Question about Brother MFC-5440CN All-In-One InkJet Printer
Cannot download drivers for Brother MFC-5440CN
  • 286 Answers
SOURCE: Brother MFC-5440CN Printer Problem
If this only happens when you are copying.
1. Your scanner glass is dirty. Open the lid, use windex to clean the flatbed. Look on the left side. You should see a strip of glass, with the scanner sitting under it. This strip is used when the document feed is being used. Make sure it is clean. Most common problem is getting a little whiteout or the sticky residue from scotch tape on this glass, which causes lines down your copies.
Clean it with alcohol which will dissolve the sticky stuff and the whiteout.
If this does not solve the problem, the CCD scanner in your machine might be going bad.
Posted on Dec 30, 2007
SOURCE: OCR with Brother MFC 5440CN
Abbyy finereader 6 works well with the 5440cn. The latest version is 9.
Posted on Apr 24, 2008
mitpatterson
  • 74 Answers
SOURCE: Ink Absorber Box
If you lift the scanner and then carfully remove the cover that is on the same side as the ink cartridges the box should bein the back and you can remove it and clean it and let it dry for a while then reinstall it. if you need more help just do a live chat request for ME and i will help you
Posted on Jul 30, 2008
cene765
  • 787 Answers
SOURCE: error message one brother mfc-5440cn
Unplug the printer from power cord.Press and hold the "menu" button, then plug the device.You'll see on the LCD screen a "machine error" code.If this code is 40,41 or 4F the print head is defective.If the error is 50 or 51 there is error in Purge unit and printer require service.If the error is 46 the waste ink tank is full.Follow this:
Enter 80, then scroll down with the arrow down (round) key. You'll find an entry listed as purge count. If number
is over 6000, enter 2 7 8 3.This will reset the purge count value. Then restart the printer, hopefully without the
annoying cannot clean message.
Posted on Oct 28, 2009
  • 159 Answers
SOURCE: Brother printer problem
You'll need the new waste ink tank, part number LF7544001. They call it an Ink Absorber box. Add a small flat screwdriver, a rag, and a #2 Phillips, and I think you're set:
Raise the scanner until the support bar holds it.
You'll find two skinny covers set into the top cover of the printer section. Use the flat-blade screwdriver to pry loose the hooks that hold them and remove them.
You'll find that they cover the cables that connect the scanner to the main section. Unplug them and unscrew the ground wire that runs parallel to them. Carefully note the routing of the cables, so you can cram them back in and they won't make the covers bulge when you're done.
The scanner support bar is now free to unlatch at the bottom end. Now you can raise the scanner section until it's vertical and unhook it from its hinges. Set the entire scanner assembly aside.
The printer section's top cover is held by about 7 screws. All are identical, except for a single one that goes into steel instead of plastic. Keep track of where that one goes when you unscrew everything. Remove the top cover. I believe there's a hidden hook near the front-center, also.
You'll find the ink absorber box at the back. The ink tubes just pull off and push on. Be ready with a rag to catch any drips when switching.
Putting it back together is easier than taking it apart was, except getting those cables to fit nicely in their channels. The flat, white one is delicate. Insert it straight. Remember to mount the scanner and snap in the support bar before snapping on those skinny covers.
You may have to reset that counter again, but you have those instructions.
Posted on Jan 27, 2010
A driver for my brother printer all-in-one inkjet model mfc 5440cn
Drivers for this printer can be downloaded from Brothers solution centre. You will have to choose you region and opperating system etc as the drivers differ: welcome.solutions.brother.com
Dec 19, 2012 | Brother Office Equipment & Supplies
Lost my installation cd (brother mfc-5440cn) How to download?
Click here Click on above link select your operating system and download driver. Then install. Let me know if you need further assistance. Thanks for using FixYa.
Dec 01, 2010 | Brother MFC-5440CN All-In-One InkJet...
I NEED TO REINSTALL MY BROTHER MFC5440CN PRINTER IMMEDIATELY. I CANNOT FIND THE DISK TO DO SO.
Go to the manufacturer site to download the software driver of you printer it is free of charge
Oct 31, 2009 | Brother MFC-5440CN All-In-One InkJet...
Need to reinstall my brother MFC-5440cn printer
http://www.howtodrivers.com/model60.html
this is the driver for to be rec by the computer ....if you use it into the network ...ya probably need to install the driver into the host pc ...and the rest will just send it trough it ...
Want to install old brother printer mfc - 5440cn on laptop - laptop run 1windows vista -what should I do ?
You can download the Driver for Vista here. There will be long list on this page, search your Model on the Page and click on "Download". (Its for Vista® 32/64 bit).
If I was helpful, kindly do Rate!. Regards.
Jul 30, 2009 | Brother MFC-5440CN All-In-One InkJet...
ok my friend from Belgium
open this website
http://welcome.solutions.brother.com/BSC/Public/Templates/DownloadTop.aspx?NRMODE=Published&NRNODEGUID=%7b2C7B4D65-D5B3-47BF-958E-322BE5EFDCA8%7d&NRORIGINALURL=%2fbsc%2fpublic%2fus%2fus%2fen%2fdlf%2fdownload_top%2ehtml%3freg%3dus%26c%3dus%26lang%3den%26prod%3dmfc5440cn_all&NRCACHEHINT=NoModifyGuest&prod=mfc5440cn_all&reg=us&c=us&lang=en
select drivers in the first step
select the operating system in the second step
select the language in the third step
now download and install the drivers and enjoy
cheers
Aug 20, 2008 | Brother MFC-5440CN All-In-One InkJet...
Brother MFC-5440CN All-In-One InkJet Printer Logo
James Cagle
James Cagle
ctnozil
Victorman
Victorman
