Question about T-Mobile MDA
T mobile mda
My mda just stoped coming on. It will not charge, or power up i dont no if i need a new batt. please help if its just the batt cool if not i need to get a new phone
  • nmat11 Aug 07, 2008
    my mda cant turn on.
  • Anonymous Aug 14, 2008
    so did getting a new battrey work
Mine also did it and finally nothing on even I thought battery died I bought a new one.
Posted on Jul 17, 2008
It just stoped working I thought the batt needed charging. Did not help I bought a brand new batt and it still won't do anything. nothing comes on
I just took the thing apart. Unscrewed front cover and just pokeing around with a feeler gage and it started working.
Dec 31, 2009 | Canon PowerShot G2 Digital Camera
Tip
Hi, I would like some help reg, the T-Mobile MDA charging. I got 2 batteries, 1...
Your battery has been depleted past a chargable state.  This is a due to a bad design in the phone that doesn't monitor the battery power state well enough.  It actually allows the battery to be taken under the minimum amount needed to recharge the battery.
You can fix this, but do so at your own risk.
You can simply purchase a new battery, that will work, just been sure not to let it deplete the battery totally anymore.
Now, on to the fix
-Take out the battery.
-Get any usb cable you can find sitting around. (any usb wire will do, an old printer cable, anything with a usb end that can plug into your computer)
-cut one end of the plug off. You need to leave the side on that connects to your computer. Cut off the side that plugs into a device (printer, camera, web cam, etc)
-Strip the rubber off the wire and expose the wires inside.
-Separate the wires from each other. You will only be using the BLACK and RED wires.
-strip the very end of the black and red wires carefully using a wire cutter exposing the metal wire inside the red and black covering.
-Plug in your home made battery charger to your computer. Careful not to touch any exposed metal, as it will give you a small shock.
****WARNING****
DO NOT UNDER ANY CIRCUMSTANCES ALLOW THE RED AND BLACK WIRE TO TOUCH EACH OTHER
****WARNING****
-now carefully hold the black wire to the negative terminal on the battery (it should be noted with a black circle with a - in the middle). Then touch the red wire to the positive terminal (it will be noted with a red circle with a + in the middle).
Hold the 2 wires there for 20 seconds. Then quickly plug the battery back into the phone, and then plug it into a regular charger. Give it little bit of time, if you've done everything correctly the charge light should come on.
I had to repeat the last step again to get the light to turn on indicating it was charging.
You must not hold the wires to the battery for too long, 20 seconds should do it. You can overload a battery with this trick and actually make it explode if you hold it there too long. You are well within the few minutes needed to detonate the battery due to overcharging by sticking very strictly to 20 seconds.
Just be careful and you'll be fine.
One you get a charge light give it a few minutes in the off position, then try powering up the device and keep it plugged in until you get 100% charge.
Good luck,
Peter
on Jan 08, 2008 | T-Mobile MDA
MDA will not power up.
another this to try is get a new battery.
mine had the same problem i would try to charge and nothing and it would turn on for about 30 seconds then turn off and i tried putting it on a charger within those 30 seconds but it wouldnt take a charge.
i got a new battery theat had some charge in it and it worked great! alot of the time thats all you need it a new battery
Mar 15, 2008 | T-Mobile MDA
Mda not charging
Either your battery is bad or your soldered contacts on the inside to the charger port are broken.
Jan 09, 2008 | T-Mobile MDA
T mobile mda
If the unit is not new have you checked the status of the battery and is it a manufacturer's battery - some units are quite sensitive to that.
The problem may also be with the charger
Dec 22, 2007 | T-Mobile MDA
Help ASAP my MDA wont turn on
it might take a while tfor the light to come on . leaving it on all night should not hurt it. try charging it again
Nov 06, 2007 | T-Mobile MDA
I need the data on my dead MDA!!!
Try to trickle charge it by hooking it up to the USB and then to your computer. Let it charge up a bit then try powering it on or charging it the regular way to charge it even faster.
Trickle charging
Some Palm devices have the ability to "trickle charge" from a USB port on a PC or Mac. This means that it receives a very small amount of charging from the USB port, even if it is not connected to its AC charger. If your device is capable of this function, the charging time will be significantly longer for a trickle charge (depending on the power rating of the PC USB port). However, the device may not charge at all on an unpowered USB hub (or for example off off a keyboard).
Sep 23, 2007 | T-Mobile MDA
T-mobile mda
buy a battery new
Sep 14, 2007 | T-Mobile MDA
MDA (T-mobile)
Make sure that your mda is being charged with an original charger
T-mobile MDA sceen doesnt function properly.
hello Shivang this more of a problem that it has to be looked into by engineers in theworkshop. find ou t if you still have any warranty in place from the manufacturer. the problem is that the screen controller is faulty an it has to be fixed in the workshop it is pure electronics stuff
Jun 03, 2007 | T-Mobile MDA
T-Mobile MDA Logo
75 people viewed this question
Top T-Mobile Computers & Internet Experts
Computer Repairing
Computer Repairing
ismael castillo
Are you a T-Mobile Computer and Internet Expert? Answer questions, earn points and help others
