Question about GE Refrigerators
Refridgerator my ice maker works fine but the water dispenser doesn't work. I used a small balloon air pump to force air from back end of tube and it reached front dispenser so I am guessing no blockage. can you help me please? thanks
    Problem Solver:
  • 27 Answers
Please cheak dispenser water pipeline any leakage
Posted on Jun 14, 2008
I have a side by side refridgerator freezer. I have just connected the water to the ice make / water dispenser for the first time and just a short trickle of water flows into the ice cube maker - not
I would guess that you need to purge the air out of the lines and system for it to work correctly. You can hold down the water dispenser for awhile to help, but if you do nothing, it should purge itself over the next few days.
Jan 07, 2012 | GE Refrigerators
I have a whirlpool refrigerator model et1fttxcq08 and the ice maker works fine but the water dispenser will not. You hear the motor when you press on the dispense button but no water comes out.
you will need to check the water line inside the door and make sure there is no frozen water in the line.
To check and make sure the water valve is working you can disconnect the water hose on the bottom of the door make sure to have a glas or small pot handy, when the water line is disconnected you can try and dispence water and if water comes out then you have frozen water in the line in the door.
You can also use a long piece of weed eater line and sticke it through the water line in the door and it should go all the way through.
If no water comes out when you have it disconnected then the water may be frozen in the lines on the inside of the fridge.
If the water line in the door is frozen you can use a blow dryer and blow hot air in the tub alternating between the top and the bottom of the line this can take awhile to do but will clear it up.
Dec 24, 2010 | Whirlpool Refrigerators
Hot point model hss25gfp. can get water at coupling but not out of door dispencer . ice maker works fine. When coupling is disconnected and water is depressed water flows fine from the coupling.
The water line is frozen in the door .Turn on the dispenser light for several hours , or , use a hair dryer aimed up into the dispenser , or , use compressed air in the tube going up into the bottom of the door ( computer cleaning bottle with a small tube ) , or , air compressor hose at the bottom of the door tube , or , order GE dispenser heater kit pt # WR49X10173 ( it comes with instructions ) . After you get it working , turn up ( warmer ) the freezer temp only slightly .
Aug 08, 2010 | Hotpoint HSS25GFP Side by Side...
Maytag sidebyside MSD2758DRW ice maker won't make ice
If the ice maker no longer make ice, check the following.
Check to see whether the ice maker has been turned off. Here's how to check. Look for a wire along the right side of the ice maker that looks a bit like a coat hanger. If this wire is in the raised position, the ice maker is turned off. On some units you simply lower the wire to the down position to turn the ice maker on.
On others, you lower a small red plastic lever to lower the wire. If the wire is in the proper position check the freezer temperature, it should be between 0-8 degrees Fahranheit. If it is warmer than 10-12 degrees, the ice maker may not produce any ice.
Check your door seals and thermostat, repair/replace as necessary.
Thanks
Jul 10, 2010 | Maytag Refrigerators
The water dispenser unit has a tube coming into the back of the fridge. Anytime you dispense water, it will also leak from this tube in the back. Also, about once a day or so, it will sound like water is...
The water inlet valve on the back of the unit where the water supply comes in can have a slow leak and will cause ice to buildup and block the fill tube. Disconnect the ice maker line from the valve and watch to see if it has a slow drip. It doesn’t take much to eventually block the fill tube. You can thaw the fill tube and replace the water inlet valve.
Sep 27, 2009 | Jenn-Air JFC2087HRS Side by Side...
Wont dispense ice or water
Hi
Please follow this :
Check to see whether the ice maker has been turned off. Here's how to check. Look for a wire along the right side of the ice maker that looks a bit like a coat hanger. If this wire is in the raised position, the ice maker is turned off. On some units you simply lower the wire to the down position to turn the ice maker on. On others, you lower a small red plastic lever to lower the wire. If the wire is in the proper position check the freezer temperature, it should be between 0-8 degrees Fahranheit. If it is warmer than 10-12 degrees, the ice maker may not produce any ice. Check your door seals and thermostat, repair/replace as necessary.
The ice maker is producing ice poorly When an ice maker is producing ice poorly--when it produces just a few cubes or none, or when the cubes are too small--it's usually because of a clogged water line or a defective water inlet valve.
First, check the water line attached to the back of the refrigerator for good water flow. To do that, first turn off the water supply valve. Then remove the water line from the back of the refrigerator. Next, place the water line into a bucket and momentarily turn the water valve back on to test the flow. If the flow is poor, you need to repair, clean, or replace the tubing or the shut-off valve that supplies the water. If the flow is good, you may have to replace the water inlet valve.
There's an ice- or water-dispensing problem The ice and water-dispensing system of your refrigerator is quite complex. Many components work together to provide the ice and water. Aside from a simple problem of a leaky water tube or a jammed ice chute, most other components are not user serviceable. We suggest that you contact a qualified appliance repair technician for such repairs.
Please revert for any assistance and Do accept this solution.
Thanks
Rylee
Mar 21, 2009 | GE Refrigerators
Water wont flow into LG LX259602b ice maker
You may have a bad water valve.  The valve has 2 sections, one for the water dispenser and the other for the ice maker.  Check those connections in the back of the refrigerator.  If everything is ok, replace the water valve.
May 18, 2008 | LG LRSC-26922 Side by Side Refrigerator
Jenn Air JCD2389GES ice dispenser problem
You could have a layer of solid ice at the bottom of your icetray. Remove icetray. Remove any ice in bottom. Reinstall. Be careful there is a connection on the rear of the icetray, you may have to turn it to get it to mesh correctly. Fill with ice and it should work fine. Good Luck.
Feb 24, 2008 | Jenn-Air JCD2295K Stainless Steel Side by...
Jenn Air Side by Side Refridgerator
You could have a layer of solid ice at the bottom of your icetray which is binding everything up. Remove ice tray and any ice from the bottom. Reinstall and be careful of the connection on the back of the ice tray, you may have to turn it a little to get it to mesh correctly. refill and try. Good luck.
Jan 08, 2008 | Jenn-Air JCD2389G Side by Side...
Refrigerators Logo
Top Refrigerators Experts
Sal De GO PATS
Charles T Nevin
Charles T Nevin
Andrew Taylor
Andrew Taylor
