Question about Intermatic T101 - 24 Hr. Dial Time Switch - NEMA 1 Indoor Steel Case - Gray
Time wheel stopped moving. - Intermatic T101 - 24 Hr. Dial Time Switch - NEMA 1 Indoor Steel Case - Gray
You posted under the Intermatic T-101
Troubleshoot:
Check if manual override turns Load on and off
If manual override snaps clean and crisp, and Load operates correctly, then you can replace the clock motor.
If manual override does not work very well, then you can buy another T-101 and swap out insides without changing box.
If manual override snaps clean and crisp, but Load does not come on, then check your electricity at breaker and check if wires are tight inside the timer.
Clock Motor
T-101: replace with T100series 120Volt clock motor
T-103: replace with T100series 120Volt clock motor
T-104: T100 series 240V clock motor
Where to buy clock motor:
http://www.grainger.com/Grainger/timer-accessories/timers/electrical/ecatalog/N-8hi
How to replace clock motor:
Turn off power.
Take a photo of your wiring so you have a record of how wiring looks.
There are two small white wires that go to clock motor.
Inside box, there is a release lever located top of box.
Push release lever up and timer mechanism tips out.
Lift mechanism up slightly, and then tip all the way out.
Clock motor is held by tiny screws or tiny star-screws
Swap motors.
Attach clock motor wires on front terminals in exact location they were connected before.
Turn screw terminals very tight against copper wire.
Posted on Nov 04, 2010
Tip
Sewing machine balance wheel stops.
Hold the wheel with one hand, turn the stop motion screw towards you. Place both feet upon the treadle and turn the balance wheel towards you at the same time allowing the feet to move freely and lightly with the treadle. Continue this until everything moves freely and easily. Do this until the machine can re-start without the balance wheel turning in the wrong direction.
Then tighten the balance wheel. Then place cloth under the presser foot then lower presser foot with the lever.
on Jan 18, 2010 | Sewing Machines
Telescopic steering wheel wont tilt
Telescopic steering wheel stopped moving - MBWorld.org Forums
mbworld.org/.../225749-telescopic-steering-wheel-stopped-moving.html
Jan 9, 2008 - Telescopic steering wheel stopped moving ... If it won't move at all, and you don't even hear a motor, it could be a fuse; check your fuse diagram ... Steering wheel adjustment motor gone bad?
Jan 28, 2008
HOW TO: Fix power steering column that will not move up and ...
Jul 12, 2007
More results from mbworld.org
Fixing the Power Steering Wheel of a Lexus LS400 - YouTube
? 2:15
https://www.youtube.com/watch?v=NP8YmnGRXWU
Jan 4, 2012 - Uploaded by AutoTech USA
If your power steering wheel is no longer working; moving up and down, back and forth, and when you attempt ...
telescopic and tilt steering not working - Cadillac Forums
Dec 01, 2015 | Cars & Trucks
Hoveround won't move.
Double check to be sure drive levers are fully engaged. Go down and up a few times. If problem persists have Hoveround come and check it out. One of the drive motors may have shorted out when you continued driving with gravel in the wheel.
Mar 29, 2015 | Hoveround MPV5 Electric Wheelchair - Used...
Back wheel sticking
Its either a sticky caliper on the rear or its in gear .is it stuck all the time or will it move a few feet and then stop quick ? If its stuck all the time id suggest tapping the caliper face with a soft mallet to loosen the caliper pistons a bit . If its moving a bit then stopping then check its in neutral
Mar 13, 2014 | 2011 Piaggio Zip 50
Blocked motor message for 2140. Has happened 3 different times. Sewing machine repair is two hours away and I need my machine today. I did all the thread things suggested with the bobbin, re threading,...
You said the hand wheel barely moves. Is that all the time? If the hand wheel is hard to turn the motor is getting overloaded and is protecting itself by stopping and giving you the error message. You need to determine why the hand wheel is tight. There could be thread caught or something might need lube. These are non oiling needed machines however sometimes a linkage might need fresh lube.
Sep 12, 2013 | PfaFF Sewing Machines
Swatch diaphane second hand stuck
Hello, a week ago the small second hand (not long chrono second hand) got stucked and my irony swatch just stop moving. Although the chronometer could be running if started... The small hand just didn't move.
I tried different tricks, like removing battery, pull out main wheel and use chrono buttons to reset arms. Etc.
Today I noticed that when turning the wheel backwards a couple of times (one or two hours back) the little hand moved one second back... Pushing wheel back to On possition made the small hand move forward one second and get stucked again.
Then I did this procedure a couple of times, at some point I turned the wheel back for a while (may be 5 full turns) and noticed the small hand moved more than one second (5, 10, 15 seconds backward)... when I noticed it was moving freely I pushed wheel to on position and noticed the small second hand was running normal.. I hope it works for some of you. Greettings from Canada
Nov 06, 2012 | Swatch Diaphane Chronograph Blooded Silver...
Why do my antiloks engage when the wheels spin in awd?
The vehicle computer's Traction Control System (TCS) has detected wheelspin on one or more wheels that's greater than the detected speed of the vehicle. That is, it knows you're spinning the tires and not going anywhere (or not really going that fast). It compares the rotation of all wheels to that of the slowest moving wheel (or slowest wheel that has a sensor), and slows down the faster of the bunch. Since it's not a full-time 4-wheel drive (where all wheels move the same speed all the time), it allows some wheelspin for outside wheels around corners, but keeps the wheels in check with the brakes. Some Traction Control Systems rely on cutting engine power to stop wheelspin, while others activate the brakes on the faster-moving wheels.
Mar 09, 2011 | 2003 Chevrolet Astro
Pride Celebrity 3 wheel. The free wheel lever
My Mother buggy does the same and you can damage the gearbox, so I use a elastic try down to the bumper this stops it from moving but should there be a need I can remove it.
the Freewhel mech may have come loose so check it out.
Regards
GeWiz.
Oct 12, 2009 | Pride Celebrity X 3-Wheel Electric Scooter...
When turning tue wheel on the mouse, the screen continues moving
Adjust your mouse wheel settings, to scroll less lines at a time. That should take care of it.
I hope that helps,
Eric
Nov 27, 2008 | Dell Wireless Keyboard Optical Mouse w0147
Intermatic T101 - 24 Hr. Dial Time Switch - NEMA 1 Indoor Steel Case - Gray Logo
469 people viewed this question
Top Intermatic Electrical Supplies Experts
Gene Haynes
Craig Butler
Craig Butler
Jay Finke
Jay Finke
Are you an Intermatic Electrical Supply Expert? Answer questions, earn points and help others
