)
Ac compressor runs 5 min shuts off then restarts 10 minutes later for another 5 min fan runs ok
Shutting down on safety. It's likely a pressure switch, possibly low pressure if fan is running.
May 24, 2017 | Heating & Cooling
1994 f150 6 cyl engine shuts down every 10 min restart after 5 min
Sounds like the module inside the distributor. Have to be replaced.
Sep 29, 2012 | Cars & Trucks
2 yr. old. worked great. Then started shuting down self changing setting to low. shortly after, shuts down after 3 min. no water collection, unit is hot. Took apart. Cleaned everything inside, and filter....
Robinson, it really sounds like the compressor is overheating. This may be caused by a low refrigerant gas in the compressor. Or the compressor's oil has leaked down. But, if you took the unit apart to clean it, I would think that you would have noticed an oily residue. If it is the compressor (other than needing to be recharged) it would cost almost as much to replace it, as it would be to buy a new unit.
At least with a new one, you'd have a one year warranty and more, if you purchase an extended warranty.
Hope this helped you.
Jun 02, 2011 | Dehumidifiers
I have a laars lite 2 manual controls natural gas. The unit starts up runs strong for 5 mins shuts down restarts runs for now only seconds and shuts off
sounds like the hi limit switch is shutting it down,because it is not getting enough water,cloged filter, valve to heater notopen,bypass valve not closed,open up the water releif valve with the pump running should be alot of water running coming out of it.
Jun 13, 2010 | Lite On Laars Lite 2 Heaters: 250,000BTU...
On my window unit the compresser only runs for 15 sec. and shuts off for 4 min. the fan stays running.. its not cooling the room
possably a problem with the outside condensor fan motor. Pls check
1.) when unit is running is the outside fan motor also runnng. My guess is the outside fan is locked bad motor ect. Unit would only run maybe 30 seconds before cycling on its overload
May 04, 2010 | Whirlpool ACE244XS Air Conditioner
Boots up windows runs for 5 mins then system shuts
You may have a cooling problem (with older computers), if you hear your fan running excessively and then it shuts down on you. Otherwise it is more likely a hard drive issue.
Jan 25, 2010 | Toshiba Satellite P25-S5263 Notebook
Starts, runs 5 min. then shuts down everything, won't restart for couple minutes and with aid of jumper cables
does the truck have an anti-theft system? if so did u install anything new on the vehicle( stereo, remote starter etc...)if not then the module for the anti-theft my be toast. if u have installed anything new, double check where the wiring for the new component has been spliced, the anti-theft module needs at least a 5 volt signal in order 2 work. if this wire has been spliced then u will not have enough voltage to run the module properly.the module runs on a timer so if the truck stalls then u will have 2 wait about 5 mins for it 2 reset b4 u can restart the vehicle
Dec 10, 2009 | 2001 Isuzu Rodeo
My outside unit runs a little while then shuts off.
More likely the out door fan motor has bad bearings and that would cause the out door unit to run for 15 to 20 min but it could be low on freon
when the out door unit runs after 3 to 5 min the larger of the two copper lines going into the unit should be ice cold
If the thermostat you just installed has a time delay that will keep the indoor blower motor running for up to 5 min after the unit shuts off
Sep 01, 2009 | Honeywell Heating & Cooling
Toro 6.5 hp pushmower shuts off after ~ 5 mins of
It may have a gravity float residing in the carberator which may be cracked and will show same symptoms.If not garvity float, check for loose connection, heat and vibration my cause it to die, it cools and then restarts.
Aug 02, 2009 | Garden
Heating & Cooling Logo
Top LG Heating & Cooling Experts
Donni Steen
Tim Whalen
Dan Webster
Dan Webster
Are you a LG Heating and Cooling Expert? Answer questions, earn points and help others
