Back to:
Tags:
Toshiba Satellite M45-S265  PC Notebook
Toshiba M50 additional memory
posted by grs1958 on Jun 14, 2008
I want to replace the existing 512kb memory with two 1GB modules. Can this be done?
I have removed the memory cover as per the manual but the existing module will not come out. Is there a trick to this? I don't want to force it.
Comment by grs1958, posted on Jun 15, 2008
I'm sorry, but this does not make sense.
I have the same problem.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Best Solution
posted on Jun 14, 2008
Thanks for Trying (70)
prasannakuma
Rank:Wiz Wiz
Rating: 79%, 46 votes
hi friend,
first you have to know it's not the 512 kb it is an 512 MB. If it is the laptop there may be the two slots in the corner of the slot you see the knob press it slidely the knob on the both side after remove as the same process to put new ram on the slot but before that see please check if your computer or the laptop is supports the 2GB ram . you can see the manual of the laptop or search the web or ask the shop where you buy the laptop. these are steps for ram. try it , and if problem comes again ,please inform to fixya.com
bye.
Rating Locked! (?) grs1958 has rated this solution as Thanks for Trying
Thank You!
Was the solution helpful?
Show your appreciation by commenting on toshiba M50 additional memory:
I don't want to Accept this solution
Can you Help with these PC Laptops problems?
PC Laptops
My laptop has Windows Vista Ultimate x64 as its operating...
PC Laptops
I don't really have any problem with the laptop now... I...
PC Laptops
Pls help me to find SATA drives to be integrated on XP...
Toshiba Satellite M45-S265 (PSM40U07V001)...
Thought it was the battery, so replace with a new battery...
You can be typing along and hit shift key and it will ...
Loading problems.
Repair Service
Find PC Laptop Repairman Near You:
Browse the Repair Directory
Repairman, Get Listed FREE
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
