My pressure is low on my baxi boiler have attached feeder to pipes and turned valve to introduce water but the pressure is not changing, what am I not doing?
  • 320 Answers
Does the water pressure before the heater is strong? if so then there is a problem with the entrance valve.There might be some object that blocks the entrance of water or the valve itself is not working properly.
Posted on Nov 04, 2010
Water pressure low on BAXi Combi 80e boiler
open bottom tap first then open top tap when water is to the leval you want turn off top tap then bottom tap.
Feb 03, 2013 | Heating & Cooling
Baxi duo tech he a range pressure rises from 1bar to 3bar when fired up and when off for say overnight pressure to low and have to re pressurise
Check for water leaks on boiler and system check to see if pressure relief valve is not passing .when boiler is off
Jan 29, 2013 | Heating & Cooling
Came home after a weekend away and central heating not working. Programmer not turning heating on (honeywell st6400c) but the boiler (a sentima ht 60l) looks like it has a fault. The mains light us on but...
Possible cause of lockout: boiler low water level. If you have a combination temperature/pressure gauge, it should read approximately 12 psi when the boiler is cold. When it runs, it will be approximately 22 psi. If the pressure is low feel the inlet water supply piping. Open the manual feeder valve. The cold water coming in will verify that there is no obstruction to the water flow. You may have "dirt" in the line. You may have a defective water pressure valve or check valve. Another thought. Make sure your AIR SEPARATOR is functional. Remove the cap and depress the valve. You should see water. If air comes out, continue to"bleed" the AIR SEPARATOR. You may haven't to replace the A/S.
Jan 28, 2013 | Heating & Cooling
Baxi boiler 80E low pressure on boiler how to fix it?
Silver flex hose may be the (correct) filling loop. There may be a valve at each end of it, maybe just one at one end.
Open the single valve slowly and LISTEN for the sound of water entering the system, and LOOK for signs of the pressure gauge rising.
On the dual valve version open the first, then open the second slowly as above. Close both valves when pressure is adequate. Adequate is determined by the specifics of your system, but note that more pressure DOES NOT mean better showers, etc.
It should only take a few seconds to top-up, any longer indicates a significant loss of fluid from the system.
Jan 28, 2013 | Water Heaters
Baxi duo-tec boiler - when water comes on flame roars up. When i put the heating on the flames roar for 5 minutes then die down.
is the boiler a combi if so have you checked the pressure. it needs to be at 1.5 bar 2 bar at the most . also check that the heat the boiler is producing is completeing the circuit on the heating if you have access to the pipe work there should be 2 or 3 22mm copper pipes. now turn the heating on and check which one is getting warm. the one that is is your flow and in about 2 to 3 min there should be one more pipe getting hot let me no if this is the case
Oct 27, 2012 | Universal 900MM Super Thermocouple Baxi...
Hi wanting to know is it dangerous to keep filling the preshireb up & is it dangerous to do this when the radiators warning up,.... had a bit of drips on the raditor pipes just bled them'' :)...
Are you saying the 3/4 inch valve is dripping and you need to keep topping up the water to maintain the pressure?
If you do this it is "safe" but you will introduce more oxygen in the system with the fresh water.
This oxygen will corrode the radiators and possiblty the boiler heat exchanger depending on how much water you are introducing.
Change the Pressure reflief valve. This is a £10/$ 10 part and will save your system in the long run.
Dec 20, 2010 | Watts 3/4 Pressure Relief Valve
Baxi 130HE losing pressure
I would go with the valve first cheaper, then see if it still doing the same thing
Mar 04, 2010 | Heating & Cooling
I have a baxi 130he which loses pressure and I have to top up once a day. The copper pipe outside which I believe is an overflow is constantly dripping. Boiler runs fine central heating and hot water.
Hi the pipe out side is the pressure relief valve change the valve or it has something stuck on the seating , changing it will stop the pressure drop
Mar 03, 2010 | Heating & Cooling
Baxi combi boiler 80e safty thermostat light on
baxi boiler relief valve blows off when heat is turned on when hot water is working it is fine
Oct 15, 2008 | Protech Systems FasNSeal FSWMKE4 4" Vent...
Baxi 105 he
on the pipework near the boiler there should be a silver flexi hose connecting the two copper pipes ...this is called a filling loop there sould be taps on the filling loop turn on by moving the black plastic taps do this slow ..at the same time look at the pressure gauge on a baxi do not go over 1 bar...............
warning ..if the boiler has lost pressure where has it gone..is there any leaks anywhere..if it persist contact a engineer
Jun 06, 2008 | Heating & Cooling
Heating & Cooling Logo
Top Heating & Cooling Experts
Paul Carew
Marvin
Marvin
john h
