Question about Fisher and Paykel 23 in. DD603H SS Free-standing Dishwasher
Water left in the bottom of dishdraw
When the dishdraw has been through, there is a couple of inchs of water sitting in the bottom of the dishdraw. I have cleaned all the filters as it tells me in the trouble shooting guide in my handbook.
  • Murtle Jun 15, 2008
    Thanks for the solution, it worked a treat.
  • onahll Jul 03, 2008
    I have a new installation. We use the top drawer most of the time. After 2 or 3 wash cycles I find the bottom drawer is filling with water. It is typically1 to 2 inches above the filter. Is this common? Does anyone have a fix?
    Genius:
  • 1,036 Answers
Try running a wash with a dishwasher cleaner product.
There may be a slight blockage of the outlet pipe caused by grease. On a kinked pipe this will be enough to stop it emptying properly.
Make sure the outlet pipe has a plastic former to prevent a kink at the highest point, and that the hose isn't flattened or pulled taut.
If after running the cleaner and checking, there is no improvement at all, the pump impeller may be obstructed or a replacement pump needed.
Hope this helps your problem.
Posted on Jun 14, 2008
Fisher and Paykel twin dishdrawer
there is water in the base setting off the flood sensor, you will need to remove the bottom draw and dry the water up with a towel (make sure the power is off and unplug it from the power point) then you will need to do a bit of testing to locate the cause of the leak, if your lucky the leak was caused by incorrect dish stacking or something too big in the draw
Jan 02, 2017 | Fisher and Paykel Dishwashers
Fisher paykel dishdrawer bottom drawer washes fine leaves water in top drawer
At some point the two drawers individual drain hoses are joined using a "Y' type connector. Check this, and everything beyond this point for restrictions or blockage. It sounds like the bottom drawer is pumping its drain water out normally, but some of that water is backing up to the upper drawer. This is an installation or plumbing problem that is external of the dishdrawers.
Jul 25, 2016 | Fisher and Paykel 23 in. DD-603SS Built-in...
F1 Error code
F1 is flood error. basically water has arrived at the bottom board. you can unplug the dishdrawer, remove the bottom drawer and dry the board at the bottom, maybe with a hair dryer carefully. this will reset the fault, but this is a fault that may appear again. replace the actuators that close the lid of the drawer that is leaking (look for signs of water running our of one of the drawers).
Jul 13, 2014 | Fisher and Paykel DishDrawer DS605FDSM...
How do I reset the f1 flood button . Dd603ss
Not sure if you have managed to fix the F1 problem with your dishdrawer. This is a common problem and occurs mainly due to water leaking into the base of the dishdrawer under the bottom drawer.
But if it is occuring only in one drawer then the power filter at the base of dishdrawer is faulty and needs replacement.
Otherwise make sure the mains power to dishdrawer is turned off. Pull out the bottom drawer and stack in some towels behind it if you can to remove the moisture sitting on the base. The flood switch is located there. Then take a hair dryer and run it down behind the drawer to dry things. Push drawer back and turn power back on. Now if you cannot reach the back of the drawer then you will have to pull the drawer out from its rail. Refer the installation manual for this. See link page 7.
You need to find the source of the lead, Fisher Paykel DishDrawer Installation Instructions ManualsOnline com
Jul 05, 2014 | Fisher and Paykel 24 in. DD603H W Built-in...
My husband put toilet bowel cleaner in the dishdrawers last night to get rid of the hard water deposits. This morning he tried it again and the dishdrawers are constantly beeping and a red light is on. ...
Sounds like an extreme case of oversudsing! The flood switch located at the back on the bottom pan under the bottom draw. To remove bottom draw you need to push the runner clips in on each side and slide back. The runner clips are located on each side at the front just behind the front panel. Once the draw is out, Remove the excess water from the pan (Throughly) and presto!
Jun 29, 2011 | Fisher and Paykel 23 in. DD-603 Built-in...
Dishwasher won't drain. (Kenmore 3380957Rev A) It's been not draining that well for a couple of months, but then a couple of weeks ago, it just won't let the last inch of water out. --I can't see in...
The problem could be the pump, the drain hose or the timer. It will not drain if left to sit. The thing to try first is to put a cup of white vinegar in the machine and let it wash. This may remove sludge or scale blocking the strainer. 2nd take the hose loose at the sink drain and see if it is half clogged with grease or food. Check the hose and the nipple. Last, if it does not work take the bottom off the dishwasher. 4 screws and a plate. look for the pump and see if the hoses are clear. Sears will sell you a manual to repair and test this machine at its Parts Central on line
Jun 24, 2010 | Dishwashers
Water collecting at bottom of dishwasher. screens have been cleaned.
is there water sitting in the bottom of the dishwasher or on the floor? If its sitting in the bottom of the dishwasher, most likely the discharge pump isn't working properly and not emptying all the water out. The pump will usually run for an extended time to pump the water out until it finally times out and you're still left with water in there...
Sep 09, 2009 | Dishwashers
Leaking F&P dishdrawer
Have you take the lid seal out to inspect it.
1- If the Lid actuator is not working right, it will cause the the seal distorted.
2- You also have a problem with the Lid actuators.
3-There are 2 on the left and the right, one of them bad can cause your lid seal replaced 6 months ago.
4- Good news for you that they can be sold only a pair. When you have them replace both.
The part number is 528113
Jul 02, 2009 | Fisher and Paykel DD605SS Stainless Steel...
My f & p dishdrawer model DD603 has fault code F1:
Yes, you need to gain access to the inside bottom panel of the dishdrawer and drain/dry the water in the bottom panel. When all of the water is gone the polystyrene block will lower and turn off the flood system. You then need to find the reason the unit flooded and rectify it or the unit will just do the same thing again.
Mar 15, 2009 | Fisher and Paykel 23 in. DD-603 Built-in...
I'm Not sure of the model number, Fisher & Paykell double draw dishwasher
My dishwasher's doing exactly the same thing. What was the solution?
Apr 30, 2008 | Fisher DD603FCSS Dishwasher
Fisher and Paykel 23 in. DD603H SS Free-standing Dishwasher Logo
380 people viewed this question
Top Fisher and Paykel Dishwashers Experts
Brian Coughlan
Owen Barnes
Are you a Fisher and Paykel Dishwasher Expert? Answer questions, earn points and help others
