Question about Nintendo 64 Console
My nintendo 64 randomly resets for no aparent reason
My 64 appears to radomly reset for no reason. I have checked to make sure that contacts are cleanded and I do not beleive it is a short in the wire. The red light on front does NOT flicker wheb this happens. Any suggestions?
    Problem Solver:
  • 3 Answers
Im thinking you n64 might be overheating, is it in a lil box or something? if not then im saying to try different games
Posted on Jun 17, 2008
I have the exact same problem! I recently tried to play Zelda OoT and i got about 5 minutes into it and it resets. It isnt always at the same spot but it will at some point just reset making it not very fun to play. Im not sure that over heating is the problem. My system is out in the open. This has also occurred on several games. Im thinking it is just old and maybe has a short in it somewhere.
Posted on Oct 14, 2008
Turns on & off & volume Goes from 0 to 100 to o all at radom
Reset your tV to fatory defaults. If this do not help you, check and replace its main system memory IC. Contact any experienced service technician.
Jun 07, 2012 | Samsung LN46C630 TV
Goldeneye deleted all it's memory randomly
Hello, n64 cartridges are outdated for that reason exactly. They have a small space to save game info. A quick off and back on is actually the way you reset the memory. Say you bought someone else's n64 and each game you loaded had saved info on it. Powering off and then turning it back on, would erase that data and allow you to start your own game. Once your 64 went instantly off, it reset/erased the saved info. Unfortunately there is nothing I know of to get it back. Sorry. Hope this helps though.
Nov 18, 2011 | Nintendo 64 Console
My Nintendo 64 will reset randomly after playing it for a while. I know for a fact the reset button isn't stuck. I've heard it could be a short in the system, or the AC power supply is bad. Will...
Well you know on how computers will re set them selves when they have an error in the software
so put it this way a N64 internal parts are like a computers pieces but a simple software so when it resets its self it acts like its going to repair its self but this is inpossible so it will just keep on redoing then. error in the software then.
Jul 18, 2011 | Nintendo 64 Console
Pokemon Platinum error
u need to delete the sav file and reset
Jul 18, 2010 | Nintendo Pokemon Platinum for DS
Nintendo DS Lite randomly resets itself
open it up and see if there is something in there that dosnt look like it should be there and remove it.But message me back if there isnt and ill tell you what you should do then
May 09, 2010 | Nintendo DS Lite Console
My N64 system randomly resets, I don't think it's a problem in the hardware itself cause its perfectly clean inside. I'm thinking it may be the AC adapter is on its last leg but I don't know for sure. If...
I think that your reset button might either be loose or busted to open your N64 console up you need a 4.5mm bit screwdriver. Lukie games has that tool you can buy then
Mar 08, 2010 | Nintendo 64 Console
N64 and NES reset randomly
Well you know on how computers will redo them selves when they have an error in their software and programming so you see that an n64 consoles parts are similar to a computers piece but a simpler software so when it does the resetting it says im going to fix it but since that its impossible fro it to fix its self it will just only keep reseting over and over again then.
Jun 07, 2009 | Nintendo 64 Console
Autorestarting
maybe you should check if the button is jammed in or try checking if the connection between the reset button and the inside of the nintendo are making contact with each other. try that.
Dec 09, 2008 | Nintendo 64 Console
Shuts off randomly
could just need the power switch replaced in the system can ushally buy a new one off ebay for a couple of bucks, but if thats not the issue clean the battery connectors and the battery to make sure its getting the best possible connection.
Other then that there could be other things to try but those are the most simplest of fixes for that issue.
If it becomes a motherboard issue then its gonna get costly.
Jul 30, 2008 | Nintendo DS Lite Console
64... or not
Get a cleaning kit and clean out the terminals on the game cartridge and game slot.
Corrosion on the terminals is common on older systems and games.
They should be cleaned regularly. Maybe once a month or as problems occur.
This should always be your first troubleshooting step when a game stops working properly.
Apr 21, 2008 | Nintendo 64 Console
Nintendo 64 Console Logo
360 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Julian Wainwright
Martin Murray
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
