Question about Humminbird 947C GPS Receiver
Transducer not connected
947c was working fine and now it's not working at all and it states that the "transducer is not connected". Ran a diagnostic on the 947c and it states that everything is working fine. Bought a new Transducer and it still says that the "transducer not connected". Checked all wires and connections and they all seem fine. Any suggestions?
  • 3 more comments
  • Anonymous Jul 07, 2008
    Mine says GPS not connected .. let me know how you make out.. Don't want to buy any parts till I know it's not the machine
  • davekrech Jul 23, 2008
    I am having the same problem and also bought a new transducer as I thought barnacles had fouled mine. Still same problem. I called Humminbird and as I was within 1 year warranty they did free repair in April 2008 (replaced a circuit board). The same problem reoccurred in June and again sent in to Humminbird. They did a free repair. The same issue "transducer not connected" occurred again July 20th. I called Humminbird and asked them to replace the entire unit. They said they could not as I had passed my original one year warranty period. They were also relunctant to do a free repair again for the same reason. I pointed out that the June repair invoice stated that the repair was guaranteed for 90 days. They reluctantly agreed to repair for free again. Let's see what happens. I fish every weekend and need GPS and Sonar for offshore wrecks so the repair downtime really puts a crimp in my fishing.
  • Anonymous Aug 04, 2008
    I have a 947c just over one year old. I purchased the extended warranty from West marine. They have offered to gt me a new transducer or switch it out for a new unit. However, I have to pay the difference between the new unit and the old unit. It sounds like I need to swap it out.
  • paulswebb Jan 20, 2009
    same problen in addition prior to failure the bottom was reading a "trench" under the boat for the flat bottom. I too replaced tranducer- no fix.
  • Lee Gardner Aug 05, 2012
    Has anyone found a solution to this problem. My 947c was working great and on the next start up started reading "transducer not connected" I have torn the boat apart. Cannot find anything wrong. Now it looks like it costs $480.00 dollors to have someone look into it at Hummingbird. Looks like they are sick of working on them! Let me know if anyone has found a solution that works.
My 947 c says transducer not connected
Posted on Feb 11, 2010
Why does my transducer not get a return when its deeper than 150 mts?how much amps does it need to operate in deep water?
Normally a new clean faced 1 KW thru-hull transducer works to 3,000 feet ( 914 meters).
Maybe the impedance of the transducer and electronics driving it do not match.
Connecting cable too long?
Poor connections. Look at plug pins to see if any are bent.
Oct 08, 2014 | Humminbird Boating
My Structure Scan display is good on the left side and the right side does not fill the screen. My transducer is mounted under my boat on the step. I have a HDS8 and everything is brand new. All other...
verify cable harness integrity at base connection of transducer , replace cable or check settings easy fix would be change display unit if unit under warranty as replacing transducer is not easy and economical
Jan 17, 2018 | Lowrance LSS1 StructureScan Sonar (Lss1...
I want to see the schematic diagram of humminbird fish finder transducer, my fishfinder won't operate. if i plug another unit of transducer, the my fishfinder operates normally.
Hi Greg and Ernesto:
Re-stating the obvious, your transducer is not working but you know that the sounder is.
I would start by checking to see if your transducer works on a different sounder. That's just a double check to confirm that it really is not working.
Then I'd try to isolate the problem:
- Plug (couold be corroded or damaged)
- wire (could be broken)
- Transducer (could be defective)
Since these are sealed units, I'd be checking with the supplier to try to find a replacement. Hopefully they are not too expensive, and time spent fishing is better than trying to maybe save a few dollars, especially if you're taking out charters.
Best of luck.
Sep 01, 2010 | Humminbird Fishfinder 525 406260 1
Lowrance X-136DF Fishfinder Not working
Hello Keneth,
Is The transducer In Side the Hull Or Mounted On The Transom?
If Inside Remove It And Re Fit It Using Epoxy Glue Ensuring No Air Pocket Between transducer And Hull.
If transom Mounted Replace Transducer.
Hope this Helps
Gordy
Nov 30, 2017 | Lowrance X136df Fishfinder With Dual...
Transducer loses bottom at any type of speed greater than trolling. Worked fine last year with all the same setttings. All I can think of is , maybe the battery is low. The boat just came out of storage...
Check the transducer for any damage on the front part. Also make sure there isn't any damage on the bottom of the boat that is causing air bubbles to cross the face of the transducer. If it works at slow speeds there is definitely something causing air bubbles.
May 08, 2010 | Lowrance Lcx 27c 7" Gps Fish Finder Combo...
My Lowrance X-51 is not reading the depth sitting still of running . Do I need a new transducer ?
Yes quite possibly... But a few things to try/check first before you go out and get a new transducer...
1. Ensure the transducer is fully submersed below the waterline when floating and when on the plane... try lowering it more if you can.
2. Check the surface of the transducer itself (the underside) pointing down... If there are any minor scratches or scuffs, this can effect its function or performance. Minor scratches or marks can be sanded out with fine wet/dry sandpaper (at least 400 or 800 grit).
3. Isolate any electrical wires running near or next to the transducer cable. Also check connection of cable at head unit, and that the pins etc are clean, free of corrosion and making good contact.
4. Take your head unit to your Lowrance dealer and they may have a transducer there to use to diagnose whether it is indeed the trasnducer or a problem with the head unit.
Jul 31, 2009 | Lowrance Boating
Built in transducer is not picking up/transferring depth to graph
I havew a Minn Kota trolling motor on a Z21 Ranger. Minn Kota has a built in (puck type) transducer on the motor. I have a lowrance 135x on the front. The lowrance will read the temp but will blink the depth. I switched out the depth finder with another 135x with the same results. I have a 522c gps unit networked together and mounted on the console that works fine. Any suggestions on the problem with the 135x?
Jul 27, 2009 | Minn Kota Maxxum 70 Universal Motor/Sonar...
Sonar only reading the surface
First, ensure that the transducer face is pointing down when the boat is level in flat water. You may want to do this step like a tv antenna, adjusting the angle of the transducer while watching the screen.
If that doesn't work, then try moving the transducer further into the water and repeat step one.
Sonar systems are (largely) directional, and will work best when parallel with the seabed (or lake bed etc)
Jan 20, 2018 | Lowrance LCX-104C
Sounds like an internal problem in the 947c. A factory reset may cure the issue if it's related to the operating system. Unfortunately I'm not sure how to do the reset on that model. I'll try to look it up and get back to you.
Jun 14, 2008 | Audio Players & Recorders
Humminbird 947C GPS Receiver Logo
1,118 people viewed this question
Top Humminbird GPS Experts
Mike Marcotte
Mike Marcotte
Steve
Steve
Jerry Greenberg
Jerry Greenberg
Are you a Humminbird GPS Expert? Answer questions, earn points and help others
