Question about EliteGroup P4VMM2 Motherboard
Networking Problem Hello.. I have a problem which involve my onboard network adapter. Im setting up my internet connection, when im plug in the cable it says network cable unplugged.. i have already checked the hardware in the device manager and it says working properly. could it be a problem with the driver or something else? my internet provider cant set up if the problem is not solved. Please help. In needed, zack
    President:
  • 1,314 Answers
It is not uncommon for the network adapter to become faulty and stop working. Since you've checked the cable and it is still listed in device manager as working properly, I would add a PCI ethernet port to your computer, then disable the faulty one in device manager. They can be picked up for around $15 locally and even cheaper on the web.
Posted on Jun 14, 2008
How to know if my computer has internet access?
heres what to do... go to your CONTROL PANEL then
NETWORK AND INTERNET CONNECTIONS then NETWORK CONNECTIONS . (If your in classic view, click on NETWORK CONNECTIONS.)
on your NETWORK CONNECTION you will see there if your LAN/WLAN is connected.
if you want to know if you are connected even without looking in your NETWORK CONNECTION do this steps.
  1. in your NETWORK CONNECTIONS, right click your LAN/WLAN.
  2. in the menu that will appear, choose PROPERTIES.
  3. a windows will popup, below the window you will see two sentences with a blank checkbox in the side that say.
- Show icon in notification are when connected - Notify me when this connection is limited or no connectivity 4. Check the 2 boxes beside it, just like the photo below. heifentrixx_2.jpg 5. CLick OK. and thats it.
Goodluck. Hope it helps.
Jun 29, 2011 | Computers & Internet
Im programing my x box 360 it needs me to program the wpa net work to get this new x bow to work. im new at this expain things very clear , thanks
Follow these instructions to set up the Xbox or Xbox 360 connections to a wireless home network. These instructions assume the wireless router is already installed with a working Internet connection. If after following these instructions you are unable to network your Xbox with the wireless router, see - Connecting Xbox to Wireless Networks - Why Things Go Wrong
Here's How:
  1. Connect the appropriate wireless network adapter to the console. On the Xbox, a Wi-Fi adapter that connects to the Ethernet port (sometimes also called a wireless network bridge) must be used. Alternatively, the Xbox 360 is also designed to work with certain Wi-Fi game adapters that connect to a USB port.
  2. Turn on the console and navigate to the wireless settings screen. On the Xbox, the menu path is "Settings -> Network Settings -> Advanced -> Wireless -> Settings" On the Xbox 360, the menu path is "System -> Network Settings -> Edit Settings."
  3. Set the SSID (network name) on the Xbox to match that of the wireless router. If your wireless router has enabled SSID broadcast, the SSID name should appear pre-selected on the Xbox display. Otherwise, select the "Specify Unlisted Network" option and enter the SSID there.
  4. Specify "Infrastructure" as the Network Mode. (Infrastructure is the mode used by wireless routers.)
  5. Set the Security Type to match that of the wireless router. If your router uses WPA encryption and the type of adapter connected to the Xbox does not support WPA, you will need to change your router settings to use WEP encryption instead. Note that the standard Microsoft Xbox 360 Wireless Network Adapter supports WPA while the standard Microsoft Xbox Wireless Adapter (MN-740) only supports WEP.
  6. Save your settings and verify the network is functional.
    On the Xbox, the Wireless Status screen displays whether a connection has successfully been made with the wireless router, and the Connect Status screen displays whether a connection has successfully been made through the Internet to Xbox Live.
    On the Xbox 360, use the "Test Xbox Live Connection" option instead.
Tips:
  1. Even when your wireless connection between the Xbox and the router is working perfectly, you may still experience difficulty connecting to Xbox Live. These issues can be caused by the quality of your Internet connection or the firewall and Network Address Translation (NAT) settings of your wireless router. Additional troubleshooting may be required in these areas to achieve reliable Xbox Live connections.
Feb 27, 2011 | Computers & Internet
PB Diego FX Foxconn Motherboard MCP73M04 P8 Manual Needed
check yhe board for swollen caps around the processor if the tops of the caps are not flat there bad and the board is done
Jul 10, 2010 | Computers & Internet
The on board ethernet adapters were damaged so i purchased an ethernet card Realtek 10/100/1000 however it gives me internet for all of 30 seconds until i try to access a website then it dies and loses...
There shouldn't be any issues if the network connection worked with the integrated NIC. Maybe you just managed to purchase a defective replacement card. The other possibility is that you didn't disable the onboard network hardware in the computer BIOS settings. There may be some conflicts since the motherboard is trying to address both of them. Make sure the onboard NIC is disabled, and try another PCI card if you still have problems.
Apr 14, 2010 | ASUS A8N-SLI Premium Motherboard
Need ip address for syrens, not sure if i remember right: 192.168.1.1???
Hi Stephan,
the ip address of your router by default should be "192.168.1.1". to check if the ip adress of your router here's the solution :
  1. go to control panel > network and sharing/networking >change adapter settings
  2. then you'll see your local area connection
  3. right click on it>properties
  4. double click on (internet protocol tcp/ip) "tcp/ipv4 in windows vista/7
  5. the select "obtain ip address automatically" & "obtain dns server464142c.jpg automatically" click ok and click ok for the other window
  7. the dns server ip show should be your router ip adress
  8. open your web explorer and type in your router ip an press "enter" you'll get your router configuration where you'll be able to change the default ip.
I hope that it will help & don't forget to rate
Kind regards
Feb 14, 2010 | Sea and Sea Syrens OnBoard WiFi...
Onboard network card
connect your lapto pdirectly to the modem by bypassing the router by directly connecting the ethernet cable if that works that means there is a problem with the router or u can use a usb wireless adapter to connect to the internet let me know ifany problems
Sep 17, 2009 | E-Machines EMA IMPERIAL GV (845GV) TG3...
Need Network adapter
Install the nForce 2 motherboard drivers. The onboard network controller drivers are part of the package.
Jan 29, 2009 | FIC K7MNF-64 nVidia nForce 2 Socket A mATX...
Network Card
Yes the network card is the same ethernet card. If your intel pro/100 is onboard try to re install the driver from the motherboard drvier. Check also in the manager device it the network device have a complex to the other device. Follow this, Click START then RUN type DEVMMGMT.MSC then enter check if the network adapter have a yellow question mark. If you found the network adapter right click and uninstall it.and click the ACTION and click SCAN FOR HARDWARE CHANGES. After the installation finished try to connect to the internet. If still the same even you input the correct ip in the network configuration. Buy a new LAN card it's not expensive, because usually the onboard lan is easy to damage or not working properly you can installed and configured it but you cannot connect to the internet.
Apr 15, 2008 | Acer AOpen AX4BS-V (91.89J11.001)...
Graphic Card
Page 71 of this manual will show you how.
http://dlsvr03.asus.com/pub/ASUS/mb/socket775/P5VD2-MX/e2505_p5vd2-mx_update.pdf
Jan 03, 2008 | ASUS P5VD2-MX SE Motherboard
Hard network
Howzit
networking you need nerworking cables which connect into the slots on the back of the motherboard the plugs for the network cables look exactly like those of a telephone cable and thus the plug female slots on the motherboard look like those on the telephone box. Plug these cables connecting the PCs you wish to network . secondly, you need network drivers for your motherboard you can download these from the manufacturers site. you should now be set to go depending on whether your drivers and Hardware is compatible with your Operating system
Let me know how you do (Networking can get complicated take it step-by-step and let me knwo if you have more questions)
regards
Nov 19, 2007 | EliteGroup P4VMM2 Motherboard
EliteGroup P4VMM2 Motherboard Logo
73 people viewed this question
Top EliteGroup Computers & Internet Experts
Brian Sullivan
Brian Sullivan
Mark Taylor
Mark Taylor
David
David
Are you an EliteGroup Computer and Internet Expert? Answer questions, earn points and help others
