Question about Medion MD-40954 Notebook
Mrkinc: It most likely is. I have one here that has two small 2 in. fans. One fan is burned out. Cant locate just a fan that size anywhere.
  • Steve Minarik
    Steve Minarik Nov 04, 2010
    I just looked at the sight. I didnt see any place for parts. Unless its written in German, But I dont speak German.
  • Steve Minarik
    I put in this as an FID2100 not a MD-40954. Dont know what happened there.
    Genius:
  • 1,325 Answers
Hello
have you gone to the website to get part numbers for the fans ?
http://www.medion.com/de/electronics/cat/Notebook/notebook_9
Posted on Nov 04, 2010
Small puff of smoke coming through the top right of the laptop
The fan usually wont fail in that manner, If it still works normally, you can go to www.almico.com and download a program called speed fan. It is free and it will tell you the temp of everything in that computer.
Feb 09, 2014 | Advent 6552 Laptop
What size case fan for HP Compaq dc7600?
What size case fan? Dunno.
1) How to measure the fan? Across the fan's shroud. (Surrounding Cage) Fan stood up, measure the Height, and Width.
2) Look at the label on the fan's center hub. Write the number down.
Now which of these CHASSIS fan numbers match?
http://www.sparepartswarehouse.com/HP-Compaq,Business-Desktop-dc7100-dc7600-dc7700,Computer,Fans.aspx
A) 3777791-001
Chassis Fan - 70mm x 70mm x 15mm.
70mm x 70mm is the height and width of the fan's shroud. (Surrounding cage) [ Chassis fan stood up ]
15mm is the Thickness of the fan shroud.
Nope, not that one.
B) 451144-001 Chassis Fan - 92mm x 25mm
Could be.
C) 455310-001 Chassis Fan - 92mm x 25mm.
Could be.
Regards,
joecoolvette
Jun 11, 2012 | HP Compaq dc7600 Small Form Factor PC...
Were is the 2004 Jaguar x type electric radiator fans relay at?
I don't know where it is; however, my husband and I have purchased 2 cooling fan assemblies for my 2004 Jaguar x-type 3.0 AWD. Neither of them would turn on. We have since been advised by a Jag mechanic that you must have a part called the link lead in order for the fans to work properly. This is a non-admitted (by Jaguar) default in this car. Check Quality Auto Parts 800-505-5838, ext. 1047 and ask for AMY. Hope this helps Nancy
May 06, 2012 | 2004 Jaguar X-Type
Heater / a.c fan switch is only working at high speed
power reducer is burned out, usually located on the back of engine compartment small plate with 2 screws or small bolts and the heater fan wires go from this to the fan
Jan 04, 2011 | 2000 Dodge Caravan
2006 H3 Hummer fan problem
Hi if your internal fan not work in any position well i fixed up myself easy and save your money.
locate the fan motor air just outside right courtesy drawn document in front of passenger. go from down and look up you will see a motor with a big connector white with 2 screw secure inside the motor block. loose the two screws and pull out gently the connector from motor fan block. you will see a green multiresistor connected with this big connector. Usually the first + voltage connector is burnet out. disconnect the connector pull from resistor and check for any burn. in my case the first pin was burned out completely
you can buy another connector or you can clean the burned connector take out form connector weld a small copper cable of 5 mm dia from resistor to the burn cable and reconnect the connector without buy a new one. after replace again the resistor in the hole of motor blow with the 2 screw.
Done all work again without buy another new connector.
Gabriel from Italy Turin
H3 hummer 2007
loveling one and Humvee owner
May 07, 2010 | 2006 Hummer H3
2001 accord fan will not work on 1 and 2 speed, works fine in 3 and 4
The fan resistor block has partially burned out leaving you without the lower speeds. It is located behind the glove box in the air plenum box. You will see a small rectangular connector with 5 wires held down with 2 screws. You will have to replace the block.
Jan 01, 2010 | 2001 Honda Accord
No heat or fan operation
24/7 Appliance Repair @ (608)214-5632 we are located in southern wisconsin, Thank You
May 26, 2009 | Marvin 3150 Mid-Size Heater
Medion MD-40954 Notebook Logo
42 people viewed this question
Top Medion Computers & Internet Experts
Hollyecho Montgomery
Robert Karst
Robert Karst
Are you a Medion Computer and Internet Expert? Answer questions, earn points and help others
