Question about Brother LS-1520 Mechanical Sewing Machine
Bicor vx1005 ...thread keeps bunching
When I try to sew the thread keeps bunching up on the bottom of the fabric. I've also, had a problem with the thread breaking. Underneath Bobbin Thread keeps bunching. I tried adjusting tension, but it is not helping.
  • 10 more comments
  • Anonymous Aug 19, 2008
    When I try to sew the thread keeps bunching up on the bottom of the fabric.The Bobbin Thread keeps bunching. I tried adjusting tension, but it is not helping.
  • Anonymous Nov 10, 2008
    Same problem...... oiled and cleaned.... but thread keeps breaking
  • Anonymous Nov 19, 2008
    thread bunches up even after a couple of stitches
  • Anonymous Dec 24, 2008
    Same problem with thread bunching underneath the fabric and thread breaking on top. Tension problem....
  • Anonymous Jan 26, 2009
    Thread bunches up on bottom when I try to sew. What is wrong can you show me how to remedy this problem/
    thanks so much .yanny
  • Anonymous Feb 03, 2009
    bobbin keeps bunching
  • fpfarric1 Mar 30, 2009
    When I try to sew something the thread bunches on the bottom and there is TONS of thread collected there when I move the fabric away from the machine. The thread often breaks and the bobbin sticks. I talked to a sewing shop and they said it may be a timing problem.
  • Anonymous May 12, 2009
    The bunching - it is so frustrating!
  • Anonymous Mar 18, 2014
    Bottom thread bunching up
  • Anonymous Mar 25, 2014
    thread keeps breaking and thread gets jammed on the under side of fabric .i dont think i have it threaded right
  • Anonymous Mar 26, 2014
    problems with bobbin threading
Try a different bobbin. Look for one that is a little narrower. I had the same problem and changing to a narrower bobbin fixed it.
Posted on Mar 29, 2009
  • Brother Master
  • 1,388 Answers
Look at my tutorial HERE, that is why I wrote it !
Posted on Dec 08, 2011
Try loosening your tension. For almost all of my projects, Mostly fleece because it's for Sugar Gliders, I have my stuff set to thread length 1 - 2 and my tension at 4 - 6. Granted, mine is a singer tradition. All I can Say is try it, what's there to lose? LoL!!!!
Posted on Mar 15, 2009
Where do you chnge the tension at? which dial?
Posted on Jan 20, 2010
I need needle threder lever
Posted on Aug 10, 2008
I NEED A BOBIN AND ALEAVER THAT RAISES THE NEEDLE FOOT
try these sites and see if they can help you,,you'll have to call or
email them
sewvacdoctor.com
a1sewingmachines.com
Jan 16, 2013 | Brother LS2020 Sewing Machine
Start to sew and it doest stitch & fabric gets bunched up on the right looper
I take it this is a serger from the fact you have a looper. Try changing which looper thread is on top when you thread it. Mine jams if they're not done just right. BTW, the easiest way to thread a serger once you've got it once is to tie the new thread to the old and pull it through.
Hope this helps.
Sep 10, 2012 | Sewing Machines
Thread keeps bunching on the bottom of thick material
try a different needle
here's a link to a free manual from singer
http://www.singerco.com/uploads/download/1199_8770-efs.pdf
some machine can't handle thick fabric & some can
rethread the machine top & bobbin
clean under the needle plate & in the bobbin area
make sure the thread has not come off the thread take up lever
Aug 20, 2012 | Singer Curvy 8770 Electronic Sewing...
Thread keeps on bunching up on the bottom side of the fabric
try changing the needle
check the top thread tension to make sure it's not to loose
rethread the machine top & bobbin, make sure the bobbin is wound
correctly & inserted correctly into the machine
Jul 11, 2012 | Brother CS6000i Computerized Sewing...
Difficulty threading bobbin- thread bunches under fabric. vx1005
I would suggest to check the needle to see if it's damaged
also check to make sure the machine is threaded correctly,,that the thread is in every thread guide
also some sewing machine have a problem with the top thread coming off the thread take up lever
also I would check the bobbin area for lint or any loose threads
also check the top thread tension to see if it's set correctly
also the hook race cover & hook need to be taken out & cleaned & then put back in
some machine have had problems with the hook getting grooves worn into them & need to be fixed or replaced
Oct 08, 2010 | Brother LS-1520 Mechanical Sewing Machine
The tension is off ?? bottom thread bunches
Sounds like it could be! Probably worth trying to readjust it. Are you using a fine fabric too? That can cause bunching.
Apr 05, 2010 | Kenmore 15516 Mechanical Sewing Machine
How do you thread bobbin for Bicor VX1005?
Look through these threading guides for a Brother that has the same features. http://www.sewusa.com/Sewing_Machine_Threading_Diagrams.htm
The above site has a manual, but I not a threading guide. Unless it is the same as another model.
Mar 07, 2010 | Brother LS-1520 Mechanical Sewing Machine
Thread bunching underneath fabric on Bicor VX1005 mahine.
The impulse is to blame the bobbin, because that's where the thread bunches. But the problem is probably with the top thread tension. The tension is too loose, allowing the bobbin to help itself to all the thread it wants. Retrace the path of the thread from spool to needle and see if you missed anything. The instructions in my VX1005 manual are not clear. I had to try a couple of paths before I got it right. Make sure the spring in the tension disk setup is moving freely. You should feel a fair amount of resistance when you pull on the needle thread. Hope this helps.
Terry
Nov 11, 2008 | Bernina Activa 130
Brother LS-1520 Mechanical Sewing Machine Logo
2,210 people viewed this question
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
