Question about Panasonic CQ-DF200U CD Player
Subs Is there any possible way to hook up my subs to this cd player
    Genius:
  • 1,224 Answers
Yes several ways
examples
amps
speaker wire direct connect i did this for 6 years on my 12's it sounded good but when i put an amp on it
it sounded better
Posted on Jun 14, 2008
Shuts off when the volume gets turned up didnt do this wen new
A mono amp usually can handle only two 4 ohm subs. You see when you hook up two subs in parallel it drops the ohms too 2 ohms and 3 in parellal drops it to 1 ohms overheating the amp and cause power failure. Unless you bought a Mono amp thats 1ohm stable. But still I've seen cheap 1 ohm stable amps not last long. Also possible your subs are fried too check them with a multimeter and measure each sub ohms.
Apr 06, 2010 | Kenwood KDC-BT838U Car CD Player
Hey I have an Alpine CDA-9851 CD Player and was wondering how to hook up my two 10" Kicker subs, since there is no subwoofer connection on the back of the player.
First to start you need an amp something that is a little stronger than your subs. What you want to do is 'T' off your speaker wires into RCA's to hook up into the amp. There is a device you can buy or you can cut some RCA cables. There are a few down sides to do it this way because as you turn up the volume the Subs will get louder and start to distort a lot faster than hooking up proper. The best way to do it is to get a deck with RCA sub outputs. Good Luck
Mar 25, 2010 | Alpine CDM-7874 CD Player
PIONEER 300 WATT CAR STEREO AMP WIREING HOW TOO
depending on how many channels the amp is, you may not be able to hook everything up to it.
usually you have a separate amp for subs. 4 channel amp for the speakers in the car, and a mono amp for the subs.
To hook them all up to the same amp you would need an amp with 5 channels. It wouldn't work out right.
If you have a mono amp its only for subs.
If you have a 2 channel you can either hook it up to the rear speakers or bridge them to mono to run the subs.
you need a channel per speaker basically.
Dec 15, 2009 | Pioneer DEH-P2000 CD Player
I having problems getting my subs to play through the cd player!!
More than likely you have hooked up the power anttena wire as your remote turn on. So hook up the OTHER blue wire to feed your amplifier, and problem solved.
Aug 07, 2009 | Clarion DXZ385USB Car CD/ MP3 Player
No sound to the subs
Possible solution: Check to make sure your ground connection is connected to metal that is NOT covered in paint. This is not a solid connection and can ruin your amp over time. Simply scrap away the paint and re-connect. This was a problem i ran into recently.
Jul 27, 2009 | Sony XPlod CD Player w/MP3 Playback...
No sound from my front and back speakers in my van ive got subs
Make sure that when you hooked up your 4 channel amp to the remote turn on lead it is the same as the sub. Only hook amps to the Blue w/ white strip. The solid blue is power antenna lead and will lose power when on CD, ipod etc and only stays powered when the Tuner is on. Hope this fixes your problem.
Jun 03, 2009 | Kenwood KDC-MP428 CD Player
Alpine subs not hitting hard
could it be as simple as bass boost??? maybe you have the subs hooked up wrong... have to have the ohms right.....hopefully this helped
Jan 26, 2009 | Pioneer GM-X962 Car Audio Amplifier
Panasonic CQ-DF200U CD Player Logo
51 people viewed this question
Top Panasonic Car Audio & Video Experts
xxxxxx xxx
Are you a Panasonic Car Audio and Video Expert? Answer questions, earn points and help others
