Question about Motorola Mobility S305 Bluetooth Headset
My S305 suddenly stopped working, thinking it was battery I started charging it about 5 hours ago, the light is still red. I have tried unplugging it and turning it on, it does not turn on. Any help will be appreciated as I have these headphones for 2 days...
    New Friend:
I am hoping someone answers this question
Posted on Feb 14, 2016
5 Suggested Answers
maddonkey5
  • 20 Answers
SOURCE: I just bought a H710
Hey, Matt here, this could be a faulty connection to the charger. I suggest checking them with different blutooth device and a diff charger. Also please be careful as this is a fire hazard if it is short circuiting so don't leave it alone. If you don't have one to check with you can go in to a shop that has the device and they shoud let you check if it is the device or the charger that is faulty. Hope this helps. Matt. Please rate me
Posted on Dec 31, 2008
Schmead10
  • 650 Answers
SOURCE: motorola H500 bluetooth won't turn on!
Hold the phone button down for about 4 seconds.. The light should blink 2 times and then stay on to add device to your phone once connected light will go out...Hold button down again light will blink 3 times and go off...........
Posted on Aug 07, 2009
  • 18 Answers
SOURCE: headset not charging
Sometimes it takes longer than two hours. Leave it plugged in overnight if you can. The indicator light should go off after fully charging.
Posted on Sep 04, 2009
  • 4 Answers
SOURCE: Red light stays on when charging, never turns any
i need only the pasword to bluetooth h710
Posted on Jan 05, 2010
Acer Aspire 4830T battery behaving vaguely.
Are you using the provided charger, or are you using an after market "Universal" charger?
If you're using a universal charger, it could be charging the battery too hot and the computer just doesn't understand why the battery is putting out more than the system is expecting.
It could also be that the battery is wrong type. The voltage may be the correct, however the Ah may be too high. This being the case, the computer doesn't understand what why the it's getting a higher Ah reading than it's expecting. The system can not reason that that if it detects more amp-hours than the it should have that it has that much more charge time. It just sees "ERROR" and since you're dealing with a system function that is designed to prevent loss of data the default action is to shut down to prevent loss of data.
You may be able to fix by resetting the Power Management Options. Unfortunately, with out doing test on the machine, it is impossible to tell. I could be software or hardware. If nothing else works, try replacing the battery again.
Oct 11, 2014 | Acer Aspire Timeline X 4830T 14 Inch...
Acer Aspire 4830T laptop battery behaving vaguely
Do you still have the old battery. If so charge it, and see if it charges properly. If so then you have a bad battery.
Mar 18, 2017 | Acer Aspire Timeline X 4830T 14 Inch...
Acer 4830 battery suddenly dead
Your battery is still alive, the problem is in the laptop, it may have a blown resistor or charging ic. I can bypass these parts tru jumpering if ever these parts are not available in the electronics store. Now, take the laptop in the computer repair shop nearest you for this is a hardware related problem.
Feb 01, 2014 | Acer Aspire Timelinex 4830t6443 Core I3...
Red light flashing on joystick about 10 min after charging
Most of the time it may be the batteries at fault. One more thing to try is charging the chair with the Joystick on all night 10-14 hours uninterrupted charging. Your chair may suffer from current roll back. There is a circuit in your system that has to be reset by the long charge cycle to reset it. I did not make this up. it occurs when the motors over heat or have a a large current draw. the chair will operate normally for ten maybe even twenty mins. then suddenly drop down to 2 flashing red lights.
I’m happy to assist further over the phone at https://www.6ya.com/expert/bill_bcbb89783b08c489
Feb 18, 2013 | NRS Hoveround MPV 5 - Used Power...
Hi all...I was stuck in a horrible traffic jam 4 2 hours...in which 1 1/2 hrs were less than 5 mph. My truck is a 2003 Ford Escape. My radio went out then the lights started 2 dim and a brake light came...
I suppose its possible the alternator stopped charging the battery enough at the low engine speed but then worked on the way home.
The alternator will charge 12 - 13 volts at idle, but you could have enough accessories and the cooling fan running to use more voltage or amps than it is producing. Stopping at a traffic light for a couple of minutes does not hurt anything since the battery is usually fully charged. But idling for an hour or more with everything on could run the battery down.
You might want to have the computer checked for codes even tho the check engine light may not have been on. Also have the alternator and battery tested again to see if something happened while in heavy traffic.
Feb 14, 2013 | 2003 Ford Escape
ZUNE NOT WORKING! ONLY BLACK SCREEN! WONT CHARGE!
Listen everyone this is what happened to me and what I did. Let the battery drain completely (unplugged from computer). It usually takes 5 to 6 hours to drain completely.
Then plug back in and hold the back and down button at the same time. Zune should resume functioning afterwards. All that is needed is a recharge.
Dec 29, 2008 | Microsoft Zune JS8-00001 Digital Media...
I was driving home and all of a sudden all of the warning lights started to flash on and off...battery showed little to no juice. I did make it home, but as soon as I turned the car off and tried to turn...
Ladytkk:
The clicking sound is the starter solenoid (a relay) trying to connect the starter to the battery. This is normal when the battery is run down. the first thing to do is to see if you can charge the battery.
If you do not have a charger, see if you can borrow one. BTW, a small charger is a good thing to have, especially if lights or etc are left on and your battery is dead when its time to go to work. You can get a small one at a Walmart like store for a reasonable fee. Connect the red lead of the charger to the red (+) terminal of the battery and the black lead of the charger to the black (-) lead of the battery. Let it charge for at least 5 or 6 hours. Unplug the charger, disconnect it from the battery and try to start the car. It will probably start. At first opportunity, drive the car to one of the major auto parts stores like AutoZone and have them load test the battery. If you need a new battery, most stores will install it right there.
Hope this helps Good luck Loringh Please give me a rating Thks
Nov 09, 2008 | Oldsmobile Bravada Cars & Trucks
It wont turn on and there is a red flashing light
first check your batteries ,whether they are charged or not?and also try the hard reset method ,that is,remove the batteries and keep it removed for half an hour and then insert the battery and try again,it will help you
Aug 04, 2008 | Cameras
Motorola Mobility S305 Bluetooth Headset Logo
445 people viewed this question
Top Motorola Mobility Radio Communications Experts
Lawrence Oravetz
Dennis
Are you a Motorola Mobility Radio Communication Expert? Answer questions, earn points and help others
