Question about GPS
Garmin nuvi 360 speaker not working - GPS
  • 11 more comments
  • Anonymous Jun 14, 2008
    my speaker is not working on my new garmin nuvi .
    The audio is only heard when I connect it to my car stero via a
    cassette adapter.
  • Anonymous Jul 28, 2008
    After I downloaded and installed the latest Map (a 2 hour ordeal), my speakers stopped working.
  • choco9in Aug 16, 2008
    I can hear the audio only if I connect it with headphones!!
  • pakhogn Aug 31, 2008
    All of a sudden while driving the speakers went out on me. Is this a manufacturer flaw or the internal connection to the speakers disconnected? Would like to hear from others.
  • hairypalm Sep 08, 2008
    I have a similar problem. Speaker doesn't work most of the time, but sometimes it does. I find that if I let the batteries run down and try it again then the speaker will work for a short time. Nothing I do can fix the problem including the diagnostic mode.
  • hank19580 Nov 08, 2008
    My speaker on garmin nuvi 360 stop working .what should i do.?
  • Anonymous Dec 23, 2008
    Count me in. The ***** is giving me the silent treatment, maybe because I ignored her directions one too many times. With heaphones, I can hear her through only one channel. I did use the mp3 player through amplified speakers for a short time, until one channel went out.
  • Anonymous Jan 05, 2009
    My Nuvi 360 speaker not working. Works through headset.
  • mas2009 Jan 10, 2009
    it was working fine today.. then it just stopped.. no sound from the speakers :s
  • Anonymous Feb 02, 2009
    Garmin nuvi 360. Probably about 2 months ago (and a few months out of warranty) lost the external speaker. DEAD as a doornail can hear only on audio jack. Quite an expensive piece of...
  • rippie Feb 02, 2009
    Garmin nuvi 360. A few months ago (just out of warranty time) my speaker went DEAD as a doornail. Can only hear thru the audio jack. What a piece. I saw a thread on this where some guy was offering his skill as an out-of-warranty repairperson. Apparently a good job to have in a troubled economy. Plenty of business...
  • Msesq1997 Feb 28, 2009
    My Garmin Nuvi 680 GPS Receiver started with sound problems that sounded like static. Now there is no sound at all.
  • tony7681 May 12, 2009
    I bought nuvi 650 almost two year back and I hardly used it. After some use audio stopped working. I thought I might have some thing wrong and there should be nothing wrong with my GPS as it is from Garmin. After trying all sort of options I finally concluded it's Garmin GPS issue.
    Now I am looking for your help. Will you pl. let me know what should I do to fix this issue. I paid $500+ for this device.
I fixed my wife's with a speaker from Digikey, part number 102-1564-NE (2 watt speaker, 8 ohms). If you have the guts to take it apart, then it's not too tough. I used a 0.020" thick plastic card (a credit card is 0.030 and is a little to thick) to separate the cover, a very small torx and phillips screw driver, and a soldering iron.
Posted on Feb 06, 2009
  • buckley888 Feb 06, 2009
    Oh I also used a dremel to trim the speaker face pad a little, it's a touch thicker compared to the old speaker.
To repair my Garmin Nuvi 360 with a distorted speaker on July 9, 2010, I purchased from Digi-Key (www.digikey.com) a Panasonic P10175-ND 36 mm round speaker 8 OHM 0.5W for $5.38 plus $0.43 tax and 1st class USPS shipping for a bottom line of $8.05. This speaker is ~ 1mm thinner than the original so no trimming of face pad was required. Arrived in 2 days very carefully packaged from Digi-Key -- Great Service ! The sound volume from this speaker is a bit less than the original at full volume setting however may be a plus so it isn't over driven by the Nuvi 360. The volumes is adequately audible in the car.
Posted on Jul 09, 2010
  • candor Jul 09, 2010
    sharcnet SELF SERVINGLY says "Please don't try this yourself. You risk damaging the unit. .... " AND THEN ATTEMPTS TO POINT YOU TO HIS COMMERCIAL WEB SITE. BS -- the fix (speaker replacement) is very simple and straightforward and cheap when purchasing the replacement speaker from Digi-Key as noted above by Candor. Don't be mislead to a commercial repair shop drumming up business for themselves.
    From Candor:
    See http://www.dacust.com/nuvi350/index.html... for an excellent pictorial instruction to replace the battery on an Garmin 350. Same disassembly works for 360 and probably many others. Just replace the speaker instead of the battery.
My nuvi 360 speaker does not work. Stopped all of
Make sure you have not invoked the MUTE function
also check that you select a voice that has TTS next to it Text to Speech
Finally check the volume
Nov 26, 2009 | Garmin Nuvi 360 Bilingual GPS Navigator...
Who supplies truck software for garmin nuvi
Trucking software for Garmin is unit specific, you can't add the trucking software into the Nuvi 360. Right now, Garmin's trucking software is offered on the Nuvi 465T.
Nov 18, 2009 | Garmin Nuvi 360 Bilingual GPS Navigator...
Garmin Nuvi 670
Yes, This can be repaired. Please see this link for more information:
http://www.sharc.net/gps_audio_repair.htm
- Jim
Sep 11, 2009 | Garmin Nuvi 360 Bilingual GPS Navigator...
Garmin Nuvi 360 needs CA maps Anywhere for no
There are topo maps for the US for free from this site. We are not affiliated with them, the link is provided as a courtesy only.
http://www.ibycus.com/ibycususa/
Jun 15, 2009 | Garmin NUVI 360 GPS Receiver
Garmin nuvi 360 wont unlock maps
Master reset is after you turn on the GPS put a finger on the left lower corner rightaway and then keep the finger there, wait until it shows up the "Do you really want to start up in maintainance mode"
You are not able to use others nuvi's map on your nuvi 360, as each map must match with the GPS unit ID, to find out your GPS's unit ID, go to "Setting" tab on "System", tab on " About"
Mar 29, 2009 | Garmin NUVI 360 GPS Receiver
Instructions on replacing nuvi speaker
I have given you the proper information as requested. Good luck!
Sep 25, 2008 | Garmin Nuvi 360 Bilingual GPS Navigator...
360 Sound lost
Try listening with headphones. If you have sound there, then your internal speaker has gone bad.
- Jim
Aug 18, 2008 | Garmin Nuvi 760 Handheld GPS Receiver
Garmin 360
have you ever updated the firmware (webupdater @ www.garmin.com)?
Dec 12, 2007 | Garmin nuvi 350 GPS Receiver
GPS Logo
1,663 people viewed this question
Top GPS Experts
Will Halftowaite
Are you a GPS Expert? Answer questions, earn points and help others
