Question about Saeco Magic De Luxe Espresso Machine
The machine just started making a noise (like a gear slipping) and the bin that catches the used grinds has the shoot locked in the down position. Therefore, the bin cannot be removed.
  • 1,089 Answers
Hi
That sounds like you have a broken brew drive. If the doser lever is pushed all the way to the positive you can overcharge the brew unit and the gears cannot compress the coffee. Something has to give. Some of the time it will just dump the coffee without making anything. you get dry grounds. Some times it will just break the gears. Sounds like yours is the latter.
Posted on Nov 05, 2010
Can't replace coffee grind drawer after emptying
That would normally mean that the brewing mechanism is not in the at rest or start of cycle position. Take the bin off the tray and see if you can slip the bottom tray back in now. Turn the machine on, let it run through the start up process and when completely stopped see if you can now remove tray and fit the spent grounds bin back where it should be.
Aug 25, 2015 | Jura Capresso Impressa E9 Espresso Machine...
My 6qt Kitchenaid stand mixer started making a grinding noise and beater bar keeps stopping. When I put it gently with my finger, it begins turning, only to stop again and make that grinding noise. It is...
They seem to have a plastic gear built in as protection for overloading (prob). When the machine counters to much resistance that gear will strip its teeth causing the machine to not be able to turn, that it what seems to be the grinding problem. If it is not the plastic gear then it another gear that is "stripped(of its "teeth") I hope your problem is not a severe, but if your mixer is "locked up" then at least you found the problem.
Jan 12, 2010 | KitchenAid KSM150PS Artisan Series Stand...
My 12.5 hp yard machine by MTD is not going into gear and there is no grinding
my yard machine 42" ride on is making loud grinding noises coupled with slipping and jerking wile driving. could this be a loose belt or is the rear axle breaking ?
Nov 25, 2009 | Mtd Garden
When i try to start the car it makes a funny sound and wont start it sounds like something is not catching
Good indication of a bad starter. Is it just clicking or is it a grinding ugly noise?. The second is definately the starter.
Nov 01, 2009 | 1997 Chevrolet Cavalier
I have a Frigidaire dryer model FDE437GHS0 It has been working fine til this morning. If I turn the timer switch to time dry and push the start button it sounds like the timer is turning(or the gears are)...
IT SOUNDS LIKE THE TIMER IS BAD. IF THE TIMER MAKES NOISE IN ANY POSITION AND GRINDS THE LITTLE TIMER MOTOR OR THE TEETH ON THE MAIN GEAR IS SLIPPING
Aug 11, 2009 | Dryers
The grinder is making a noise and not grinding beans
if the gear is slipping we need to know how it is helld on the shaft. Look between the teeth on the gear to see if there is a set screw. If so, using the proper tool, loosen it and try to remove the gear. Then, go to a auto parts store and buy a small tube of loc-tite thread lock, put some on the shaft and slip the gear back on, then tighten the set screw firmly. The loctite will set up in an hour and fully dry in about 3 hours. Good luck and keep me informed please.
Jun 21, 2009 | Cuisinart Brew Central 12-cup Coffee Maker
Tines wont turn /disengaging type grinding noise
its possibly the gears inside the box they are spider gears & wearout on those they are great machines but the gear drives are weak most of the time or the belt could be slipping
Jun 05, 2009 | Troy Bilt, Tuffy, Rear - Tine Tiller, 4.0...
When you use the sewing machine it makes a grinding noise
It sounds as if a pin or some small object may have slipped down and gotten lodged in the workings of the sewing machine. This could become a serious issue if it is not remedied. Remove the bobbin area cover under the sewing foot to look inside. If the noise is coming from one of the completely encased areas on the right side of the machine, there may be a problem with the gears rubbing against each other (disalignment). If this is the case, and the machine is still under warranty, I would return it to the place where you purchased it. If not, I would try to take a look and see if anything is lodge in the workings. Grinding noises are not good when it comes to machinery.
May 03, 2009 | Singer 8280 Mechanical Sewing Machine
Loud grinding noise when paper is feeding through machine
Mine was indeed a gear problem. Took off the top cover and poked around. Found two areas that may have caused the grinding.
1. The lower roller shaft had slid to the left out of it's groove. By removing the handset cradle (3 release tabs are accessed underneath the toner hatch.) I could loosen the "gear box" (a black contraption with all the gears inside) and then snug the bottom roller into proper position.
2. I removed the "gear box" to look around. Don't know if I dislodged one of the gears while doing so, but noticed one was dislodged ;-)
This required opening up the gear box by removing 2 screws and lifting off the motor. Then i could get at a gear that had come loose from a claw sort of piece. Note: the teeth of the loose gear needed to be on the motor side when sliding it back into the claw thingy. It seems to use a metal clip for friction control and perhaps proper spacing.
I noticed "some" wearing of gears, but doubt this is an issue. This machine has been used VERY hard for years and now, just by re-aligning things, it works once again.
My googling barely found any mention of troubleshooting this machine, so I shudder to think what finding parts would be like.
Jan 19, 2009 | Brother IntelliFAX 2800 Laser Fax
Paper Jam...grinding noise
The print head lock is probably not retracting. Look for the white plastic block that pokes through from the paper feed side just in front of the head. Push it in with your finger and move the head to the middle by hand. Now turn the machine on. Then turn it off using the correct method. Then turn it on once more. If it starts grinding again, you screwed the feed mechanism when tugged out the jammed paper (probably pulled it backward through the feed instead of making it go forward and out the correct exit). If this is the case, you may as well bin it. If it in warranty, you can try to get a claim for repair.
Jun 15, 2008 | Epson Stylus CX3200 All-In-One InkJet...
Saeco Magic De Luxe Espresso Machine Logo
401 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
eyecam
Marvin
Marvin
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
