Question about Kenmore Washing Machines
I know its not the switch making a racket but does pump water out not spinning i pretty sure it is a belt but i havent had this one apart yet i know its really simple but its been a long day and it been a while since i had one apart how do i get it apart so i can see the problem ??
  • Dan Webster
    Dan Webster Nov 04, 2010
    Please submit a model number
  • Kenmore Master
  • 2,699 Answers
The older kenmore washers don't have belts in them,it's the motor coupling that's broke,remove the two screws that hold down the top console,if you have the plastic corner pieces,pop then off and the screws are under them,flip the console up,then with a screw driver pop the two metal clips and in between them unplug the lid switch harness,open the lid,grab the frame and tilt it back and pull back and remove the frame,down the bottom,remove the two clips and slide off the pump,then remove the two screws and clips and slide off the motor and on the back is where the coupling is,remove the broken coupling from the motor shaft and off the tranny shaft and tap on the new one,slide the rubber onto the tranny piece and then slide the motor back on ,put it back together and your good to go,next time send the model number
Posted on Nov 05, 2010
Wbb4500g0ww im128843g initially wouldnt spin, did drain now wont fill, only aggitate without water, indicator light for "fill" single flashes when load is started then only the wash light...
Thanks for choosing FixYa and welcome. You need to check your water pump. Check the belt. Make sure it is not clogged. Make sure it is working. The pump is what controls water into the washer. If your washer doesn't drain or spin, you may read and learn what parts may cause this. First, you will want to check your water pump. You need to make sure it is working. Make sure you check the belt on the pump. Make sure it is not broken or loose. Also, make sure your pulley is not stuck in place. Sometimes, they will stick or barely turn at all. If this is the case, you will need to replace it. If the pump, pulley, and belt are working, make sure your motor is working. You should be able to hear it if it is. If it isn't, check your lid switch. The lid switch can cause the motor to not work. It may need adjusted. If not, go ahead and change it. A bad lid switch may cause the washer to not work at all. Now, if your pump is pumping and the washer still won't spin, you will want to check your belt and clutch. Once again, the belt may be broke or loose. Check to make sure your clutch is not worn also. This may be a case of a bad lid switch again as well. You could have a bad drive motor. This is what controls spinning, draining, and agitation. You could have a broken motor coupler. Over time, they will go bad and need replaced. It is possible that your transmission is slipping or damaged. And lastly, you could have a bad basket drive ir spin bearing. This is what allows the inner tub to move. If this is the case, you will probably hear loud sounds or loud banging. I want to thank you for reading and I hope this helps you
Apr 17, 2011 | GE WBB4500EWW Top Load Washer
Wont spin fill or drain i looked at lid switch it clicks the rubber assembly looks good. motor just hums when turned to spin. also need to know how to remove cover
Thanks for choosing FixYa and welcome. If your washer doesn't drain or spin, you may read and learn what parts may cause this. First, you will want to check your water pump. You need to make sure it is working. Make sure you check the belt on the pump. Make sure it is not broken or loose. Also, make sure your pulley is not stuck in place. Sometimes, they will stick or barely turn at all. If this is the case, you will need to replace it. If the pump, pulley, and belt are working, make sure your motor is working. You should be able to hear it if it is. If it isn't, check your lid switch. The lid switch can cause the motor to not work. It may need adjusted. If not, go ahead and change it. A bad lid switch may cause the washer to not work at all. Now, if your pump is pumping and the washer still won't spin, you will want to check your belt and clutch. Once again, the belt may be broke or loose. Check to make sure your clutch is not worn also. This may be a case of a bad lid switch again as well. You could have a bad drive motor. This is what controls spinning, draining, and agitation. You could have a broken motor coupler. Over time, they will go bad and need replaced. It is possible that your transmission is slipping or damaged. And lastly, you could have a bad basket drive ir spin bearing. This is what allows the inner tub to move. If this is the case, you will probably hear loud sounds or loud banging.
Mar 13, 2011 | Kenmore 22642 Top Load Washer
WASHING MACHINE TUB HAS STANDING WATER!! WATER WONT DRAIN OR SPIN????
Thanks for choosing FixYa and welcome to the site. If your washer doesn't drain or spin, you may read and learn what parts may cause this. First, you will want to check your water pump. You need to make sure it is working. Make sure you check the belt on the pump. Make sure it is not broken or loose. Also, make sure your pulley is not stuck in place. Sometimes, they will stick or barely turn at all. If this is the case, you will need to replace it. If the pump, pulley, and belt are working, make sure your motor is working. You should be able to hear it if it is. If it isn't, check your lid switch. The lid switch can cause the motor to not work. It may need adjusted. If not, go ahead and change it. A bad lid switch may cause the washer to not work at all. Now, if your pump is pumping and the washer still won't spin, you will want to check your belt and clutch. Once again, the belt may be broke or loose. Check to make sure your clutch is not worn also. This may be a case of a bad lid switch again as well. You could have a bad drive motor. This is what controls spinning, draining, and agitation. You could have a broken motor coupler. Over time, they will go bad and need replaced. It is possible that your transmission is slipping or damaged. And lastly, you could have a bad basket drive ir spin bearing. This is what allows the inner tub to move. If this is the case, you will probably hear loud sounds or loud banging
Feb 22, 2011 | Samsung WF328AA Front Load Washer
Maytag washing machine mah5500Bmodel# put on spin cycle drains out water but wont spin basket
Feb 20, 2011 | Maytag Neptune MAH5500B Front Load Washer
Car is overheating. I think the wrong tensioner pulley is installed. we bought the right one according to the parts store. if the tensioner pulley is not providing the right tension on the belt can it...
First off if your belt is slipping enough for the water pump to not function it should be making one heck of a racket.
look at the belt (carefully and with protective wear) and see if the water pump pulley is spinning when the engine is running.
more likely your culprit may be a thermostat or if when the belt came off the last time the vehicle overheated, it may have cause internal damage, head gasket etc.
Jan 01, 2011 | 2001 Dodge Durango
My machine fills and agitates but doesn't empty or spin? How can I be sure it's the pump and not something else?
I'm pretty sure it isn't the pump.
Bad pump= no pumped water Broken belt=no spin or pumped water
The belt has probably broken and is laying in the bottom of the machine.
Aug 23, 2009 | GE Washing Machines
Washer has started making a heck of racket during the drain/spin cycle. It's not consistant. Two loads may go thru ok no noise. A third load and it will make a very loud grinding chain like noise.
Grinding noises are most often the result of a failing water pump. The noise can increase during the spin\drain cycle due to the added load on the pump. Although less likely it could also be the drive belt rubbing on something or a pulley bearing failing. If you are able to locate and remove the drive belt, you should be able to turn the water pump pulley by hand. If the pump does not turn smoothly it is bad.
Aug 06, 2009 | Maytag Washing Machines
Maytag top load washer won't pump water out=intermittent problem
If your lid switch was the problem I dont think (and I might be wrong) that it would spin in the first place.
Your pump may have a separate belt and it could be loose or worn out but this is on older models. The pump may not be turning or turning and not pumping. The pulley may be turning on the shaft and its not pumping. Give it a spin and see if you see it turning inside. If not replace it.
The motor and timmer sounds good because of the "spin" you discribed. So we are left with the pump or a filter if it has one.
Look in the lower section find the pump front right hand corner I believe. Trace the hose back up to the tub above nothing in between and you have eliminated the filter. I filter could be any shape but will either attach with 2 hoses or 1 hose and attached to the side or bottom of the outer tub.
I think your pump is probably stopped up, strings and lint especially if you have some older rugs, towels, and rags that are shedding or coming apart. You can try and clean it pretty easily Unplug. Then remove it and look inside it. Catch all the water you can and keep another towel close by. Examine the water. Looking for lint and the like. If its pretty clean looking and not turning freely look for signs of something wrapped up inside it.
Hope this helps. Please rate me accordingly and good luck.
Mar 10, 2009 | Maytag Neptune MAH5500B Front Load Washer
Washing Machines Logo
29 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
