No spin cycle
Spin cycle is not functioning, all other functions including tumble in either direction are working fine... not sure if this is a motor problem or something in the circuitry mine is a front load model FTF2140ES3.i did the test everything works fine but the spin cycle, after i finish doing the test it keeps flashing the lights for code E43 which is change the control board
  • Anonymous Jun 18, 2008
    hey premm i dismount the motor to change the brushes but there is no way to get to the brushes . thank you anyway. any other advice ?
    Problem Solver:
  • 4 Answers
Have same machine with same error code. Change the door switch , and not the controlboard. Fixed ours for $45 and in 15 minutes.
Posted on Oct 13, 2009
    President:
  • 1,294 Answers
Before you try changing the control board, try changing the brushes of your motor.
Posted on Jun 14, 2008
  • prem mathew Jun 18, 2008
    Likely you hv to dismount the motor; before that google 'how to change motor brushes'; there is even a video......it is important & useful.
Not spining properly on daily load cycle
Make sure door mechanism is working at fine. So next is to check whether the motor tumbles both directions.
The spin bearing might be a problem, but normally you'd hear a problem here first. Have you heard any freight trains passing through the house in the spin cycle?
One thing to check for this problem is the spin speed switch. If the spin speed switch is bad then the control won't know how fast to spin, and so it will just not spin at all.
The drain pump must be draining all the water out. If the water doesn't drain out then the pressure switch won't read empty and that might prevent a spin cycle.
I hope this helps.
Please reply with additional details for further assistance.
Shane
Mar 26, 2011 | Whirlpool Washing Machines
My kenmour washer stopped spinning
I hope this helps.
Shane
Mar 26, 2011 | Kenmore Washing Machines
Will not spin
I hope this helps.
Shane
Mar 10, 2011 | Bosch WFK 2401
The washing machine does not spin, it says error 4
I hope this helps.
Shane
Mar 08, 2011 | Washing Machines
No spin cycle
I hope this helps.
Shane
Shane
Mar 01, 2011 | Hotpoint WMA76 Front Load Washer
Cannot spin
I hope this helps.
Shane
Feb 12, 2011 | Washing Machines
Lower washing machine function inoperative in Maytag stackable
rclasky check this one
http://www.fixya.com/support/t827165-maytag_model_lsg7806aae
Mar 13, 2009 | Washing Machines
Washer wont spin or drain
did you check to see if there was anything stuck in the pump? sometimes socks and other small articles get dow there and wont allow the washer to spin or drain
Feb 07, 2009 | Frigidaire Washing Machines
Will not go into tumble action
Because F04 is not a clearly defined failure, the possible cause of your situation is a timer, a lid switch, a belt, a drive motor, or an agitator.
Solution, before proceeding watch your timer (does it follows its cycle?) if no replace timer, if yes, then check your lid switch replace if defective, check your belt if it broken or worn replace it, check your drive motor for functionality, and check your agitator--your agitator can become worn, strip out the spline that allows it to properly grip the shaft.
Jul 07, 2008 | Frigidaire ATF6000ES Front Load Washer
Estate by Whirlpool washing machine will not drain or go into spin mode in any cycle.
I would try and check voltage at the overload on the motor
when in spin cycle and see if you have power there..
 that should tell ya if your at least getting power from the timmer or not in the spin cycle to the motor
Sep 04, 2007 | Admiral AW22 Top Load Washer
Washing Machines Logo
374 people viewed this question
Top Washing Machines Experts
